BMW-specific E39 acronyms (list and definition)
BMW E39 glossary of terms, abbreviations, acronyms, slang, and oft-used brand names:
(AFAIK, this is the most complete list on the planet; it took many hours to compile & edit.) (Please correct where needed - but limit to technical parts terms; no jokes please.) ---------------------------------------------------------------------- BMW = Bavarian Motor Works aka Bayerische Motoren Werke (in German) BMWNA = BMW of North America, LLC (a wholly owned subsidiaries of BMWAG) BMWAG = The parent BMW company in Germany Beemer = slang for the BMW motorcycle (not the car) Bimmer = slang for the BMW car (not the bike) DIY = Do It Yourself (as opposed to the Indy or Stealer) Indy = Independent BMW specialist (versus the BMW-dependent dealers) Stealer = BMW dealership, affectionately called the stealership Realoem = BMW parts diagram and nominal prices (www.realoem.com) Roundel = BMW symbol (badge/decal/ornament/emblem/logo) also a magazine ---------------------------------------------------------------------- Aftermarket = a copy of the OE part (should meet OE specifications) DO = dealer only (apparently some parts are restricted to the dealership) OE = original equipment (the exact replacement part that the dealer sells) OEM = same OE manufacturer but could be differently branded, boxed, etc. OES = original equipment supplier (meets spec, can be multiple brands) ---------------------------------------------------------------------- CA = client advisor (salesman) (see also comfort access) PO = previous owner (also sometimes used for "angry" or "not happy") SA = service advisor (serviceman) (see also Sonderausstattung) OP = Original Poster ---------------------------------------------------------------------- AUF = "of" (preposition) (from RealOEM, e.g., in cupholder AUF 0017969) EBA = Einbauanleitung (from RealOEM, e.g., in cupholder EBA 9789813) Einbauanleitung = Options Installation Manual (as specified in Realoem) Entwurfen 39 = project 39, aka E39 ETK = Elektronikteilkatalog (BMW part numbers & descriptions) ETM = BMW electrical troubleshooting manual KDS = Komputer Service Desk (defect codes & warranty flat rate labor units) KSD = BMW error kodes & man hours per job (shop rate) PBS = Parts Bulletin System (in TIS) RA = Repair instructions (in TIS) SI = Service Information (in TIS) (aka Service Interval) SIB = Service Information Bulletin (BMWNA) TD = technical data (in TIS) (also engine speed signal) TDD = Technical Documentation Disk TEPC = Nominal prices for parts in the ETK TIS = Technical Information System (aka Technische Information System) TSB = Technical Service Bulletin ---------------------------------------------------------------------- CSL = Coupe Sport Lightweight ECE = European community edition LEV = Low Emissions Vehicle M52 = Inline 6 cyl single vanos E39 engine 2.0L-3.2L (1994-2000) M54 = Inline 6 cyl double-vanos E39 engine 2.2L-3.0L (2001-2003) M Technic = an options package (as in M technic Emblem) NG = New Generation (as in N73 engine) PP = Premium Package (multiple definitions) SAV = Sport Activity Vehicle Shadowline = matte black (SA339) or high-gloss black (SA760) trim option SE = Special Equipment SP = Sport Package (multiple definitions) TLEV = Transitional Low Emission Vehicle ZHP = BMW Performance Package (Available on US-Market 330i/Ci/Cic Only) ZPP = Premium Package ZSP = Sports Package 4WD = Four Wheel Drive (aka FWD) ---------------------------------------------------------------------- ///d = diesel (where the slashes indicate a model number, e.g., 528td) ///e = economy (e.g., BMW 528e) ///h = hydrogen (where the slashes indicate a model number) ///i = fuel injected (where the slashes indicate a model number, e.g., 525i) ///M = motosport (where the slashes indicate a model number) ///t = hatchback (where the slashes indicate a model number, e.g., 528td) ///T = touring (where the slashes indicate a model number) ---------------------------------------------------------------------- BMW-related abbreviations, acronyms, and definitions: ---------------------------------------------------------------------- A = "out" (Aus) (also = processed vehicle speed signal) A = processed vehicle speed signal (also = "out", Aus) AB = Airbag ABL = Brake system warning Lamp (2 colors) ABS = Anti Lock Braking System AC = Air Conditioning (aka A/C) A/C = Air Conditioning (aka AC) ACC = Active Cruise Control ACS = Active Comfort Seats (also AC Schnitzer) A/D = Analog/Digital ADB = Automatic Differential Braking ADB(X) = Automatic Differential Braking ADS = Engine Intake Air Control (also Aux Throttle Position Motor) ADV = windshield wiper pressure control AE Projectors = Angel Eyes, projector light distribution halogen lamp system AEGS = Automatic Electronic Gearbox Control (also EGS) AFM = Air Flow Meter AFR = Air to Fuel Ratio AG = Automatic Gearbox (transmission) AGD = suction silencer AGR = emission reduction AGS = Adaptive transmission control AHK = Active rear-axle Kinematics (multiple definitions) AHK = trailer hitch (multiple definitions) AHM = trailer Module (not for US models) AHPS = Advanced HPS AIC = Automatic Interval Control (rain sensor) AKF = activated carbon canister AKS = Active head restraint (also a pressure regulating device ) AKS = pressure regulating device (also Active Head Restraint) ALC = Automatic Light Control ALR = Automatic Lamp Range Adjustment AMM = Air Mass Meter AMP = radio system Amplifier A Pillar = The front-most roof support (as in A pillar, B pillar, C pillar) ARI = car radio information system ARS = Active Roll Stabalization ASC-EZA = ASC w/ engine timing and injection intervention ASC = Automatic stability control (most common of multiple definitions) ASC = All Season traction (multiple definitions) ASC = Anti-Skid control (multiple