Trunk lift/close fluid - Bimmerfest - BMW Forums
Old 02-23-2010, 05:22 PM
mudd746 mudd746 is offline
Mein Auto: 05 745li
Does anyone know what kind of oil goes in the reservoir for the lifting and closing of the trunk? When I open the trunk it sometimes wants to bopp my on the head. After it fully opens all the way the motor runs and then it will drop a few inches. Has anyone else had this problem or know a way to fix it. I think the Fluid is just low
05 745li, 22" Asanti AF211 B4 Alpine White 22x11,22x9.5.
Old 02-23-2010, 05:51 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
Hydrolic fluid, they sell it at autostores
Old 02-23-2010, 06:33 PM
Mein Auto: 05 745li
So its just any standard hydraulic fluid
Old 02-24-2010, 04:51 AM
bembo19 bembo19 is offline
Mein Auto: E65 745
yes ! ATF 95 or something ! nice rims by the way !
Old 02-24-2010, 10:46 AM
umbcumcp umbcumcp is offline
Mein Auto: 2002 745i
Lucky!!!
Hey my 02 745i trunk does not open nor close automatically....everytime i need to open the trunk...i have to hold it....if i need to use two hands....ouch...i see the stars....so many of them... do i need to get new shock (left and right) or just add some oil?
Old 02-24-2010, 12:27 PM
udoknow udoknow is offline
Mein Auto: 2009 750i
Your control module could be gone. I would check that. It is located in the rear fuse panel. A white box in the upper left.
Old 02-24-2010, 12:57 PM
I hear the noise from the module when i push the red close button. does that mean it works?
Old 02-24-2010, 03:16 PM
spec33 spec33 is online now
Send a message via ICQ to spec33
Mein Auto: 2016 750ix
I have the same problem, where does the fluid go?
2016 750IX Mineral White/Mocca, All options except, LED sunroof, Rear Executive Lounge Seating, Total Chrome Delete.
2015 ML400
Past:
2015 S550 Platinum Silver/Black
2011/750Li Alpine White/Cream, HUD, CWP, Rear LUX Seating, DVD, Sport Pkg, Sat, Side Camera, Top View, Lane change Det, Blind Spot Mon.
08/750Li Orient Blue/Cream on Blk, Conv Pkg, Comfort Access; Cold Weather Package; Prem Sound pkg; LUX Pkg; Ent Pkg; NAV, SAT
04/745i
09 Acura RL
05 Acura RL
04/525i
03 Navigator
Old 02-28-2010, 10:06 AM
Mein Auto: 05 745li
fluid resivoir located under rear deck right side need to pull off panel in rear of trunk. im going to check that today
Old 02-28-2010, 11:32 AM
Fattrain's Avatar
Fattrain Fattrain is offline
Rollin' N' Style
Mein Auto: 2003 745Li
From another thread:
I don't believe in telling people what they need to do, I just share my experience with the same situation.
My trunk was not going down with just one push of the button on the trunklid, I took out the paneling on the passenger side of the trunk and behind there, I found the reservoir that holds the hydraulic fluid for this to work correctly. I proceeded to take off the two nuts that hold it in place, once I was able to do that, I turned the reservoir upside down so it could be filled. You'll see a lot come back into the plastic cap once you turn it upside down but that's fine, there's still room to add plenty more.
Take a small screwdriver and take off the clamp that holds the clear sump so you can proceed to refill it. Once off, fill it with the correct fluid then place the hydrolic motor back on top. At this point, you should have not spilled one drop and it should be filled to the "max" line on the clear piece. Make sure the band is tight before flipping it back upside down again in order to mount it.
Once you finger tighten the 2 nuts/bolts that hold it in place, close the trunk fairly quickly without locking it and then lift it back up manually and do that 2 to 3 times. This is the way in which I bled the system and thoroughly flushes the fluid all the way through the hydraulic pump. This is SUPER IMPORTANT before you have the pump try to close the trunk on it's own.
Once that's done, you should be able to open the trunk all the way, push the button and it should work perfectly. If not, continue to open and close the trunk so it bleeds the setup and gets all the air out.
Hope this helps... I actually found someone on this site who did a write up on this and I couldn't find it so I figured i'd type it out again with what I did. Good luck with the fix.
lendog-
:: Current Rides ::
07' GMC Yukon XL
04' GSX-R 600
98' Mustang
:: Past Rides ::
03' BMW 745Li (Sold)
03' Mustang Cobra (Stolen)
03' Landrover Discovery (Sold)
Old 03-01-2010, 10:57 AM
Mein Auto: E65 745
the guy i got my 7 off just took the fuse out when it stopped lifting on its own ! i did as you described and happy days ! this was over a year ago !
Old 03-01-2010, 11:23 PM
themanagerco88 themanagerco88 is offline
THEMANAGERCO88
Mein Auto: 745i
You can also use ATF. That's what I used, then I found out my left strut or lifter was leaking. Sounds like an easy fix huh? Well no, I had to buy the shock plus the attachments for 3 bills. The dealership here in Hawaii is unforgiving.
