Old 03-23-2010, 04:52 PM
gs171 gs171 is offline
Mein Auto: 2006 650 coupe
min oil level---topping off
I got the "oil level at minimum" warning on I drive the past 2 days. I still have 2200 miles until my change is due. I looked in the manual and it says to add synthetic 5w 30 oil with a "API SH or higher" rating...
I bought a quart of Mobil 1 5W-30 synthetic. What's confusing is the "API" thing in the manual...on the Mobil bottle it says "ILSAC GF-4 ACEA A1/B1, A5/B5 API SM, SL/CF" Is this "higher" than API SH?
What does that mean? If I put a half a quart of this in my engine to get me until my next change, could this cause a problem? I can't imagine it would be, but I don't want to ruin my engine in doing so...
Thanks in advance.
G
Old 03-23-2010, 05:20 PM
bmwe39fan's Avatar
bmwe39fan bmwe39fan is offline
Mein Auto: 2006 650i
You are fine - the SH rating is a minimum level - check out this link:
http://www.mobiloil.com/USA-English/...ead_of_SG.aspx
Old 03-24-2010, 07:45 AM
NWS Alpine NWS Alpine is offline
Mein Auto: 650i
For future ref the GERMAN Castrol 5w-30 is hard to find on the shelves so if you need oil in a pinch you should use Mobile 1 0w-40. They are tested to be about the same weight. Since you are just topping off it's no problem.
2006 650i - SMG - Alpine White / Chateau
Mods: OEM style 249 19" rims, H&R 10mm front spacers and 12mm rear spacers, KW v3 coilovers, Magnaflow exhaust (x-pipe, mufflers, resonator delete), RPi scoop, BMC filter (charcoal delete), LED angel eyes, 30% tint, OEM iPod interface, AC Schnitzer aluminum pedals, black kidney grill
Old 03-24-2010, 03:15 PM
GregE GregE is offline
Mein Auto: 2008 650i coupe
More info here:
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
2008 650i coupe space gray/chateau pearl, auto, CWP sport Logic 7 comfort HUD AS
Old 03-24-2010, 10:38 PM
BlaZinMJ3's Avatar
BlaZinMJ3 BlaZinMJ3 is offline
Mein Auto: GranTurismo, RR Sport SC
gregE, i grew up in bethlehem and am currently in business over in the lehigh valley. we should hook up sometime
2013 Nero Carbonio Metallic Maserati GranTurismo MC Sport Line
2012 Valloire White Pearl Mica Range Rover Sport Supercharged
Old 03-26-2010, 09:59 AM
Nice, I grew up on LI, moved here 11 years ago. I live near Wegman's.
