Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 03-08-2010, 09:25 AM
balance balance is online now
Mein Auto: 97 740iL
97 740iL - Electric fan questions
After hearing stories of exploding fans, and realizing that my car has 180,000 miles and my fan clutch has probably never been changed, I want to get an electric fan kit for my car. I've done this on my father's 1992 towncar using an electric fan from a newer towncar and a $50 kit from summit racing. The towncar was easy because the block had a bunch of unused plugs for antifreeze, so when I needed to install the temperature sensor from the kit, I just replaced the plug with the sensor.
So my questions are...
1. Are there any unused plugs on an early M62B44 motor that I can replace with the sensor?
2. If there is, what is the thread pitch for the plug
If all else fails I'll just cut the hose and install a sleeve, but I'd rather put the sensor on the block.
Old 03-10-2010, 01:26 PM
Mein Auto: 97 740iL
OK...
Well, it's a well known fact that switching to an electric fan gives a small boost in performance. With all the threads made about mods to the power figures of E38s, does the lack of responses mean to say that nobody on this board has switched to an electric fan? Do the later model E38s already come with one? If you have installed one on your car please tell me either which kit you used, or where you ran the temp sensor.
Old 03-14-2010, 08:06 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 1997 740i
There are aftermarket kits that use an external probe- it sticks between the fins in the radiator...
1997 740i- Daily Driver- 18" M-Pars, Depo Lighting, HIDs
1991 Mazda Miata CSP Autocross Beast. too much to list..
1999 540i M-Sport 6 SPEED- Waiting for upgrades.
2010 Mini Cooper S- Bone stock TURBO Wife's Daily..
Old 03-15-2010, 01:51 PM
Mein Auto: 97 740iL
It looks like those are my only options as I can't seem to find anywhere else to put a temp sensor. Thanks for taking the time to reply rrtec.
