Old 03-13-2010, 11:10 AM
GoingNuts GoingNuts is offline
Banned
Mein Auto: 04 330Ci M-Sport
Originally Posted by msouren View Post
I don't have any non-BMW parts, where did I mention that?
Sure you do. You just don't know you do. The Beisan seals are not BMW for instance. But that is compatible with the BMW engine. However the other non-BMW parts that you don't know you have may not be compatible. BMW parts usually are stamped with BMW part numbers and the bmw badge. It's quite easy to verify.
Old 03-13-2010, 11:30 AM
msouren msouren is offline
Mein Auto: 2000 328CI
Which items would you be thinking of in particular? I've had this issue for about 4 months now, so I've gone through the common items that would cause the problems that I've been having, as you can see by the list above. Plus, I've stuck with only OEM items because I know that aftermarket ones can be faulty.
Old 03-13-2010, 11:42 AM
Banned
I wouldn't know. Why don't you go look at all the parts you put in and see which hasn't got a BMW badge ? You don't want OEM items, you want BMW items.
Old 03-13-2010, 05:05 PM
gregetski gregetski is offline
Mein Auto: 2007 M Roadster. 2000 323
When I did my Vanos, has similiar mis-firing problem at idle. Codes said vaccuum leak but couldn't find it. Finally after CCV and new tubes, had to have smoke test down and discovered the leak in one of the spark plug holes - the gasket has gotten pinched during reassembly too small to see. I would never have found it on my own. Just something to consider.
Old 03-13-2010, 07:52 PM
I am certainly considering a smoke test to check for vacuum leaks. Where did you get it done and how much?
Old 03-13-2010, 07:56 PM
I meant BMW, I thought OEM has the same meaning. However, not all of the BMW parts have a BMW stamp on them. I bought an exhaust CPS sensor from Pelican Parts that is genuine BMW, and there is no badge on it. At first, I thought Pelican sent me the wrong part. It turns out that it was indeed Genuine BMW. Pelican states that "only BMW places the last 7 digits of the part on the item itself".
Old 03-13-2010, 09:38 PM
Banned
Does the part number match up with realOEM ? If I were you, I wouldn't mess with precision electronics from anywhere but the dealer. As you have already found out, the money you saved for not going to the dealer parts department had cost you inordinately more.
Old 03-14-2010, 10:35 AM
mrmaico's Avatar
mrmaico mrmaico is offline
BMW driver/rider
Mein Auto: 04 330Ci ZHP/05 12GS
Actually the dealer price at Tischer is quite a bit cheaper than Pelican....$92 vs $127.
Old 03-14-2010, 05:54 PM
Not necessarily, because after all this troubleshooting & replacing parts the issue could very well be the VANOS unit itself and not the other parts I've changed. Although, you may be correct, its hard to say at this point
Old 03-14-2010, 10:35 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
I agree......
mujjuman
