Home made CAI (Possibly better then Dinan). Pics and details inside. - Bimmerfest - BMW Forums
Closed Thread
Old 04-30-2010, 08:25 PM
540ig5's Avatar
540ig5 540ig5 is offline
Mein Auto: new york metro area
Four days ago I noticed that the rubber intake fitting that goes over the throttle body was ripped. To fix the issue I went down to my local performance shop to see if I can find a rubber/silicone coupling to fix the problem. While there I got to talking about a CAI and discovered that the shop had something I was looking for 3 years (I know it sounds too dramatic). It was a very high quality flex pipe. It was made with 3 layers of silicone and layers of nylon rope and metal coil. Really high quality stuff. Seeing this made me want to expand my project from fixing the ripped fitting to installing a full CAI, a real CAI, the kind I always envisioned, not the kind that mounts the filter under the hood. So with parts in hand I set off to undertake what I thought would be a relatively straight forward project.
The first surprise came when after taking off stock air box, the bumper and headlights. I think the word Iím looking for is shocked to describe the size, shape and general setup of the stock intake plumbing. Not only was the intake hole tiny, it faced towards the rear of the car and sucked in air right in front of the auxiliary fan. (So if the fan is on, it basically sucks air out of the intake.) I guess it was all made that way to make the 4.4L V8 quiet enough for soccer moms, but for me it was horrible. See pictures below.
Then using the flex pipe and an Autozone cone filter I went to work. For a rather large sedan, itís surprising how very very little room there is under the hood for any kind of modifications. There is literally just 1 or 2 millimeters of extra space for components (sometimes zero). I had to fight through the project the entire way. Starting from making sure the fan blades donít hit the MAF/Intake piping, to going crazy trying to fit the flex pipe between the stupid secondary air pump, the bumper and my fog lights, to finally finding a suitable place for the filter. It took me a total of 8 hours to put anything together, but man am I glad I did it. The car sounds absolutely amazing. I will try to post a sound bite later.
Anyways, enough talk, here are all the pics.
ID:	228281   Click image for larger version
ID:	228282   Click image for larger version
ID:	228283   Click image for larger version
ID:	228284   Click image for larger version
ID:	228286   Click image for larger version
ID:	228287   Click image for larger version
Old 04-30-2010, 08:27 PM
540ig5's Avatar
CAI Pis. (Don't mind the bumper, had a run in with a big rock while playing in the snow)
ID:	228289   Click image for larger version
ID:	228290   Click image for larger version
ID:	228291   Click image for larger version
ID:	228292   Click image for larger version
ID:	228294   Click image for larger version
Old 04-30-2010, 08:45 PM
pj- pj- is offline
Mein Auto: 02 530i
Nice cold water intake you've got there..
Sometimes BMW does things for a reason. I'd have researched why the stock intake was designed that way before I went and destroyed my car.
Old 04-30-2010, 09:05 PM
nike001 nike001 is offline
Mein Auto: 04 330 ZHP
How do you know how this is better than Dinan? Just on the sound alone? From other people installing CAI's on their cars, they have shown to have almost 0 performance gains. The only thing that comes from it is the sound.. I guess if the sound was what you're looking for than more power to you, but i would have fixed that torn up bumper and removed those eyelids before i did any other modifications
EDIT: BMW has done these sort of things for the air getting to the engine for a reason, no matter how long or messed up you find it to be..it still works the way it should. hence why putting a cai on it does almost nothing except make some noise and break your wallet when you could put that towards a new bumper.
330i ZHP 6MT | H&R Sport Cup | BMW Performance | OE Clears | Coby Wheel
Old 04-30-2010, 09:31 PM
540ig5's Avatar
Originally Posted by pj- View Post
Nice cold water intake you've got there...
That's just silly
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
That's some major ghetto action going on right there. I give you props for having the balls to post this however.
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
andyffer andyffer is offline
WTB - your E39 M5
Send a message via AIM to andyffer
Mein Auto: 02 530i, 09 335d
what the hell did you do lol
Dont you think you could have put that money towards fixing the bumper?
Unencumbered by the thought process
If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain.
Old 04-30-2010, 09:32 PM
540ig5's Avatar
P.S. The whole thing cost about $80 buks
Old 04-30-2010, 09:35 PM
540ig5's Avatar
I got to give you that one. I forgot the kind of people that are on the BMW forums, but I'm very quickly being reminded of it. Good thing the owner manual did not say "Jump of a bridge", if it did, most of you people would not be here.
