E36 (1991 - 1999)
Old 03-22-2010, 06:46 PM
Scorpian Scorpian is offline
Mein Auto: 1997 M3
Common central locking problem fix.
So,
If your car is experiencing the following (As i was):
sudden loss of power door locks without warning.
all doors will not lock centrally.
You get odd voltages when you put your meter in the F7 circuit
measuring green red to ground gets you .5 or 1 volt,
This could very well be your problem:
There is a 7 wire connector located under the drivers side carpet (Under the drivers seat). the drivers side tends to get tons of water in it and this connector rusts out. mine was green with corrosion. pull out your seat and remove the necessary trim and lift out your carpet enough so you can see the white cover thing with holes in it and secured to the floor with a nutless bolt. look around for a flat black piece of plastic hanging off of a nutless bolt. snip the wires off and solder them together or pickup a connector.
This Seems to be a a common problem, but is a really easy fix. It was so satisfying to finally hear my power locks whirring away again!
unfortunately though, i seen these two connectors going to a speaker and plugged them in, thinking that i had unpluged them when i removed the trim under the steering wheel.
Now i get the annoying door ding, and a airbag light is on. will unplug them asap. Its driving me nuts...
Hope this helps people! I searched all over this board and counldnt find answers...
Iab
Old 04-21-2010, 10:59 AM
anuparmi anuparmi is offline
Mein Auto: 328ic
How the heck do i remove the driver's seat???
Old 04-21-2010, 11:09 AM
mksu19's Avatar
mksu19 mksu19 is offline
Yes, they're real!!!
Send a message via AIM to mksu19 Send a message via Yahoo to mksu19 Send a message via Skype™ to mksu19
Mein Auto: 04 325i / 05 X3 2.5l
Originally Posted by Scorpian View Post
So,
Iab
Any one of these should do:
Originally Posted by bimmerbarbie View Post
...Not everyone can be as beautiful as Mona and me...
Mona B.
Old 04-21-2010, 11:19 AM
E36youngster's Avatar
E36youngster E36youngster is offline
blank
Mein Auto: 07 e92 335i
Old 04-21-2010, 11:21 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
OP, great write up, thank you.
Mona, :shakes head:
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 04-21-2010, 11:22 AM
Zodiac Zodiac is offline
Mein Auto: e36 328is
lmfao
Mona FTW
Old 04-21-2010, 03:01 PM
haydar1984's Avatar
haydar1984 haydar1984 is offline
bimmer 4 life
Mein Auto: bmw 325i 1992 sedan
Great post thanks , I would like to add that some times my central looking and alarm system get crazy and I only disconnect and reconnect the battery and it goes back to normal...
_____________________________