definitions) ASC+T = ASC + Traction control ASK = Audio System Controller (aka audio systme kontroller) ASR = self starter block relay AST = Automatic Slip control (marketing term) AT = Antenna (multiple definitions) AT = Automatic Transmission (aka A/T) (multiple definitions) AT = remanufactured part (multiple definitions) ATF = Automatic Transmission Fluid (see DEXRON III) ATL = exhaust gas turbo charger AUC = Automatic Air Recirculation AUT = Automatic transmission AVT = Antenna amplifier Tuner AWD = All Wheel Drive AZD = tightening torque specifications (in TIS) ---------------------------------------------------------------------- B = Benzene (gasoline contains aromatics and alkenes & alkynes) BAT = Battery BBK = Big Brake Kit BC = Board Computer BC1 = Body Controller 1 Bentley = most common publisher for BMW repair manuals BL = Brake Light BLS = Brake Light Switch Bluetooth = A wireless interconnection technology BMBT = Board Monitor BMW = Bayerische Motoren Werke B Pillar = The second-from-front roof support (usually the middle pillar) BS = Block Diagram (aka block schematic) BST = Battery Safety Terminal BUNA = Brittle OEM material for VANOS seals (see Viton) BVA = Brake pad wear indicator BZM = Center Consol Control Center BZMF = center console control center, rear ---------------------------------------------------------------------- CA = Comfort Access CAB = Control Arm Bushing CAI = Cold Air Intake CAN-Bus = Controller Area Network (bus) CAN = Controller Area Network (Multiple ECU Controller) CANH-Bus = CAN bus, High CANL-Bus = CAN bus, Low CANP = fuel tank ventilation valve CAS = Car Access System (multiple definitions) CAS = Car Activation System (multiple definitions) CAT = Catalytic Converter (aka cats) CBC = Corner Braking Control CBS = Condition Based Service CC = Check control CCA = battery cold cranking amps - the current available in cold conditions CCFL = Cold Cathode Fluorescent Lighting (headlights) CCM = Check Control Module CCV = Crankcase vent or (incorrectly) Clutch Control Valve (should be CDV) CD = Control Display CDC = Compact Disk Changer CDS = CD player CDV = Clutch Delay Valve (prevents dumping of the clutch) CEL = Celsius (multiple definitions) CEL = check engine light (see MIL & SES) Ceramic = an almost meaningless term for brake pad material (versus organic) CF = Carbon Fiber CIM = Chassis Integration Module CKP = crankshaft position sensor (this is the correct abbreviation) CMP = camshaft position sensor (this is the correct abbreviation) CO = Carbon monoxide COMBI = Electronic Instrument Cluster CON = Controller C Pillar = The third-from-front roof support (usually the rear pillar) CPS = colloquial for crankshaft & camshaft position sensors (see CKP & CMP) CU = Copper CVM = Convertible Top Module CVT = Constantly Variable Transmission CVV = crankcase ventilation valve (sometimes colloqually called CCV or PCV) CW = drag coefficient CWP = Cold Weather Package ---------------------------------------------------------------------- D-Bus = Diagnosis Bus (same as TXD) D1 = Xenon light / gas discharge DAE = Daytime Angel Eyes DBC = Dynamic Brake Control DBS = Dynamic Braking System DCS = Dealer Communication System DD = Daily Driver (multiple definitions) DD = Dynamic motor Drive (multiple definitions) DDE = Daytime Demon Eyes (multiple definitions) DDE = Digital Diesel Electronics, ECU for Diesel Engine (multiple definitions) DE = Diagnostic Unit DEXRON III = General Motors certification of quality for ATF Diagnostic Connector = Where scanners plug into DICE = a company that manufactures an iPod interface to the BMW radio (see also Intravee) DIN = German Industrial Standards (similar to SAE in the USA) DIS = Diagnosis and Information System (multiple definitions) DIS = Direct Ignition System (multiple definitions) DISA = Differential Air Intake Control (multiple definitions) DISA = intake runner length tuning mechanism (multiple definitions) DIVA = continuously variable length intake runners DIY = Do It Yourself or (Do-it-yourself when used as an adjective) DK = Throttle Housing & valve DKB = throttle w/ brake intervention DKE = Throttle Increase DKI = Throttle Position DKR = throttle reduction DKT = throttle position signal DKV = preset throttle position value DM-TL = Diagnostic Module Tank Leakage DME = Digital Motor Electronics (gasoline engine control block) (see ECU) DOHC = Double Over Head Camshafts DRL = Daytime Running Lamps DS = gasket set DSC = Dynamic Stability Control (in all 540s as of 1998, all models after 2001) DSP = Digital Sound Processing DTC = Dynamic Traction Control (multiple definitions) DTC = SAE Diagnostic Trouble Code (multiple definitions) DTM = Deutsche Tourenwagen Meisterchaft DWA = Theft Deterrent (Alarm) System DWS = Druckwarnsystem (see TPMS, TPC, TPM, & TPW) DZM = revolution counter ---------------------------------------------------------------------- E-KAT = Electrically heated catalytic converter E = "in" (Ein) (also sometimes used for communications errors in code readers) EAM = Electrostatic Airflow Meter EBA = EinBau Anleitung (i.e., Installation Instructions) EBA = installation instructions EBV = Electronic Brake force proportioning ECM = Engine Control Module (SAE term) ECO = Controller for I-Drive system ECU = Electronic Control Unit (see DME) EDC-K = Electronic Dampening Control Continuous EDC = Electronic Dampening Control or Electronic Damper Control EDFC = Electronic Dampening Force Controller EDIS = Electronic Distributorless Ignition System EDK = Electronic throttle valve EDR = Electronic throttle control EDS = pressure regulator EFH = Electric window lifter EGR = Exhaust Gas Recirculation (to reduce temperatures & therefore emissions) EGS = Electronic Automatic Transmission Control EH = Electronic Hydraulic EHC = Electronic Height Control EKAT = Electrically heated catalytic convertor EKM = Electronic body Module EKP = Electronic Fuel Pump ELV = Electronic Steering Lock EM = Electro-Mechanical EME = Electro-Mechanical Emergency Brake EMF = Electro-Mechanical parking brake EML = Electronic Motor Load regulation (aka Electronic Throttle Control) EMV = Electro-Magnetic sensitivity EO = Component Location EPC = Electronic Parts Catalog (related to the ETK) EPROM = Erasable Programmable Read Only chip Memory ESC = Electronic Stability Control, a lateral slippage control system (see ESP) ESP = Elektronisches Stabilitätsprogramm, Electronic Stability Program (see ESC) ESS = Electronic anti-theft device ETM = Electrical Troubleshooting Manual EV = injection Valve EVAP = relates to fuel vapor recovery EWS = Electronic Drive away protection (alarm system) EZA = aka ASC-EZA ---------------------------------------------------------------------- Fault Code = a "code" stored in the DME memory bank FB = Function Description FBC = Fading Brake Control FBD = remote control services FBZV = Radio Frequency Locking System FGR = Vehicle Speed Control (Cruise Control) FH = window lifter FHK = rear Heater/ air conditioner FI = Forced induction FLC = automatic Light Control FRU = Flat Rate Unit FS = Crash Sensor FSR = A/C and heat fan speed-control final-stage resistor (aka FSU) FSU = A/C and heat fan speed-control final-sage unit (aka FSR) FTL = For The Loss FTW = For The Win Fuel Trim = adjustments to maintain proper air fuel ratio FWD = Front Wheel Drive FZD = Funktionszentrum Dach (Roof Switch Unit, e.g., bluetooth) FZV = central lock receiver ---------------------------------------------------------------------- GAL = Speed Dependent Sound Volume GM = General Module GMIII = General module III GMR = Yaw Moment Control GPS = Global Positioning System GRII = Cruise Control GRS = rotation Rate Sensor GS = Belt Tensioner GWK = torque converter lock-up control ---------------------------------------------------------------------- H = "rear" (Hinten) H/K = Harmon/Kardon H2 = Xenon headlights HA = rear Axle HC = Hydro Carbon HD = Heavy Duty HDC = Hill Descent Control HFM = Hot Film Air Mass Meter HG = manual Gearbox (transmission) HID = Xenon lights (high-intensity discharge lamps) HKL = Hydraulic trunk lid Lift HLM = Hot Wire Air Mass Meter HM = Hotwire Meter HPFP = high-pressure fuel pump (despite many joke definitions otherwise) HPS = Head Protection System HR = Heater control HUD = Head Up Display HVA = Hydraulic Valve Adjuster Hz = Hertz (Cycle) ---------------------------------------------------------------------- I-Bus = Information Bus IB = Interior lighting Control Signal ICM = Idle Control Module ICV = Idle Control Valve IHKA = Automatic Heating and air conditioning IHKAF = IHKA w/ micro filter IHKR = Regulated Heating and air conditioning IHKRF = IHKR w/ micro filter IHKS = Standard Heating and air conditioning IHPD = Internal High Pressure Deformation IHR = Integrated Heater control IKE = Instrument Cluster Electronics ILH = Interior Lighting, rear ILV = Interior Lighting, front IMS = Instant Mobility System Intravee = an iPod interface to the BMW radio (see also Intravee) IR = Infrared IRS = Infrared Locking System ISC = Idle Speed Control ISIS = Intelligent Safety Integration System ISN = Individual Serial Number ISOFIX = standardized mounts for child restraints ITB = Individual Throttle Body ITS = head airbag assembly/ Inflatable Tubular Structure IVM = Integrated power supply Module ---------------------------------------------------------------------- JC Chip = Jim Conforti chip, remaps fuel and spark ---------------------------------------------------------------------- K-Bus = Body Bus (Karosserie) KAT = Catalytic Converter KATON = Converter Heating (signal) KD = Kick-Down KHI = interface for headphones KL = Terminal Designation KL15 = run bus (ignition switch run position) KL30 = battery bus (hot at all times) KL31 = ground bus (chassis ground) KL50 = start bus (ignition start position) KLR = accessory bus KO = Compressor "ON" Signal KOMBI = Instrument Cluster KOREL = Compressor Relay Signal KR = Contact Ring KSK = Knock Sensor KVA = fuel consumption signal/value KW = crankshaft (also KiloWatt) ---------------------------------------------------------------------- LAM = Laser Airflow Meter Lambda = the air:fuel & emissions strategy of the DME (lambda = 1) Lambda Control = catalytic converter/oxygen sensor/emission control Lambda probe = the 02 sensor between the engine & catalytic converter Lambda sensor = synonymous with the oxygen sensor LCM = Lamp Check Module (sometimes called the light control module) LDP = Leak Diagnosis Pump (also Loss Diagnosis Pump) LED = Light Emitting Diode LEO = Law Enforcement Officer LEW = Lateral acceleration sensor LHD = Left-Hand Drive LHD = Left-Hand Drive LKM = Lamp Control Module LL = closed throttle LL01 = BMW Long-Life 2001 certification for motor oil quality (aka LL-01) LL04 = BMW Long-Life 2004 certification for motor oil quality (aka LL-04) LM = Light Module LMM = air flow meter/sensor LMR = Light alloy wheel LRA = vertical headlight aiming LRA = Vertical Headlight Aiming LSD = Limited Slip Differential LSM = Steering Column Memory LSZ = Lamp Switching Center LVA = Air Supply System (for EHC system) LWR = Vertical Headlight Aiming control LWS-5 = Steering Angle Sensor ---------------------------------------------------------------------- M-Bus = IHKA/IHKR stepper motor bus MAF = Mass Air Flow Sensor MAL = center armrest MAM = Mass Air Meter MBC = Maximum Brake Control MDK = Motorized throttle valve system MEC = Multi-Function Controller MF = Micro Fiber MFC = Multi-Function Controller MFL = Multi-Function Steering Wheel MFU = Multi-Function Clock MID = Multi-Information Display (on instrument cluster & above radio) MIL = SAE malfunction