7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
Feeling some drivetrain/shifting slack - and my car being at 138K miles and 8-ish years old - I figured I'd go ahead and replace my guibo joint / flex disc / universal joint. I haven't yet seen any pictures on doing this yet, so I figured I'd go ahead and do it / post pictures.
The basic procedure is:
So far I have the exhaust system down and the heat shields off. Had to take the car down to shut the garage door, but will hopefully have it in the air again and finish in the next few days. Because the space in which I chose to do this is limited, I'm going to make an attempt to skip #3 and replace the guibo joint without dropping the transmission mount. Stay tuned for updates. See pictures / procedure --> here.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... Last edited by Keif; 03-30-2010 at 10:56 AM. |
Let us know if you feel a difference... Great thread BTW, I'm not a DIYer but I'm sure this will be useful to many members.
I really really really appreciate this Keif!
Keif coming through in the clutch again
2003 BMW 745i Sport package Alpine White with Black roof || Black Sport wheels || ACS roof and trunk spoilers || 2 tone creme/black interior || HID foglights || full tint|| black grill || 12V 295/345Hz twin import Horns(my fav )1988 BMW 325e Alpine White under major facelift and construction ![]() |
thanks keef .....looking for you final result
amazing DIY...props man.
2006 BMW M5SOLD: 2006 750Li Monaco Blue/Black|Sports Package|Convenience Package|Comfort Access|Logic 7|Rear Entertainment|Night Vision|SAT/HD|Cold Weather|Luxury Seats|Rear Power Sunshades|35% Tint|22" Custom Wheels|H&R's|Alpina Trunk Spoiler| ACS Roof Spoiler| MTEC v3| |
i just had mine done at the dealer
they charged the warranty company about $1000 i had rough shifts, i wonder if that would fix the problem
'03 745i - modded - GONE - |
wow what a rip
+1. If I had a lift, this would almost be a trivial task.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
what about a pit?
-------------------------------------------------- 2003 745i Sport Sterling Gray/Black 2001 986S Seal Gray / Boxster Red Past: 98 540i Sport 6 944's |
it's really like $150 for the guibo. How can they justify $850 in labor? that's like 10 hours worth of labor at most shops
Could you please list all the parts needed to do this job? I am going to get all the parts together and have my mechanic do it.
Thanks! |
The guibo joint / flex disc / universal joint, part #2 here was the only part I bought.
Tonight I took the driveshaft down, put the new guibo joint on, and bolted the driveshaft back up. Tomorrow I should be hanging the exhaust and bolting everything back up. Also, you do NOT have to drop the transmission mount -- there is a gap where you can hold the necessary bolts at the guibo joint with a 16mm crescent wrench with the transmission mount in place.
when i know i am being ripped off, i raise hell
'03 745i - modded - GONE - Last edited by Seven11; 03-31-2010 at 08:45 PM. |
How about a video of how it sounds without the exhaust?
Bump
I just got mine replaced yesterday under the SIB that covers the E65, otherwise it would have been about $800!
Looking for a fire extinguisher, then I plan on it. =]
Very cool. Been thinking of tackling this one myself - you beat me to it!
No go on the video without exhaust -- I couldn't find a fire extinguisher that wasn't behind glass. =( Next time I'll come prepared.
Finished everything up last night. It helps to have a second person when hanging the exhaust, so my dad came over to help. After hanging the exhaust in its rubber mounts, bolting everything back up was very easy. The exhaust system is sealing well and I have no parts left over. ![]() While the old guibo joint didn't appear to have anything but hairline surface cracks in small places, replacing it definitely tightened up the little bit of slack in the drivetrain I felt when shifting and stopping/starting. Very happy with the results. I will post up a few more pictures later today or this evening in case anyone is interested (mainly of the driveshaft and its various joints). Last edited by Keif; 04-02-2010 at 06:45 PM. |
Final pictures posted. Will label and add descriptions and stuff later tonight.
how are u?
There was a little slop in the shifting, mainly while moving, but none now. Is the sound coming from the transmission itself, or somewhere along the driveshaft?
Uj
Some time i feel like it comes from transmition,but some time i hear it coming from the back , but some time it dose not happen it all 10% of the time. I show one mech he said transmtion another UJ
Try having someone else shift while you listen under the car to see how far back the noise is coming from. There is a crossmember underneath that you can use as a point of reference. As you can see here and below, the crossmember is roughly where the middle universal joint is (the bolts coming down from the body on the left and right are where the crossmember bolts on). There is also a similar joint at the very rear of the driveshaft.
#25
I can be all 3 parts central mount UJ and rear joint ? how much time did take for you to do all work?
| Tags |
| exhaust, flex disc, guibo joint, universal joint |
