Old 03-14-2010, 04:59 AM
Abuja_325i Abuja_325i is offline
Send a message via Yahoo to Abuja_325i
Mein Auto: just bought 530i 2004
DISA noise & Blue-ish Tail-pipe smoke....?
Hello All, good to be back in the forum.
I know many of you pros and some Amatuers are sick & tired of issues relating to the DISA and smoke problems. I've search the forum using the 2 keywords and I found SOME info that to my problem have no bearing.
Here is my problem:
1-Blue/white smoke emanating from the exhaust pipe
2-Sound from around under the Intake manifold (side connected to the DISA & MAF).
for 2:
from post on forums, the only thing that to me makes sense is "repairing" my DISA (AKA cleaning it maybe)....
for 3:
Don't have cracked cylinder/all valves & seals have been replaced/ all manner of gaskets replaced & the Air Regulater/Lifter (pic attached). I didn't do this because I felt like it but I had a serious OVER-HEATING problem whcih affected the engine.
I am frustrated to hell and between all the meks I've passed thru (some bmw meks who did work for me "on the side") I'm stompped & honestly I'd like to have an experience non-nigerian mek look at it but unfortunately we dont have them hear in abuja.
So, any.....& I mean...ANY help on these 2 problems would be greatly appreciated.
a tired bimmerfest-er....
Name:	crankcase ventilation - $52.jpg
'04 530i (Black)
Old 03-14-2010, 11:37 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Your oil separator has probably failed, sorry to say. The DISA does not cause blue smoke out the exhaust.
Old 03-15-2010, 12:19 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
replace your oil separator valve and hoses.... and replace your DISA as well, if its visibly broken when you pull it out. otherwise, you should reseal it
mujjuman
Old 03-15-2010, 02:52 AM
Hi. Thanks for your input. ut I've replaced my Oil Separator twice already, the last time a day before I started seeing the smoke.
As for the DISA, can you show/tell me how to re-seal it?
'04 530i (Black)
Old 03-15-2010, 09:42 AM
Update !!
Hi guys. This is in relation to the blue smoke from tail-pipe problem.
Well, 2gether with my mek, we've narrowed down the actual problem to the Oil Separator aka crankcase vent valve aka oil lifter, and particularly to the "diphram" inside it. After opening up the side that has the Dia (which is made of this orange round rubbery thing), we found out that the edge of the rubber is torn (so there is no "sealing" effect). It also contributed to the loud noise I had mentioned, and nothing to do with the DISA.
Now, I'm gonna try something here. I'm gonna repair the diaphram using another one that is also bad (from 1 of the 2 oil separators I'd already bought) and PATCH up the side that is torn.....HOPING IT'LL WORK !!!....
Now, if someone has already tried this and succeeded OR NOt , i'd like to hear from you.
if it's the 1st time anyone has tried it, I'll brief you of the results..... either which way I'm going for it...damn the consequences. ....
wish me luck
'04 530i (Black)
