#26
I still prefer the CTEK over all others I've used (including Battery Tender). I have the 3300 and the 7000, and have been using them for several years. The 7000 is now the 7002, and it's the one I'd recommend. Amazon had them on sale earlier this week for $90. Given the features, that's a steal. Has a recondition cycle, separate profile for deep-cycle batteries, etc. Made in Sweden, very high quality. CTEK was the supplier for the Porsche battery charger (a CTEK 3300 relabelled). My CTEK 7000 is about to finish its 4th stint of being on the roadster for the whole winter (right now my battery is an Odyssey PC925).
Daniel 2002 M roadster |
#27
Does it work with AGM?
On order
7002 ordered.
It works with AGM. Let me know if you get the GT1. Thanks, http://www.ctek.com/EN-US/eLearningUS/Default.aspx
#30
CTEK 7002 Battery Charger
http://www.ctek.com/Manuals/new_US7002_EN.pdf When charged in normal it draws .03 ampere. Battery Tender draws .06 ampere. ![]()
. . Last edited by Ron Stygar; 04-03-2010 at 08:07 AM. |
#31
Last week we visited a friend with several old and exotic cars hooked up to various brands and vintages of battery tenders. Her non-technical view was that they all worked. But the new CTEK 7002 at Amazon looks like a good deal, so I just ordered one for the M. Do you get a commission?
Recent ED: 25 June 10, 328xiT in Red. Then headed SW to Italy & France. Flew home via Rome. Hoegh Kobe departed 22 July; unloaded at PH 17 Aug. Redelivery 11 Sept. (Re-redelivery 14 Sept....read the details here.) Previous ED: 7 June 08, X3 3.0si in rosso corsa (*), then off to Italy, Austria, Slovenia. (*Note: A61 Crimson Red north of the Alps.) Back-up vehicle (while waiting for re-deliveries): 1999 M Roadster in Estoril Blue. |
#32
Not yet. Daniel is the guy that started this years ago.
Another nice thing (7 ampere output), I don't have to replace the tender with a charger when I'm playing with the AutoEnginuity.
It will get quite warm if asked to deliver 7A for a long period (say 8+ hours). The only consequence I've seen is that the paint on the bottom of the enclosure will lose its adhesion. Of course mine is always on the floor which contributed to the paint loss (dragging it around on concrete).The 7A capability combined with its splash-proof enclosure is one of the reasons I prefer it. I just leave it connected almost all of the time, whether I'm working on the car or not. If I spill something on it (I spilled coolant on mine), I just wipe it off; I can't say that about my Battery Tender Plus. Deltran makes a waterproof Battery Tender, but it's 5A.
#34
On ignition position two with the AE it was drawing 1.7 ampere if I remember right. ~200 watts.
. . Last edited by Ron Stygar; 04-03-2010 at 09:53 AM. |
#35
When I had a stock battery, I also found that float charging with the Battery Tender appeared to be contributing to water loss when I left it connected for a whole winter. I assume the pulse-mode maintenance of the CTEK (after 10 days of float) is better on that front, but I am not sure since I haven't had a wet battery in the roadster in quite some time.
The Odyssey batteries seem to like the 'snowflake' mode, and I suspect that's true of the BMW AGM batteries also.
#36
CTEK Recondition
Regular charger didn't do anything and I ended up with jumpers. I was going to pick up a battery Monday. Yesterday I tried the CTEK charging and recondition. Tried it this afternoon and it started right up. Hard to believe.
. . Last edited by Ron Stygar; 04-30-2011 at 02:31 PM. |
#37
#38
put me into the epic FAIL category. Battery was completely dead. Jumpstarting didn't work so I had to buy a new battery...and that did the trick
the stable: 2003 BMW Z4 3.0i 2008 Hummer H3 Alpha 2008 Suzuki SX4 |
#39
Some nice features on the CTEK!
#40
BMW says not to go over 14.8 vots on the AGM battery so you can't do the recondition.
I'll call Exide and see what they say. http://www.ctek.com/Manuals/new_US7002_EN.pdf
. . Last edited by Ron Stygar; 04-04-2010 at 07:31 PM. |
#41
I use the Battery Tender plus and keep it plugged in whenever the M is going to sit for more than a couple of days; I can operate the top/windows/stereo without worrying about draining the battery.
Dang! Amazon now wants $115 for the CTEK 7002.
#43
Thank you, Ron!
#45
Was going to match the bottom of the CTEK, but too much time doing it by hand. 1 each Plate 4" x 8" x 1/8" aluminum. (polished with 220 wet paper) 2 each Spacer 3/8" hex, 1/2" height w/ 8-32 male / female. 2 each Nut nylon lock stainless. 2 each Screw 8-32 1/2" counter sink stainless. ![]() Back on the garage floor doing its thing.
. . Last edited by Ron Stygar; 04-08-2010 at 10:02 PM. |
#46
Anyone using the cigarette lighter adapter for the CTEK? Also, I found a cool wall/window mount for the 7002 that looks promising:
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock. |
#47
Z4...battery tender question
Have used a Sears battery tender(regularly on sale for around $20), on my 2003 Z4, 2.5. Prior to buying the Sears unit, I checked out the BMW one and was told by the BMW sales manager to just buy the Sear product at 1/4th the price of the BMW one.
Prior to moving to Florida this past winter, the car was in residence in Upstate New York, parked in my cold garage, with the Sears battery tender on it for 4-5 months at a time. In the Spring, it always started up at first turn of the key. Now that I can drive the car daily, I will charge the battery, through the cigarette lighter plug, once a week. I've had my now 7 year old battery checked regularly and informed it's still as good as new. I believe the Sears Battery Tender is engineered and produced my Schmacher(not Michael). Gor for it...it's cheap insurance that your battery won't let you down. |
#48
Zuzax, I don't use the cigarette adaptor in my coupe, instead I went with the Comfort Indicator Panel and mounted it in the rear panel next to the battery. It provides a quick connect/disconnect and I just crack the passenger window slightly and run the cable through the window and over the seatbelt to plug it in. Pictures below....
I like the wall mount. I've got slat wall in the garage and have just been using a little wire shelf to do the same thing, but this is cleaner and I can then go back to using the shelf as a shelf.
2006 Ti Silver Z4 M Coupe 2009 Deep Sea Blue 535i xDrive Sports Wagon |
#49
2008 BMW M COUPE- -DME TUNE-RPI RAM AIR-H&R SPORT SPRINGS-GRUPPE M INTAKE-EISENMANN RACE EXHAUST-TEKARBON ANGEL EYES PROJECT ![]() |
#50
+2...that's what I use.
BMWCCA Member 2008 Alpine White Z4 3.0si Roadster 6spd 2006 Silverstone II M5 SMG (gone) 2002 Alpine White 325i Steptronic (gone) |