indicator light (see CEL & SES) MIR = Multi-Information Radio MLF = Multi function Steering Wheel MMC = Multi-Media Changer MoDiC = Mobile Diagnostic Computer MOST-Bus = Media Oriented System Transport bus MRS = Multiple Restraint System MSR = Engine Drag Torque Reduction (or Engine Drag Torque Regulation) MT = Manual Transmission MTF = Manual Transmission Fluid MTL = Manual Transmission Lubricant (as in Redline MTL or Maxima MTL) MV = Magnetic Valve (solenoid Valve) ---------------------------------------------------------------------- NAO = non-asbestos organic brake pad material NAVI = Navigation module NG = New Generation (as in N73 engine) (also tilt sensor) NG = tilt sensor (also "New Generation, as in N73 engine) NOS = Nitrous Oxide Systems NOX = Nitrogen Oxides/ exhaust gas recirculation NSD = rear muffler NSL = rear fog Lamp NSW = fog lamp NTC = Negative Temperature Coefficient (aka coolant temperature sensor) NW = camshaft n-ab = rotational speed, transmission (rpm) n-mot = rotational speed, engine (rpm) ---------------------------------------------------------------------- o-ring = cryptically specified by BMW as 7,5X3,0 (7.5mm ID, 3.0mm thick) O2 = Oxygen (sensor) OBC = on-board computer (e.g., high-obc cluster vs low-obc cluster) OBD = On-Board Diagnosis (SAE) OBDII = On-Board Diagnosis port (must be in cockpit near driver) OE = Original Equipment (not the same as OEM) OEM = Original Equipment Manufacturer (not the same as OE) ---------------------------------------------------------------------- P-Bus = Periphery Bus PAG = Polyalkylene Glycol oil, a hygroscopic oil used in R-134a A/C systems P/N = Park/Neutral position PB = Pin Assignments PCD = performance center delivery PCV = Positive Crankcase Ventilation valve PDC = Park Distance Control Peake = a OBD scan/reset tool PGS = Passive Go System Pixel = the little orange squares (that die) in the MID & KOMBI PM = Power Module (multiple definitions) PM = Preventive Maintenance (multiple definitions) PO = Previous Owner PP = Impact Pad (multiple definitions) PSI = Pounds Per Square Inch PTC = Positive Temperature Coefficient PWG = Pedal Position Sensor / potentiometer) QL = idle air mass adaption (see Fuel Trim) ---------------------------------------------------------------------- RAL = Aluminum wheels (also standard color, from the ETK) RAL = standard color (also aluminum wheels, from the ETK) RAM = (usually DME) random access memory RDC = Reifendruck Control, Tire Pressure Control, see TPMS RDS = Radio Data-broadcast System RDW = Reifendruck Warnsystem, Tire pressure warning system, see TPMS RFT = run-flat tire RHD = Right-Hand Drive RLS = Rain-Light Sensor RM = Relay Module ROM = (usually DME) read-only (aka program) memory ROZ = Research Octane rating for fuel (RON versus MON Motor Octane Number) RPA = Reifenpannenanzeige, tire puncture warning system, see TPMS RPS = Rollover Protection System RPW = Tire Puncture Warning RS = Repair kit RSM = Rear Shock Mount RSW = back-up lamp RTAB = Rear Trailing Arm Bushing RWD = Rear Wheel Drive RXD = wake-up Diagnosis line RZV = Direct Stationary Ignition ---------------------------------------------------------------------- S/C = Supercharger SAE = Society of Automotive Engineers (specifications) SASL = Satellite, A-pillar left SASR = Satellite, A-pillar right SB = Fuse Assignments SBE = Seat occupancy detector/sensor SBFH = Seat module, passenger-side rear SBSL = Satellite, B-pillar left SBSR = Satellite, B-pillar right SBT = SI techniques/ tech reference information (in TIS) SCA = Soft Close Automatic/Actuator SD = silencer/muffler (also sliding roof, from the ETK) SD = sliding roof (also silencer/muffler, from the ETK) SES = service engine soon light (see CEL & MIL) (multiple definitions) SES = voice recognition System (multiple definitions) SFAH = Seat module, driver's side rear SFZ = Satellite, vehicle center SG = Control Unit SGS = Seat Integrated Belt System SHD = Sunroof Module (or sliding/lifting sunroof) SI = Service Interval SIA = Service Intervall Anzeige (service-interval readout when you reset the SII) SII = Service Interval Indicator (see also SIA) SIL = silicon SIM = Safety Information Module SINE = Siren/tilt sensor SKD = Steel sliding roof SKHD = Steel sliding/ lifting roof slushbox = derisive slang for automatic transmission (compared to manual) SM = Seat Module (multiple definitions) SM = Street Modified (multiple definitions) SM/SPM = Seat/Mirror Memory SMBF = Seat Module, passenger side SMFA = Seat Module, driver's side SMG = BMW Motorsport Sequential Manual Gearbox SP = Schematic (multiple definitions) SR-300 = an OBD scan/reset tool SRA = headlight/fog light cleaning SRS = Supplemental Restraint System (includes Airbag) SS = stainless steel, as in Braided SS Brake Lines SSD = Steel sliding roof SSH = Seat Satellite, rear seat SSK = Short Shift Kit ST = Connector Views Step = Steptronic transmission (see Steptronic) Steptronic = transmission shift control (see Step) STVL = Satellite, left front door STVR = Satellite, right front door SVS = Speech processing System SWR = headlamp cleaning system SWZ = Special tool listings (in TIS) SZL = Switch center, steering column SZM = Central Switch Center Module ---------------------------------------------------------------------- TAGE = Door Handle Electronics TCM = Transmission Control Module TC = torque converter TCS = Traction Control System TCU - Telematics Control Unit (related to bluetooth) TD = engine speed tachometer signal via ignition pulse (also tis technical data) TDC = Top Dead Center (vertical position of piston in the cylinder) TE = fuel evaporation control TEL = Telephone control unit TEV = evaporative purge control valve THZ = Tandem master cylinder ti = Injector "on" Time (duration) ti = Injector on time TL = part throttle / load