Lower oil pan leaking - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 03-28-2010, 08:38 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
Question Lower oil pan leaking
on my E38, 4.4, the last few times i noticed a slight coating of oil leaking from the lower oil pan. not the upper, but definately the lower.
being that i havent checked with the stealership on this one, and elsewhere online havent found readily available gaskets, would i be able to use some quality RTV gasket maker? looked like the upper pan piece was installed with grey silicon. i've done it before on other vehicles, but rubber gaskets are much nicer to work with. any suggestions. i plan to do it with the next oil change, maybe 12-16 weeks from now.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 03-29-2010, 07:43 AM
balance balance is offline
Mein Auto: 97 740iL
I'd much rather use a gasket than a sealant, it would seal better and last longer, not to mention be alot less messy. Grey sealant is used for aluminum, but the pan itself is steel, so I'm not sure if the grey stuff would be better than the black rtv for this situation. Taking off the pan should give you access to the oil pump bolts that I hear come loose on these motors, so be sure to check those out if the pan is off.
Old 03-29-2010, 11:43 AM
no its definately the lower pan gasket. above it is dry as a bone, the aluminium part and block portion have no oil dripping down. not even from the valve covers. i'll see if the stealership has the gasket in stock though. it shouldnt be too expensive, my hoses werent.
*Der E38*
manufactured: 7/01
Old 03-29-2010, 02:46 PM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
i changed that gasket on my e38 last winter...if the dealer is too high, go to www.autohausaz.com
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
Old 03-29-2010, 05:19 PM
those prices, shipped even, sound great. i'll check with the dealer tomorrow though just in case i can get a better discounted price maybe. some parts i've found cheaper in town, but most are cheaper online. thanks for the link!
*Der E38*
manufactured: 7/01
