Old 03-24-2010, 09:05 PM
guideroner 745 guideroner 745 is offline
Mein Auto: 02 745
Lamp control module?
any one ever had this problem?my brake lights are stuck on,after changing switch twice there still on so i know its not that but after talkin to a tech he told me about module,i unplugged it and they would stay off for a minute but eventually come back on wow so drivn with brake lights on .all my lights work so anybody know about this?can i get it repaired?get a used one?tech said have to get knew cause it would mess with odomoter there 500 and another 150 to recode just stupid.
Old 03-25-2010, 04:14 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Light module
The light module controls and monitors the vehicle lights. Information is received and sent via the data bus K-CAN SYSTEM.
Emergency operation properties of the light module: The light module is supplied with terminal 30 twice.
If a terminal 30 fails, the following are activated:
* Front lighting: low beam and parking light (each on one side).
* Rear lighting: On one side, the outer sidelights/brake lights are activated. On the other side, the inner taillights are activated. The vehicle thus still has lights on both sides. Confusion with a one-track vehicle (motorcycle) is excluded.
* Brake light: One side of the brake lights is activated with normal power (ECE coding). This leads to ”one-track” braking, as if for example one brake light had failed.
In the case of a failure of the processor, emergency operating mode is activated. Emergency operating mode involves hardware that is completely independent of the light module. Emergency operation properties with failure of the processor:
* Vehicle lighting: At terminal 15 On, the following are switched on: Front low beam and outer rear sidelight/ brake lights left and right. The outer sidelights / brake lights left and right are not, as would be normal, dimmed to 10% of their brightness, but operated with full power. This ensures the function of the vehicle lighting irrespective of the position of the light switch.
* Brake light: With terminal 15 On, the left and right brake lights are switched on when the brake-light switch is operated (via a hard-wired, direct line from the brake-light switch to the lamp drivers).
Function defects with failure of the processor:
* No turn indicators and hazard warning lights, no high beam, no headlight flasher, no fog lights, no rear fog light, no third brake light
* No communication across the K-CAN SYSTEM.
* No communication with the trailer module
My BMW ACS7
Old 03-25-2010, 05:19 PM
Mein Auto: 02 745
ok so if only my brake lights are staying on its a good chance it aint the lcm?im talkn to a tech on just anwser who says mite be dsc controller because my dsc lights are on, in idrive says dsc is not working,i took it to dealer they diagnosed it as dsc controller im sent that in to module masters they said nothing is wrong with it,now im takin it back monday to see why lights are stuck on,and i dont have a warranty ugh
Old 04-06-2010, 03:54 PM
Anaggie82 Anaggie82 is offline
Mein Auto: 2013 550i
Lighting malfunction
I have this problem. what is the fix?
terry
JTS, Southlake, TX
1984 528e (Sold){No power, bad a/c, bad seats, bad stereo..etc.}
2004 745i (Traded) {Toledo Blue Metalic/Beige, comfort pkg, conveniencepkg, Logic 7,cold weather pkg, 19" Falken 452s, Escort Solo2, soft close doors, etc......what a difference!!!
2013 550i MSport Package, comfort seating, convenience package, Cold weather package, executive package, etc.
Old 04-06-2010, 04:09 PM
terry
Probably means you prob need a new Light Module.
I assume the rest of the steering coulumn works ....if not check the Fuse in the Glove Box.
My BMW ACS7
Old 04-07-2010, 12:55 PM
lighting problem
Thanks, I was afraid of that. My indy shop says they can fix it but it is expensive and may not be covered by my extended warranty. thank Freak
Terry
JTS, Southlake, TX
Old 11-04-2010, 07:47 AM
wpacello wpacello is offline
Mein Auto: 740i
lcm problems
Tech Freak, I had a used lcm installed with no change to the above conditions. I was told that it needed to be programmed. I was then told that you could not program a used lcm for a different car.
Any insight? Thx.
1998 740i
Bummerfest right now
Old 03-28-2012, 05:12 AM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
terry
Hoping to revive an old thread! I have exactly these issues, the LMA unit died when I tried writing the FA (vehicle order) code with NCS Expert.
As yet I have been unsuccesful in trying to restore its functionality.
Has anyone succeeded?
TechFreak, where did you get the information regarding failure of the processor and these symptoms?
Thanks,
Stuart
Old 01-12-2013, 05:04 AM
mody2220 mody2220 is offline
Mein Auto: 730d 2006
hey
i got problems wyth my lights as well but they stay on all the time need to disconect the batery every time, when i start the car and the swich is set on 0 the the xenon lights go on and cant turn them off plz help
Old 11-25-2014, 04:13 AM
fratan fratan is offline
Mein Auto: 2006 750i
I was reading this thread and I think the problem is the LM Light module behing the switch in the Dash. Alllights on is a safety mechanism for this.
2006 750 I
Old 04-30-2016, 05:31 PM
Strydna 530 Strydna 530 is offline
Mein Auto: 2003 BMW 530i
Is it the LCM ?
I have a particular problem when I switch on just the Parking Lights, they come on with the Angel Eyes as is should be, But then I switch on the Headlights the AEs stay on But the Parking/Running Lights go off. The Parking/Turn Signal bulb socket only has two wires, I guess the facelift kind, Is This Normal or is the LCM supposed to turn off the Parking Lights? If I had all three wires would they work right, do I have the wrong LCM or is it Faulty, And could it need reprogramming or the other R Word....Replacing ? I guess I'll need to have a look at it to make sure it's the original one first, Do They pull you over for not having Parking Lights, Is there a rule that states that you Must Have Properly Functioning Parking Lights while driving at night Or are They mainly concerned with the use of Turn Signals ? Thank You if you can Help to shed a little light (Amber Light That Is) on this problem
Old 05-03-2016, 05:29 AM
You need to pull the codes to see what error messages your getting. I'm sure one of your light modules need to be replaced
2006 750 I
