e39 BMW 528i ABS Control Module DIY and Case Study - Bimmerfest - BMW Forums
Old 04-23-2010, 07:43 AM
BAMF BAMF is offline
Mein Auto: 528i
Post e39 BMW 528i ABS Control Module DIY and Case Study
Vehicle: 2000 BMW 528i with DSC
Symptoms: After the car heated up to operating temperature the ABS light, Brake light, Check Engine light would turn on. In addition the speedometer would stop working, and any display or indicator requiring speedometer functionality also stopped working, including trip meter, odometer, fuel efficiency meter, etc.
Local independent repair shop with good reputation and award winning service determined through diagnostics that it was the ABS Control Module, after having replaced the rear speed sensor. Quoted a price of $1,600 to replace and reprogram Bosch 5.7 ABS Control Module.
After brief research found that there were choices and alternatives.
1. Buy a used control module for around $375, some are available with a 6 month warranty. The service shop agreed to install used part but it would have to be reprogrammed by BMW for $129. Total cost $504. BMW tech said that ABS Control module cannot be reprogrammed, they can only be programmed once as a new module.
Can anyone corroborate this? Could Bosch really be that stupid/greedy as to use a chip that can only be programmed once? If you know anything please provide details.
By the way if choose this route make sure you get the part number off the sticker on the bottom of the existing Control Module as the part numbers must be the same.
2. Have the existing control module rebuilt by one of the automotive electronics rebuilding services. Costs around $300-$400 including shipping back and forth. Based on conversation with a very helpful lady at http://www.modulemaster.com they can be rebuilt and actually end up being better quality than the original.
She indicated that there are some that are damaged beyond repair and that if that is the case they will sell you another rebuilt one for an additional $75 if they have any in stock. Module Master offers a 5 year warranty for the rebuilt one.
3. Buy a brand new one from any number of online parts shops for around $450-$550. These usually come with a 1 year warranty.
I'm going with option 2 to have it rebuilt because there is an 85% chance that they can rebuild it better than before, and I plan on keeping this car for a while and a 5 year warranty on this part sounds good.
The reason it went bad in the first place is because the internal wiring seems to be too thin or of poor quality. After repeated heating and cooling shorts out.
In any event for $1,600 one can buy one hell of a laptop, can't bring myself to spend that kind of money on a low level electronic component.
Heading to the garage to remove the control module from the pump unit. Will add more later.
Removing ABS Control Module:
The control module is located on the passenger side. There is a metallic box, which is the pump, with tubes coming out of it. The control module is attached to the front of the pump.
The first step is to remove the connector. The image above shows the connector with the locking mechanism in the closed position. The image below shows the connector with the locking mechanism in the open position. To unlock the connector gently slide the locking mechanism toward the engine.
Carefully lift the connector straight up to disconnect it from the control module. The contact points are very thin pins and you'll want to make sure not to bend them.
Next use a #20 torx tip to remove the six bolts that mount the control module onto the pump. Once the bolts are removed, carefully slide the control module towards the front of the car. The arrows in the picture below give a reference of where the bolts are located. They were pretty easy to access.
Cover the surface where the control module was mounted with foil. I also covered the connector to prevent dirt from getting in there as well.
The image below shows what the control module looks like inside. Pretty nifty piece of work, and very delicate so handle with care.
To ship it I imagine shipping an egg. I lightly put some tape over the cylinders from one side of the frame to the other. The cylinders have some wobble and the tape should keep them stable during shipping.
Next i wrapped the whole thing in aluminum foil as instructed by rebuilding service. Wrapped the whole thing in bubble wrap and used a large enough box so there would be at least 4 inches of packing peanuts surrounding it.
And away it goes.
It will be a few days before rebuilding service gets it. More later.
Old 04-23-2010, 08:58 AM
cn90 cn90 is offline
Check bba-reman.com first.
Old 04-23-2010, 10:21 AM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
If you want to go with option 3 I sell brand new bosch modules and will give you the best price possible. That really is the easiest way to get this repair right the first time. New module, code to car, drive away happy.
Old 04-23-2010, 11:17 AM
Mein Auto: 528i
Will keep that in mind
I appreciate the offer and it may just come to that.
Old 05-15-2010, 08:26 AM
I just saw this while looking up BMW Acronyms to add to the list.
Nice. Very nice. Simple. Easy to follow. And with annotated pictures.
Here's a cross reference for those of you following this thread to fix your ABS.
Old 05-15-2010, 10:16 PM
Rgol Rgol is offline
Mein Auto: '09 335cic M-Sport
Hd same problem a few months ago. Took it off on Monday. Sent it to BBA and got it back Friday. Put it back on. No problems. Total cost = $350.
2009 335cic M-Sport
RIP - 1999 Dinan 5 | 528is 5-Speed
Old 05-17-2010, 06:26 AM
Mein Auto: 528i
Result of the ABS repair attempt
Well, got the word last week that my ABS module gave up the ghost. In the process of repair it showed error code 54 which is a fatal non-repairable error. The repair company tried their best.
Doing a little digging I found a number of online stores selling rebuilt ABS control modules and went ahead and ordered one from PelicanParts.com - should be delivered tomorrow.
Old 09-14-2010, 05:43 AM
Jaystyles's Avatar
Jaystyles Jaystyles is offline
Mein Auto: 545i Sport
Mr E39 528i Sport
Has anyone heard or dealt with a company called cheapabs.com they claim to rebuilt all abs modules for $150 and they give a lifetime warranty. Is this too good to be true or what please help. Thanks.
Old 09-14-2010, 06:09 AM
Mein Auto: 528i
It depends
They can be rebuilt depending on the error code. Some error codes are fatal and cannot be rebuilt, that is what happened to mine. The company I dealt with did not charge me to try and rebuild it, they would only charge me if the rebuild was successful. All it cost me was the shipping cost to get my unit to them.
If they ask for the money up front I would say "no thank you".
Old 09-14-2010, 06:26 AM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
BAMF:
What was your final outcome since May?
Was the Pelicanparts.com remanufactured ABS module + shipping + coding cheaper than the new one form eac and coding?
I only ask to help others searching.
FWIW: I sent mine to modulemasters ~ 2+ years ago and had it rebuilt for around $330.
No problems/issues to date.
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 09-14-2010, 01:35 PM
Mein Auto: 528i
Originally Posted by Jase007 View Post
BAMF:
Not sure what EAC charges for a new on, but I paid $450 for the rebuilt from Pelican, and the dealership charged me $99 to code it. Since then no problems whatsoever.
I sent mine to modulemasters too to try and repair mine - great folks. The woman I spoke to there had the patience of a saint. They tried their best best, but the error code they found was a fatal one.
Old 01-08-2015, 01:30 PM
JeffSinNHUSA JeffSinNHUSA is offline
Mein Auto: BMW 525I
I used cheapabs.com. They charged $139 + S&H and it works great. The local garage was going to charge me $2,275!
528i abs control module
