E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Five Speed Reverse Gear
Does anyone here know if a 328's manual transmission should require additional force (an aggressive tapping or smacking instead of gently gliding to the left) to shift into reverse.
I'm looking at a used 1997 328is with a manual transmission that seems to only have that one issue. I brought a relative of mine with who ran it through all of its gears and said everything else checked out. I thought I should play it safe and find out if that is standard operation. |
It takes some force to get it into reverse, but you shouldn't need to smack it.
You shouldn't need to smack your stick...just push it hard...
The trick is to put the trans into any forward gear *before* engaging reverse....if that doesn`t help, then the reverse idler gear is probably very worn.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
+1 If i don't end up doing as bob has stated it sounds like all my gears are grinding! horrrible, Unless it is warm and i have been running it most the day. Need a bit of force but shouldn't need to put your shoulders into it ;P
[ "Straight roads are for fast cars, turns are for fast drivers." -Colin McRae Owned/own: 1995 M3-cosmos black(E36) 1998 528I-schwartz black(E39) 1999 328IS-steel blue(E36) 1995 540IA-orient blue(E34) 5/6 speed swap soon. |
| Tags |
| 328, manual, transmission |
