Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 03-23-2010, 10:22 PM
joepipe joepipe is offline
Mein Auto: 2005 BMW 645CI
Question Rear tire PSI ??
What is the lowest PSI you guys would run your rear tires on ? I have mine at 38 right now nitrogen filled. Sometimes I think they are a bit stiff/bumpy so I was thinking of lowering them to 36 or 35 maybe ? Fronts are at 32. I have a 2005 645CI with 19's miro reps.
Old 03-24-2010, 05:03 AM
bokmeipai bokmeipai is offline
Mein Auto: 2008 650i & 2006 325xi
should be 33psi for coupe & 38psi for vert.
Old 03-25-2010, 05:25 PM
I bought non-run flat yokohama s-drives 19 inch so I'm wondering if the door chart is ok for those also. Factory 2005 645CI came with RFT Bridgestones and it shows 29 front psi and 32 rear psi for 2 passengers.
Old 03-26-2010, 12:51 PM
twenspirited twenspirited is offline
Mein Auto: '04 645 cic
Hey Joe,
How do you like the Yokohama? I have to purchase some new tires and the factory ones are reported poor by consumer reports.
Old 03-26-2010, 01:33 PM
So far the Yokohamas handle great ....we'll see how they are in the long run as I've only had them 2 weeks
