M Coupe Stereo help needed please
Ahhh....what a mess I have made!
System I am attempting to install: (keeping stock head unit) Interfire 5 ch amp Interfire Line out converters (for RCAs) 5.25" MB Quart PSC 213 components for the front 5.25" infiniti Kappas for the rear roof JL 6W0 sub in the stock enclosure +tons of dynamat & wiring I was able to find the wiring diagram somewhere on this forum, and that certainly helped...but there is one wire that remains unaccounted for: the front door tweeter wires! I have the rear of the car and the door panels removed. What I have noticed is that in the M coupe's door panel, there are two speakers; one tweeter, and one mid/tweet speaker. I decided to mount my tweeter in the stock location for a clean install. It was too big to be mounted in place of the tweeter, so I removed the mid/tweet and constructed a metal piece to hold it in place. The problem is that I don't know where I can tap that wire in the amp harness to connect to the output of MB Quart crossover. I think that the each of the front channels must be spliced into on the front of the car, then sent from that one channel out to the kick panel mid, and both of the speakers in the door. I should probably run new wire from the rear of the car (at the amp/crossover location) to the kickpanels and tweets, but I am trying to find another way...anyone have an idea of what I can do here? Thanks in advance! -Bryon
Bryon 2003 Jet black/imola SMG M3 |
had similer issue
The tweeter wires are in the J2 connector pins 8 9 21 22 23 24 25 26 I made connectors from electronic parts pics is needed I am in portland as well and could help it needed |
Thanks b3.0
I have the car down at Autohaus Bayern right now getting the wiring figured out. They cut me a really good deal on labor, and freed up some extra time for me to take care of a few things today. That damn j2 pin eh? The j2 connector had the lines going into the amp from the head unit (in all of the diagrams that I have found), and what I needed to run from my crossovers in the rear were the lines coming out from the amp to the speakers.
roadster audio
Daniel 2002 M roadster |
I will try to post the wiring diagram I have. I got it from a web site, can't remember who to credit.
Later tonight form the other computer, did not have it yesterday b |
Thanks for your help everyone.
I am all wired up! There is only one problem though...there is some sort of fluttering sound coming from the JL sub in the stock box. It just doesn't sound as clean as I had hoped. I wonder if this is because the box is ported, and JL recommends a sealed encloser for this sub?
Did you fill the box with polyfil foam? Did you cover it with dynamat?
Jon Maddux 10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe |
Regarding the polyfil, how much did you use? I bought a two lb bag of it, and it only took a few handfuls to have the box loosely filled.
Also, you have an email from Andy about some leather stuff.. Was it you that made the leather amp cover for the rear hatch of the coupe? Care to make another one? thanks Bryon
I did the leather work on this amp cover: But Shawn did the wood work.
Yes, that is the one that I am referring to. That is what I am wanting to do, I think...So would you be able to do something like this again? How thick, and what type of wood did you use?
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
JL Sub problem is fixed!
Here is what I did: The wiring going to the stock sub box is channeled through a divet around the edge of the speaker, and is surrounded by some foam tape stuff. I peeled back this foam, and sealed up the divet and around the wires with black hot glue. I then proceded to seal around the outside of the MDF ring, and fill a few extra holes on the outside of the ring with the hot glue. This resulted in eliminating about 90% of adverse noise/flutter. I then plugged the factory port, and 100% of the flutter is gone. I am left with nice clean bass that is free from any offending noises. As far as the floor goes, I decided to build a false floor constructed out of laminated peg board (the stuff you hang tools and things from in the garage). In between the the amp and crossovers are 3" styrofoam strips about 3" wide in aggregate dimmensions providing a large amount of structural stability. The holes in the peg board allow the heat from the amp to escape. I covered the board with my ///M mat on the rear hatch, and have absoultely no heat issues! I will be posting pics probably tomorrow or the next day. Thanks for all of your suggestions and help!