Old 03-01-2010, 11:25 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
at least you live in hawaii
'08 BMW 535i - Sport - Sport Trans - JB4 - Catless DPs - Intake - E85 -
'07 SUZUKI GSXR-750 - Gray/Black - Akrapovic Titanium Exhaust -
'03 BMW 525i - Sport -
'98 Ford Expedition - 5.4L - 4WD - Eddie Bauer - 8 seater -
'03 BMW 745i - GONE -
'09 HONDA CBR600RR - GONE -
Old 03-02-2010, 08:35 PM
GKT33's Avatar
GKT33 GKT33 is offline
Send a message via Yahoo to GKT33
Mein Auto: 2002 745LI
lendog-
Thats good info bro, thanks, I didn't know that!!
02 745LI "Titanium Gray Metallic" Heated/Cooled Seats, Soft Close Doors, Comfort Pack..Recent Upgrades..ATL Autosport Drilled/Slotted Rotors with Akenbono Pads..128's(Wac) fitted with 245/35/21-285/30/21 Hankook Ventus...Garax (6000k) HID Headlight Bulbs...MTEC R Dash Angel Eye Bulbs..H&R Springs...JleviSW Carbon Fiber Door Post's...MTEC HID MT402 Cosmos Blue White FLB..BTUM 8000 Bluetooth Upgrade..RAD Wheel Locks..MK 4 DVD Nav upgrade..Iridium plugs
Old 03-03-2010, 09:27 PM
today is the day
I came home early today..decide to fix my trunk...took 15 min to just take out the trim...finally i see the pump you guys talked about...took it out no oil.....not even one drop...went to the CVS..bought ATF (last one)..came home take out the reservior cause i don't have tools to open the damn funny looking bolt...put some oil...put it back all..finally i see my trunk move just little (fisrt time since i bought this car) took out the reservior add more oil...put it back...moved little more...got excited...what the f.. took out reservior again add more oil...my trunk autimatically open just half way...still happy...if i open manually and i press red button it close automaticaly...i spend 3hours for this ....
Now my question is 2003 7 has different hydralic pump system installed cause this one (2002) has too many problems..i heard.. in this case...do i have to replace the pump or need to buy new very expencive shock (this case just left side)??
Help guys..
Old 03-03-2010, 09:44 PM
GKT33's Avatar
lendog-
Help guys..
Did you try manually bleeding the pump?
Old 03-04-2010, 03:03 AM
Mein Auto: E65 745
Help guys..
there should be a + sign on the side of the resevoir ! if the fluid is not above that level (basically full to the brim) you'll get what you describe ! considering you had no function at all , suggests that your going in the right direction don't you think !??
Old 03-13-2010, 11:26 AM
swaynesworld swaynesworld is offline
Swaynesworld
Mein Auto: 750Li
Trunk
For what its worth. Don't forget to check the switch in the middle console, there is a switch located inside if slid over will lock the truck, only the key will open the trunk lid. I made the mistake of switching it to locked and it took two days to figure out what I did!
___________________________________
"Religion sucks"
Mark Driscoll
Old 04-10-2010, 11:11 AM
Kizmo Kizmo is offline
Mein Auto: 2003 745Li; 2000 328Ci
Saw some pictures of this pump:
http://www.xolmatic.com/xprojects/XE65/D_Maletero.htm
but when I went to find mine, it just wasn't there! HELP!
My trunk opens but not all they way, its just short of opening all the way. Where is my pump
Oh, in case it helps, my car is a 2003 745Li
Old 04-10-2010, 11:26 AM
skyhome skyhome is offline
Mein Auto: 2006 750Li
my 2006 750li has the similar issue. the lid opens when I use remote, or button in driver's side but can't close when I push the button again. It makes some noise when the button is pushed but do nothing. took it to the dealer and was told the hydralic pump issue and needs to be replaced.
2006 750Li Titanium Silver Metallic with Crème Beige Nasca Leather Interior.
Old 04-10-2010, 05:26 PM
TX750Li TX750Li is offline
When you say "can't close when I push the button again" are you talking about the red button on the trunk lid or the button on your remote? The remote and dash buttons only open it on an '06, you have to push the red button on the trunk lid to close it.
Old 04-10-2010, 06:39 PM
Fattrain's Avatar
Rollin' N' Style
NOT ALL 02+ 7 SERIES HAVE FLUID/PUMP.
My 03' Li just has Trunk Struts which i just had replaced :-)
It opens by itself (but obviously there is no button to close it, as it only has springs/struts not a motor/pump to pull it back down)
:: Current Rides ::
07' GMC Yukon XL
04' GSX-R 600
98' Mustang
:: Past Rides ::
Old 04-10-2010, 08:31 PM
Good point fattrain. I took a closer look earlier and there are stuts and springs or something like that. How much did that cost you to have them replaced?
Old 04-10-2010, 08:32 PM
Fattrain's Avatar
Rollin' N' Style
My buddy is a bimmer tech and just threw them in for me with no labor and his cost on each strut was like 80$ or something??
:: Current Rides ::
07' GMC Yukon XL
04' GSX-R 600
98' Mustang
:: Past Rides ::
Old 04-20-2010, 01:59 AM
TechGuy TechGuy is offline
Mein Auto: E46 325i
It could be your hall sensor. Have that checked. Is it not bent in any way or pressurised, etc. There are 8 segments through which the process of opening/closing the trunk takes place and these segments are identified by the sensor.
