Old 09-14-2003, 06:50 PM
eVal's Avatar
eVal eVal is offline
Mein Auto: 2002 M Coupe & 05 MCS
Exclamation Help - installing alarm and have a question
Can someone tell me where the siren connector is by the brake master cylinder?
Loki is in the middle of his install and called me to seek help
Thanks!
Old 09-14-2003, 07:00 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Thanks!
It's a two pin gray connector located between the fuse box and master cylinder reservoir. The connector has a brown and dark blue wire going to it.
Old 09-14-2003, 07:30 PM
eVal's Avatar
Well, after much searching he found it hidden down near the firewall - was a real pain to get out.
The description really helped - Thanks so much for answering, youre the best!
Old 09-14-2003, 08:34 PM
loki loki is offline
Mein Auto: KTM Duke II
Hi Ron,
Thanks for the help, I was outside trying to install the alarm while eVal posted help .
One more question for you, I can't seem to find the hood connector pin in the glove box area. The illustration that came with the alarm kit shows it coming from the front top of the glove box but I can't seem to find it anywhere! Any ideas what and where to look for?
TIA!
Old 09-14-2003, 09:03 PM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by loki
Hi Ron,
TIA!
It's taped to the vehicle side alarm connector harness. Feel for the bump. Have to cut some tape to find it. Violet/green/yellow wire going to the single mating pin on the alarm harness that connects the car connector to the alarm connector.
http://www.unofficialbmw.com/images/alarm4.gif
