Old 04-06-2010, 07:01 AM
jbrovage jbrovage is offline
Send a message via AIM to jbrovage Send a message via MSN to jbrovage Send a message via Yahoo to jbrovage
Mein Auto: 2000 BMW 540iT
charging vs "charging" the battery
Question for the wise....
normally, when i I've accidently let something drain my battery down, i've just jumped my car, and made sure i drove for an hour or so, to get the battery "charged". I've heard people here on the forums say that doing that stresses the alternator, because it forces the alternator to work harder until the battery is back to full charge. Since i have a 540, with the water cooled alternator, i want to treat it well. However, the Alternator is rated at 150 amps. this seems like it'd be able to take quite a load, and "charging" the battery seems like it should be the responsibility of the alternator.
So, should i charge the battery up with a trickle charger overnight, after a run-down? does this really "lighten the load" on the alternator? I've never had to do this with any other car, why with the BMW?
Also, is there any "high output" alternator alternatives? In my Grand Marquis, i can get a 200amp alternator that's for a police-package Crown Vic. I'd love an option like this for the BMW. That way, i'd feel fine about adding a winch (for all those times i'm stuck on a hill in the snow!)
- Jeremy
"I never learned from a man who agreed with me." - Robert A. Heinlein
Old 04-06-2010, 07:04 AM
frhsfootball80 frhsfootball80 is offline
looking for a car
Mein Auto: e39 m5 & 92 civic
you'll be fine, ive killed my battery countless times, jumped it, drove for a little bit and called it a day. been doing that for 4 years now and i still dont have issues. im sure bmw wouldnt put an alternator in there that cant handle something like that.
Old 04-06-2010, 07:43 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
You are OK, don't worry.
Old 04-06-2010, 07:45 AM
very good. thanks!
- Jeremy
Old 04-06-2010, 08:49 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Bear in mind that the job of the alt is to run the car after the engine is started; it supplies all the current required. It also replaces the energy that was used to start the car.
If you do this frequently, it will stress the alt, as well as the battery. A dead battery s/b brought back to life slowly, charging at about 10% of its ampere-hour rating.
Old 04-06-2010, 09:01 AM
Fast Bob's Avatar
Keeping it surreal
Correctomundo....One other overlooked aspect is that any battery (especially an older one) that has been left in a discharged state for any length of time is probably incapable of taking and holding a full charge, which can lead to all sorts of gremlins popping up, as well as the possibility of outright failure. Better to replace it now, before it leaves you stranded at 2 a.m.
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 04-06-2010, 09:45 AM
1+,
Car battery is not like cell phone battery (I think battery cell phone needs to be d/c completely once ina w hile).
Car battery, after a few cycles of complete d/c, is basically a goner. It holds charge very poorly.
Too bad car maker does not make the hand crank any longer, otherwise, it may be a useful feature for the worst case scenario getting stuck somewhere with dead battery:
Old 04-06-2010, 09:55 AM
i vote for lithium polymer car batteries.
http://www.coloradoautoconnection.co...ries_aev_3.asp
- Jeremy
Old 04-06-2010, 12:46 PM
Fast Bob's Avatar
Keeping it surreal
The battery featured in the link is for a completely different application (i.e., powering an electric motor, with a constant output, demand & load). It doesn`t have a CCA rating, which would be the critical spec for use with a high-compression IC engine....
(R.I.P. Jever)
Old 04-06-2010, 12:53 PM
Fast Bob's Avatar
Keeping it surreal
1+,
I`ve often thought the same thing....a "port" through the grille, where you insert a long splined shaft which interfaces with a gear-reduction box, which in turn spins the crankshaft pulley....your 19Volt, 1/2-inch drive portable drill would provide the power. Of course, you`d probably need a compression-release feature of some design....
(R.I.P. Jever)
Old 04-06-2010, 01:50 PM
I figured if you put enough together in parallel, you'd get enough CCA. if each one is 160amps, maybe 5 of them would do it?
Plus, they are designed to be fully discharged occasionally. So no worries about running your radio all day while you wash/wax your car...
- Jeremy
Old 04-06-2010, 04:59 PM
bmw_n00b13's Avatar
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Offtopic: Cellphones with Lithium-Ion or Lithium Polymer batteries should not be run down.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
alternator, battery, charge, charging, winch
