Old 04-03-2010, 07:05 PM
Meka Meka is offline
Mein Auto: 525iT Wagon
Rear door vapor barrier leaking on floor board.
I have the rear door leak issue that seems to be very common with the 5 series BMWs.
I get a water in the rear floor mat area every time it rains.
I was gearing up to pull the rear door panels and reseal them.
Looking over the doors, mainly the bottoms I dont see where the water is meant to drain.
I dont see any drain holes. I thought perhaps there was a hole in the center of the two drain plugs located at the bottom of the door, but no.
So if my leak issue is the door panel needing to be resealed, how is the water to drain from the door?
Any advice on my leak issue would be great!
2003 525i Wagon
Old 04-04-2010, 05:13 AM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
Rest assured the required drain holes are there. Pull the door panels and reseal the vapor barriers. When you have them loose, poor in a cup of water into the door and you will now know where the drain holes are.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 04-04-2010, 06:15 AM
Hooray!'s Avatar
Hooray! Hooray! is offline
Mein Auto: 2002 530i Sport Premium
Great link to bmw-planet in your signature... never been there before, LOTS of good information and yes, e39's are complicated but nothing compared to the newer 5-series. I think we have the last DIY BMW, now they are electro this, adaptive that, computerized this, variable that... no fixing them without alot of $$$ and dealer tools. Long live the e39!
2002 530i
Exterior: Black
Interior: Black
Packages: Sport, Premium, Cold Weather
Options: HID, Folding Rear Seats, Ski-pass
Old 04-04-2010, 06:24 PM
ctxspy ctxspy is offline
Mein Auto: 1999 528i
i had the leaking issue as well, though i caused it myself when i replaced my window regulator. I ended up buying "3m strip caulk" because the material i had on the door from the factory was not enough for me to get a good seal again, it having been moved around during multiple on-off cycles
Old 04-04-2010, 06:52 PM
525isport's Avatar
525isport 525isport is offline
Mein Auto: 2003 e39 525i sport (uk)
had the same prob not as bad though just re seal the barriers and your good as new
2003 525i sport uk import .see pic ^
1997 300 Tdi Landrover Defender
Old 04-04-2010, 09:15 PM
Severe550i's Avatar
Severe550i Severe550i is offline
Registered Loser
Mein Auto: 2011 F10 550iX M-Sport
what tools are required to remove the door panels? anyone have a good DIY link?
"'Tis nothing good or bad, only thinking makes it so."
-William Shakespeare
Old 04-05-2010, 10:22 AM
This info. would be helpful for me as well.
Old 04-05-2010, 11:13 AM
kentd98 kentd98 is offline
Mein Auto: 99 528iTM
In video form here:
Old 04-05-2010, 06:51 PM
Hooray!'s Avatar
Cool... I need to do this in the next week or so, every rain storm I have to dry things out! : ( My rear regulators were replaced and they must not have sealed things up.
2002 530i
Exterior: Black
Interior: Black
Old 04-05-2010, 08:22 PM
Severe550i's Avatar
Registered Loser
Thumbs up
[QUOTE=kentd98;5077521]In video form here:
Thanks, that's perfect.
Old 04-06-2010, 12:25 AM
The video is VERY helpful! Thanks.
After watching the video it has me thinking. Should I replace my regulators while I have the door panels off.
For all I know they were replaced at sometime in the past. Perhaps thats why I have leaks.
I don't have any issues with my windows. But if the regulators are indeed a design flaw and often need to be replaced should I go ahead and do it before I seal up my doors?
Old 04-06-2010, 12:36 AM
You're welcome on the video link!
As far as replacing a functioning part that will not lead to a breakdown on the road if it breaks, my advice is "if it ain't broke, don't fix it"...but I'm lazy.
Old 04-06-2010, 05:41 AM
Severe550i's Avatar
Registered Loser
I agree.
Old 04-06-2010, 06:07 AM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Vapor barrier repair = standard rite of passage ritual for E39ers*.
*one of many I might add.
Old 04-06-2010, 06:15 AM
cn90 cn90 is online now
This is a very good DIY, basically Torx screwdriver and flat screw driver. Very detailed, and nice pictures:
http://public.fotki.com/stilljester/...por-barrier-r/
It basically boils down to this. If you think you will spend more than 2h playing around with this, then my suggestion is to d/c battery ground acble to prevent battery drain.
Old 04-08-2010, 04:43 AM
gtxragtop's Avatar
Anybody considered putting in a rear seat footwell sump pump. Probably will be more reliable than the rear door seal.
Old 04-08-2010, 06:43 AM
Entwicklung 39
Line it with plastic and stock it with trout.
Old 04-08-2010, 07:33 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Here's another DIY that will be helpful. It's for an M5 but procedure is the same.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 05-01-2010, 02:29 PM
hokiehigh hokiehigh is offline
Mein Auto: 2003 540i MSport
actually if you have rear sunshade, following the M5 DIY, there are few more steps involved to remove the sunscreen.
2003 540iA M-Sport Black/Tan
Old 05-01-2010, 02:33 PM
Hooray!'s Avatar
Is there a danger in disconnecting power 100% (both + and -) while you do this? I read you can scramble modules if you dont let them "go to sleep" for 16 minutes or so. Is that BS? I'm planning to de-sulfer my batter while I do it, right now it never gets back to green in the view port always black.
2002 530i
Exterior: Black
Interior: Black
Old 05-23-2010, 01:08 PM
eob eob is offline
Mein Auto: 525i - 2002
cn90, this was a great help....it took about 40 minutes for the first door and only 20 minutes for the second door. Both vapor barriers were coming off and now resealed....crossing my fingers this will work. Great job....thank you very much. For anyone that is condsidering doing this job, with the help of CN90 it was a easy one.
Old 05-23-2010, 02:51 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
Why not just open whatever doors you'll need to have open to complete the vapor barrier project & then just hit the wider center light button (up by the rear view mirror, where the overhead interior lights are)? This will turn off all those lights (until you open another door...) & hence, no drain on the battery.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 05-26-2010, 06:57 PM
Rainman15 Rainman15 is offline
Mein Auto: 01 330CI Convertible
My car has airbags in the back doors. Disconnecting the battery isn't just for saving the battery, its for saving my face and arms.
Old 04-25-2012, 10:40 AM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
I see several references to 5/16" x 15' is 3/8" ok? its slightly thicker. jyst dunt know if that will b a problem when I open her up
Old 04-25-2012, 11:23 AM
3/8" or 1/4" butyl rope is fine.
Get it at local glass shop.
About $10-15 for a roll of 15 feet.
Here is my experience with window regulator:
http://www.bimmerfest.com/forums/sho...d.php?t=556902