signal TMBFT = door Module, passenger side TMBFTH = door Module, passenger side rear TME = Transmission Mount Enforcer TMFAT = door Module, driver's side TMFATH = door Module, driver's side rear TP = Tandem Pump TPC = Tire Pressure Control (see TPM & TPW) TPM = Tire Pressure Monitor (see TPC & TPW) TPMS = Tire Pressure Monitoring System (see RDC, RDW, RPA, & DWS) TPS = Throttle Position Switch/Sensor TPW = Tire Pressure Warning (see TPC & TPM) TR = engine speed signal (rpm) (also TRansister in the ETK) TR = Transistor (also engine speed signal) TRE = Tie Rod End TRG = fuel level sensor TRI = Technical Reference Information (also SBT) TRS = Battery Isolation Switch TSD = Torsional vibration dampener TSH = Door Lock Heating TSZI = Transistorized coil Ignition system TXD = Transmitting Diagnosis Line ---------------------------------------------------------------------- U-batt = Battery voltage U-vers = supply voltage UERSS = rollover bar ULF - Universal Ladefreisprechelektronik (Universal Hands-Free System, e.g., bluetooth) URS = rollover protection System USIS = Ultrasonic passenger compartment Sensor ---------------------------------------------------------------------- V = "front" (Vorn) (also vehicle road speed) V = vehicle road speed (also "Vorn", i.e., front) VA = front Axle VAM = Volumetric Airflow Meter VANOS = Variable Camshaft Timing (Variable Nockenwellen Steuerung). VAT = front axle support VC = Valve Cover VDS = Vehicle Description System. VIN Digits 4-7 VEP = distributor-type injection Pump VID = Video module Viton = Better than OEM material for VANOS seals (see BUNA) VIN = Vehicle Identification Number VL = full load (wide open throttle) VSD = front muffler VTEC = Variable Timing and Lift Electronic Control VVT = Valve tronic VVTI = Variable Valve Timing and Lift (With Intelligence) ---------------------------------------------------------------------- WBG = hazard warning switch WIM = Wiper control Module WK = Torque Converter Lock-up Clutch WOT = Wide Open Throttle WSS = Wind Shield WTB = Want to buy (as in WTB xenon passenger headlight) WT = Valve tronic control unit ---------------------------------------------------------------------- Z = "central" (Zentrum) ZAB = ignition fade-out (reduction) ZAE = Central Airbag Electronics ZAS = ignition starter switch ZCP = BMW Competition Package (M3 Only) ZCW = BMW Cold Weather Package ZGM = Central Gateway Module ZK = cylinder head ZKE = Central Body Electronics ZKH = cylinder head cover ZMS = dual-Mass flywheel ZS = central lock ZSD = center muffler ZV = Central Locking System ZVM = Central Locking Module ZWD = Idle Control Valve ---------------------------------------------------------------------- ---------------------------------------------------------------------- German to English translation of the BMW wiring diagram technical terms: ---------------------------------------------------------------------- ---------------------------------------------------------------------- German to English translation of the BMW wiring diagram technical terms: ---------------------------------------------------------------------- Abblendlicht = Dipped Headlights Abbledschalter = Dip Switch ABS (Anti-Blockier-System) = ABS (Antilock Braking system) ABS-Diagnose = ABS Diagnosis ABS-Druckmodulator = ABS Pressure Modulator ABS-Kontrolleuchte = ABS Telltale ABS-Relais = ABS Relay ABS-Sensor = ABS Sensor ABS-Tester = ABS Key ABS-Warnrelais = ABS Warning Relay Abschirmhülse = Screening Sleeve ab = modell from model akustisch (akust.) = acoustic (audible) Änderung = Change Anlasser = Starter Motor Anlasserkontakt = Starter Contact Anlasserrelais = Starter Relay Anlasserschalter = Starter Switch Anlaßrelais = Starting Relay Anlaßwiderstand = Starting Resistor Anlaßwiederholsperre = Starting Repeat Lock Anschluß = Connection Antennenhalter = Aerial Holder Anzeige = readout (or indicator, or display) Ausreichend geladen = sufficiently charged (green battery hydrometer) ---------------------------------------------------------------------- Basis = Base, Basic Batterie = battery Batterie ersetzen = replace battery (yellow battery hydrometer) Bedienteil = Control Element Begrenzungsleuchte, -licht = Marker Light Behördenschaltplan = Circuit Diagram (Official User) beige = beige Benzinstandgeber = Fuel Gauge blau = blue Blaulicht = Blue Light Blinker = Flasher Blinkerausschalter = Flasher Cancel Switch Blinkerkontrolle = Flasher Telltale Blinkerkontrolleuchte = Flasher Telltale Light Blinkerschalter = Flasher Switch Blinkgeber = Flasher Unit Blinkeuchte = Flasher Turn Indicator Bremsflüssigkeit = Brake Fluid Bremsflüssigkeitskontakt = Brake Fluid Contact Bremsflüssigkeitskontaktschalter = Brake Fluid Contact Switch Bremslicht = Brake Light, Stop Light Bremslichtschalter = Brake Light Switch Choke-Kontrolleuchte = Choke Telltale Light Choke-Kontrollschalter = Choke Telltale Switch City-Horn = City Horn Cockpit = Cockpit (Fairing) Country-Horn = Country Horn ---------------------------------------------------------------------- Dauerlicht = Permanent Light Diebstahlwarnanlage = Burglar Alarm Differenzdruckschalter = Differential Pressure Switch Diode = Diode Diodenplatte = Diode Board Diodenträger = Diode Carrier Doppelfanfare = Twin Tone Horn Drehstromgenerator = Alternator Drehzahlmesser = Revolution Counter Drehzahlwarnung = Engine Overspeed Warning Drosselklappenschalter = Throttle Butterfly Switch Druckknopfschalter = Pushbutton Switch ---------------------------------------------------------------------- Einspritzrelais = Fuel Injection Relay Elektrik = Electrical System Endschalter = Limit Switch Entlastungsrelais = Load-Shedding Relay Entstörfilter = Suppressor Filter Entstörgeflecht = Suppressor screening Entstörhülse = Suppressor Sleeve Entstörkasten = Radio Suppression Box Entstörkondensator = Radio Suppression Capacitor Erläuterungen = Note On (Key To) ---------------------------------------------------------------------- Fahrlicht = Low Beam Fanfare = Horns Fanfarerelais = Horn relay Fanfareschalter = Horn Switch Fernlicht = High Beam Fernlichtkontrolle = High Beam Telltale Fernlichtkontrolleuchte = High Beam Telltale Light Fernlichtschalter = High Beam (headlight) Switch Fliegende Sicherung = Fuse In Cable FMS-Geber (Funkmeldesystem) = Two-Way Radio Transmitter France = France Frontplatte = Front Panel FUG (Funkgerät) = Two-Way Radio Set Funk-Batterie = Two-Way Radio Battery für (f.) = for Fuß = Foot Fußbremslichtschalter = Foot Brake Light Switch ---------------------------------------------------------------------- Ganganzeige = Gear Indicator Generator = Generator Getriebe = Gearbox Getriebedeckel = Gearbox Cover Getriebeschalter = Gearbox Swich Gleichrichter = Rectifier grau = gray grün = green ---------------------------------------------------------------------- Hallgeber = Hall-Effect Transmitter Hand = Hand Handbremslichtschalter = Handbrake Light Switch Heckleuchte = Rear Light Heckteil = Tail Heizgriffe = Heated Handlebar Grips hinten = rear Hinzukommende Teile = Additional Parts Hoch, hoher Ton = high, high-note Höhenkorrekturstecker = Height Correction Plug Horn = Horn Horndrücker = Horn Push Hornrelais = Horn Relay Hornschalter = Horn Switch Horntaster = Horn Push Hörsprechgarnitur = Transmitter/Receiver Equipment ---------------------------------------------------------------------- identisch mit = identical with Induktivgeber = Inductive Transmitter Innenraumfilter mit Aktivkohle = cabin filter with activated charcoal Instrument = Instrument Instrumentenbeleuchtung = Instrument Lighting Instrumentkombination = Instrument Cluster ---------------------------------------------------------------------- Kabelbaum = Wiring Harness Kaltstatanhebung Kontrolleuchte = Cold Start-Increased Idle Speed Telltale Light Kaltstatanhebung Kontrollschalter = Cold Start-Increased Idle Speed Telltale Switch Kammernummer = Chamber Number Kasten = Box Kennleuchten = Identification Lights Kennzeichenlicht = Number Plate Light Klangfolge = Tone Sequence klappbar = folding Klemme = Terminal Kombischalter (Kombisch.) = Combined Switch Kombi-Instrument = Combined Instrument Kondensator = Condenser, Capacitor Kontaktplatte = Contact Board Kontaktschalter = Contact Switch Kontrolle = Check, Monitoring, Telltale Kontrolleuchten = Telltales Kraftstoffanzeige = Fuel Gauge Kraftstoffkontrolleuchte = Fuel Telltale Kraftstoffpumpe = Fuel Pump Kraftstoffstandgeber = Fuel Level Sensor Kühlmittelempertur = Coolant Temperature Kühlmittelemperturwarnleuchte = Coolant Temperature Telltale Kupplungsschalter = Clutch Switch ---------------------------------------------------------------------- Ladekontrolle = Charge Telltale Ladestromkontrolleuchte = Charge Telltale Light Ladestromwarnleuchte = Battery Charge Telltale Lampenkontrolleuchte = Bulb Monitoring Light Lampenkontrollgerät = Bulb Monitoring Unit Lautsprecher = Loudspeaker Leerlauf = Idle, Neutral Leerlaufkontrolle = Neutral Indicator Leerlaufkontrolleuchte = Neutral Indicator Light Leerlaufschalter = Idling Switch Leitung = Cable, Wire Leitungsverbinder = Cable Connector Lenkerschalter = Handlebar Switch Leuchtdiode (LED) = Light-Emitting Diode (LED) Licht-Hauptschaltung = Main Light Switch Lichthupe = Headlight Flasher Lichthupe-Relais = Headlight Flasher Relay Lichthupe-Schalter = Headlight Flasher Switch Lichtrelais = Light Relay Lichtschalter = Light Switch links (li.) = left LTG (Leitung) = Lead Luftmengenmesser = Airflow Meter Lüftermotor = Fan Motor ---------------------------------------------------------------------- Magnetschranke = Solenoid Barrier Masse = Earth, Ground Massenpunkt = Earth Grounding Point mechanisch (mech.) = mechanical Mikrofon = Microphone mit (m.) = with Mit Einbauanleitung = including mounting instructions Modell = Model Motor = Motor, Engine Motorkabelbaum = Engine Wiring Harness ---------------------------------------------------------------------- Nachtrag = Supplement Nebellicht, Nebelscheinwerfer = Fog Light Nicht ausreichend geladen = not sufficiently charged (black battery hydrometer) nicht belegt = not in use Notabschalter = Emergency Off Switch Notausschalter = Emergency Stop Switch, Kill Switch nur, nur bei = only, only with ---------------------------------------------------------------------- ohne (o.) = without Öldruckkontrolle = Oil Pressure Telltale Öldruckkontrolleuchte = Oil Pressure Telltale Light Öldruckkontrolleschalter = Oil Pressure Telltale Switch Öldruckschalter = Oil Pressure Switch Öldruckwarnleuchte = Oil Pressure Telltale orange = orange ---------------------------------------------------------------------- Plus = Positive Pol = Pole, Pin -poling = -Pole, -Pin ---------------------------------------------------------------------- Rahmen = Frame rechts (re.) = right Regler = Regulator, Govenor Relais = Relay Rundumkennleuchte = Rotating Beacon ---------------------------------------------------------------------- Schadgasreduzierend = reduces emissions of toxic gases Schalter = Switch Schaltgerät = Switchbox Schaltkasen = Controls Cabinet Schaltplan = Circuit Diagram, Wiring Diagram Scheinwerfer = Headlight Schlußlicht = Rear Light schwarz = black Schweden = Sweden Serienhorn = Standard Horn Sicherung = Fuse Sicherungskasten, -dose = Fuse Box Signalhorn = Horn Signalhornschalter = Horn Switch Sirene = Siren Skalenbeleuchtung = Instrument Dial Lighting Sonderausstattung SA = Special Equipment Spannungsmesser = Voltmeter Spanungsregler = Voltage Regulator Sprechtatse = Speak Button Stadthorn = City Horn Standlicht = Parking Light Straktonhorn = High Power Horn Stecker = Plug Steckerleiste = Plug Strip Steckerplatte = Plug Board Steckerverbindung = Plug Connector Steuergerät = Control Unit STVB (Steckverbindung) = Plug Connection Summer = Buzzer ---------------------------------------------------------------------- Tachobeleuchtung = Speedomter Light Tachometer = Speedometer Tachometer-Skalenbeleuchtung = Speedometer Dial Lighting Tank = Fuel Tank Teile = Parts Temperaturefühler = Temperature Sensor Temperaturschaltgerät = Temperature Switchbox tief, tiefer Ton low = low-note Tonfolgeanlage = Tone Sequence System Tonfolgesteuergerät = Tone Sequence Control Unit Transistorzündung (TSZ) = Transistorized Ignition ---------------------------------------------------------------------- Uhr = Clock Umschalter = Changeover Switch und (u.) = and Unterbrecher = Breaker, Contact-Breaker ---------------------------------------------------------------------- Ventil = Valve Verbindungsstelle = Connection Point Verkleidung = Fairing, Cover Panel Vollenstörung = Interference Suppression, Complete Vollverkleidung = Fairing, Full Voltemeter = Voltmeter vorhandene = Teile Existing Parts vorne = front Vorwahl = Preselection warm = warm ---------------------------------------------------------------------- Warnblinkanlage = Hazard Warning Flashers Warnblinkgeber = Hazard Warning Flasher Unit Warnblinkschalter = Hazard Warning Flasher Switch ---------------------------------------------------------------------- Zeichungs-Nr. = Drawing Number Zeituhr = Clock zum (z.) = to, for Zündung = Ignition Zündauslöser = Ignition Trigger Zündkerzen = Spark Plugs Zünd-Lichtschalter = Ignition-Light Switch Zünd-Lichtschloß = Ignition-Light Switch And Lock Zündschalter = Ignition Switch Zündschloß = Ignition Lock Zündspule = Coil Zündspulenbefestigung = Coil Mounting Zündsteuergerät = Ignition Control Unit Zündunterbrecher = Breaker, Contact Breaker zur (z.) = to, for Zustazinstrumente = Additional Instruments Zusatzschalter = Additional Switches Zusatzscheinwerfer = Additional Driving Lights Zweifunken-Zündspule = Twin-Spark Coil ---------------------------------------------------------------------- ---------------------------------------------------------------------- Commonly recommended brand names (parts used in the BMW): ---------------------------------------------------------------------- ACS = AC Schnitzer, the tuning company Adsotop = registered trademark for Mann activated charcoal cabin air filters ATE = a re-builder of the ABS control module in your BMW Axxis = longer sold in the USA after 6/2010; see PBR BBA = a re-builder of the ABS control module in your BMW BBS = manufacturer of wheels for the BMW Bilstein = a manufacturer of shocks often used in the BMW Borla = a brand of aftermarket BMW exhaust systems Bosch = manufacturer of many parts, e.g., the ABS control module Carsoft = an OBD scan/reset tool Celis = Central lighting systems, a trademark of Hella (as in OEM Celis Tail Light retrofit) DDM Tuning = a seller of BMW items such as wheels & headlights Depot = a headlight commonly used to replace the BMW Hellas DICE = manufacturer of an iPod to radio interface for the BMW Dinan = a California-based tuning compoany (as in Home made CAI (Possibly better then Dinan) DJ Auto = a headlight commonly used to replace the BMW Hellas E-code = a headlight commonly used in Europe to replace BMW Hellas Flowmaster = a brand of aftermarket BMW exhaust systems G-power = a German tuner (as in Who sells G-Power?) Hella = manufacturer of the OEM headlights for the BMW E39 Intravee = manufacturer of an iPod to radio interface for the BMW Jurid = OEM manufacture of E39 front brake pads (lots of dust, great bite) Koni = a manufacturer of shocks often used in the BMW Magnaflow = a brand of aftermarket BMW exhaust systems MM = Module Masters, a re-builder of the ABS control module in your BMW Pagid = brake pad brand name often used in BMW E39s PBR = Patons Brake Replacements (aka Repco/Mintex/Axxis/MetalMasters) Redline = an often recommended manufacturer of lubricating oils Repco = See PBR RP Synchromax = Royal Purple manual transmission fluid Sirius = a satellite-radio provider (as in Sirius Receiver Pinout..) Textar = OEM manufacture of E39 rear brake pads ZF = Sahnradfabrik (gear factory) Friedrichshafen AG, manufacturer of steering & transmissions Note: this list needs a lot of improvement! ---------------------------------------------------------------------- Most-recommended top-three suppliers based on bimmerfest threads: (obviously subject to interpretation; but intended to be useful to newbies) ABS control module rebuilders 123: (BBA, MM, and ATE in that order) Brake pads 123: (Akebono Euro, PBR Deluxe Plus, Jurid/Textar OE) Cabin air filter 123: (Mann CUK2736-2,Hengst E960LI, Mahle LAK73/S) Windshield wiper refills 123: (BMW dealer, ?,?) Wheel cleaner 123: (Sonax R2000, P21S, ??) DOT 4 brake fluid 123: (ATE Super Blue, ??, ??) Motor Oil 123: (Mobil1 0w40 Euro Formula LL-01, Mobil1 5W30 USA, anything 10W30/40 API SM) Headlights 123: (Hella, Depo, DJ Auto) Oil filter 123: (Mahle, Mann HU9254X, Hengst) Tires 123: (??, ??, ??) Shocks 123: (Bilstein HD, Koni FSD, Sachs OE) iPod interface 123: (DICE, ??, ??) Oil extractors 123: (Mityvac, ??, Motive) OBDII testers 123: (Carsoft, Peake, Actron) Repair Manuals 123: (Bimmerfest, Google, Bentley) Radiator & expansion tank 123: (Nissens, Behr, Zionsville) Water pump 123: (EMP/Stewart, Hepu, GMB) Gas additives 123: (nothing, Techron, ??) Exhaust 123: (Magnaflow, Flowmaster, Borla) PLEASE ADD MORE! What to fix in the first month (DIY/Indy/Stealer): - cracked plastic radiator (replace entire system) ($700/$1400/$2800) - CCV and ICV ??? (cn90?) - brittle Vanos seals ($200/$400/$600) - crumbling windshield & back window molding ($50/$100/$200) - missing jack pads ($50/$100/$200) - recode annoying automatic door-lock ($250carsoft/$75/$150) - blown