Old 04-30-2010, 09:36 PM
pj- pj- is offline
Mein Auto: 02 530i
I only have a basic understanding of why CAI is mostly worthless, but the gist is that more air is not necessarily a good thing. For any given throttle position except wide open throttle, the engine only needs a certain amount of air, and the stock system is more than adequate to provide that. At wide open throttle, a CAI probably lets the engine suck in more air, but at what cost? And how much are you actually gaining, other than noise? A couple HP at most?
Originally Posted by 540ig5 View Post
That's just silly
No, what's silly is what you did to that car. You don't think you massively increased the risk of sucking up water with the filter being that low? What happens if you hit a puddle, or drive behind someone who is kicking up heavy mist? What about in the winter, not worried about snow? Eventually the filter will get saturated enough that it starts pulling in water, or during winter it could become encrusted with ice and choke the engine.
I'm all for DIY that improves a car in one way or another, but there is nothing good about what you've done here. I just hope there's enough backlash in this thread to prevent any hapless googler from trying it themselves.
Old 04-30-2010, 09:37 PM
540ig5's Avatar
And why would I want to spend money on that, so I can look pretty in my BMW? That's not why I have this car. What it looks like is important, but that's the last thing on my to do list.
Old 04-30-2010, 09:40 PM
540ig5's Avatar
Originally Posted by nike001 View Post
How do you know how this is better than Dinan? .
I don't, that's why i said possibly. The only reason I even mentioned it is cuz with my set up the filter is getting "fresher" air, and more of it. (compared to the Dinan one)
Old 04-30-2010, 09:41 PM
WTB - your E39 M5
ahh I see. So thats why you have the m bumper, roof spoiler, trunk spoiler, etc.
Get the vid of how it sounds, Im sure its better than stock. even removing the air horn was a good little improvement
Old 04-30-2010, 09:50 PM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
Poor 540i. Missing front bumper paint, engine covers, valve cover covers, hole in grill, jimmy-rigged intake system from fast and furious on the budget....it does appear your priorities are slightly off......
BTW to even state "possibly better than Dinan" is just asenine! Your 30min cold air with an autozone filter vs hundreds of hours of Dinan R&D.....hmmm.
Andyffer, stop encouraging.....lol
Old 04-30-2010, 09:53 PM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Man looking closer at your pics this car needs a lot of work. I mean wow. I'd stop spending $80 to piece together a ghetto CAI and start saving up for stuff like an engine cover, paint for your headlight trim, goo be gone after yanking off those cheesy eyelids, replacement brake duct intake tubing, bumper paint, I could go on but you get the gist. Goodluck my friend.
WTB - your E39 M5
Yeah I just looked through all the pics.
Wow.
Old 04-30-2010, 09:56 PM
davenotize's Avatar
davenotize davenotize is offline
03 530 S/P for sale!!
Mein Auto: 03 bmw 530s/p 02 bmw 525
ill give you the benefit of the doubt, would i attempt to do that stunt? i highly doubt it. this DIY is like spray painting your car to cover some scratches.
Old 04-30-2010, 09:57 PM
WTB - your E39 M5
papers towels and painters tape FTW
E39er09 E39er09 is offline
Mein Auto: E39
OP do you plan on removing it when it rains, if not, you're looking for a whole mess of trouble. It is unprotected from the elements sitting in that position. That is the reason why most aftermarket manufactures of CAI design them for under the hood to save them from liability of naive enthusiast.
Old 04-30-2010, 10:00 PM
WTB - your E39 M5
shhh
Old 04-30-2010, 10:06 PM
540ig5's Avatar
Can somebody actually say something constructive here?
Old 04-30-2010, 10:08 PM
540ig5's Avatar
You're saying that if rain get's on the filter I will have issues?
^^^ you actually think you are going to get constructive comments from your setup?
Sure, here you go. Remove what you have done and put it back to stock. Otherwise I forsee a seized engine in your future.
Old 04-30-2010, 10:09 PM
WTB - your E39 M5
we have. this is for your benefit
I am looking forward to hearing it
  #25
Old 04-30-2010, 10:10 PM
540ig5's Avatar
Man you guys are impossible, it's gonna take me 4 days just to reply back to all the irrelevant nonsense you guys are writing.
YES believe it or not, paper towers and painters tape, it's a good way to protect your bulbs while your headlights are out, or is not BMW approved?
Closed Thread