cluster pixels ($500/$800/$0secretwarranty) - blown MID pixels ($250/$500/$1000) - cracked wood trim ($400/$800/$1200) - ??? PLEASE add YOUR EXPERIENCE & PRICING! What to fix when it breaks (DIY/Indy/Stealer): - broken ABS control module steel power wire ($150/$600/$1200) - erratic fan-control (FSU/FSR) module ($100/$200/$300) - loose rear vapor barrier seals ($50/$100/$200) - clogged cabin-filter housing drain hose ($0/$25/$50) - washed-out roundels ($25/$50/$100) - crumbled headlight adjusters ($200aluminum/$500/$1000) - frayed trunk loom wiring harness ($25/$200/$1200) - bump brake shudder front shocks worn ($500/$1000/$2000) - stuck window regulators ($150/$300/$600) - curb-crushed ambient temperature sensor ($100/$200/$400) - fragile front & rear cupholders often break ($100/$250/$500) - wobbly thrust arm bushings ($200/$400/$1000) - ??? PLEASE add YOUR EXPERIENCE & PRICING! Maintenance items (DIY/Indy/Stealer): - oil & filter change ($25/$75/$250) - front & rear brake pads ($100/$300/$800) - front & rear rotors ($300/$600/$1200) - ??? PLEASE add YOUR EXPERIENCE & PRICING! Overall Used BMW E39 DIY Repair Budget (assume 50K miles or so): $1k for the first month $100 a month thereafter (ad infinitum) Overall BMW E39 Indy Repair Budget (assume 50K miles or so): $2k for the first month $200 a month thereafter (ad infinitum) Overall BMW E39 Stealer Repair Budget (assume 50K miles or so): $3k for the first month $300 a month thereafter (ad infinitum) ---------------------------------------------------------------------- Most-recommended BMW parts suppliers (please improve): ---------------------------------------------------------------------- AllEuro,(NV),+1-866-286-2051,http://www.alleuropeanautoparts.com AllOem,(??),+1-800-230-5754,http://www.alloembmwparts.com Apex,(PA),+1-866-505-2739,http://www.apexperformance.net AutoBody,(??),+1-800-364-3005,http://www.bmwautobodypartstore.com AutoHaus,(AZ),+1-800-240-4620,http://www.autohausaz.com,(no,ship>50) AutoParts,(??),+1-800-859-0923,http://www.******************.com Bavauto,(NH),+1-800-535-2002,http://www.bavauto.com Bimmerparts,(??),+1-888-810-9223,http://www.bimmerpartswholesale.com BMAParts,(CA),+1-888-262-3911,http://www.bmaparts.com BMWfans,(??),+1-???-???-????,http://www.bmwfans.info Circle,(NJ),+1-732-440-1238,http://www.circlebmw.com Crevier,(CA),+1-800-309-2318,http://www.crevierbmw.com Crown,(NC),+s,+1-866-756-1437,http://www.crownbmw.com EACTuning,(OH),+1-877.322.5757,http://www.eactuning.com, ElAuto,(FL),+1-954-316-1022,http://www.elautoparts.com EuroParts,(NY)+1-800-871-3619,http://www.europartsdirect.com KOPerf,(FL),+1-888-581-1035,http://www.koperformance.com Mileone,(MD),+1-443-872-0743,http://www.mileoneparts.com OemBimmerParts,(TX),+1-210-445-7090,http://www.oembimmerparts.com OverNight,(??),+1-800-267-1845,http://www.overnightautoparts.com Pacific,(CA),+s,+1-800-542-9634,http://www.pacificbmw.com PartsBin,(??),+1-888-628-3247,http://www.***********.com Pelican,(CA),+1-888-280-7799,http://www.pelicanparts.com RealOEM,(WB),Lookup only!,http://www.realoem.com/bmw SpeedNet Motorsports (CA) 800-530-3515 http://www.speednetmotorsports.com/index.html TecaAccess,(??),+1-925-485-4559,http://www.tecaccessories.com Turner,(MA),+1-800-280-6966,http://www.turnermotorsport.com Zeckhausen,(NJ),+1-800-222-8893,http://www.zeckhausen.com ---------------------------------------------------------------------- E// = Entwicklung, chassis code, evolution, development, project, e.g., E39 Note: Sometimes called Entwurfen, as in Entwurfen 39, aka E39 BMW E3 (1968-1977) 2.5, 2.8, 3.0, 3.3 "New Six" sedans BMW E9 (1969-1975) 2800CS, 3.0CS, 3.0CSL "New Six" coupés BMW E12 (1972-1981) 5 Series BMW E21 (1975-1983) 3 Series BMW E23 (1977-1986) 7 Series BMW E24 (1976-1989) 6 Series BMW E26 (1978-1981) M1 BMW E28 (1981-1988) 5 Series BMW E30 (1982-1991) 3 Series BMW E31 (1990-1999) 8 Series BMW E32 (1986-1994) 7 Series BMW E34 (1988-1995) 5 Series BMW E36 (1991-1999) 3 Series BMW E36/5 (1995-1998) 3 Series Compact (US market known as "318ti") BMW E36/7 (1996-2002) Z3 Series Roadster BMW E36/8 (1998-2002) Z3 Series Coupé BMW E38 (1994-2001) 7 Series BMW E39 (1996-2003) 5 Series BMW E46/5 (2000-2004) 3 Series Compact BMW E46/4 (1998-2005) 3 Series Sedan BMW E46/3 (1999-2005) 3 Series Touring/Sports Wagon BMW E46/2 (1999-2006) 3 Series Coupé BMW E46/C (1999-2006) 3 Series Convertible BMW E52 (2000-2003) Z8 BMW E53 (2000-2006) X5 BMW E60 (2004-present) 5 Series BMW E61 (2004-2007) 5 Series Touring/Sports Wagon BMW E63 (2004-present) 6 Series coupé BMW E64 (2004-present) 6 Series convertible BMW E65 (2002-2007) 7 Series short wheelbase BMW E66 (2002-2007) 7 Series long wheelbase BMW E67 (2002-2007) 7 Series Protection BMW E70 (2007-present) X5 BMW E83 (2004-present) X3 BMW E85 (2003-present) Z4 BMW E86 (2006-present) Z4 Coupé BMW E87 (2004-present) 1 Series BMW E88 (2008) 1 Series Convertible BMW E89 (2009) Z4 roadster BMW E90 (2005-present) 3 Series BMW E91 (2005-present) 3 Series Touring/Sports Wagon BMW E92 (2006-present) 3 Series Coupé BMW E93 (2007-present) 3 Series Convertible BMW F01 (2008) 7 Series BMW F02 (2009) 7 Series long wheelbase BMW F03 (2008) 7 Series Protection BMW F04 (2009) 8 Series Light Base BMW F10 (2010) 5 Series BMW F11 (2012) 5 Series Touring/Sports Wagon BMW F12 (2011) 6 Series Coupé BMW F13 (2011) 6 Series Convertible BMW F14 (2011) LC5 BMW F25 (2011) X3 ---------------------------------------------------------------------- ---------------------------------------------------------------------- Single page BMW E39 fluid summary: (print for glovebox) (with a reference thread for each to see if they stand the test of time) - Power steering: Dexron III ATF (realistically, Dexron VI ATF because Dexron III certification is no longer available from GM) Bentley page 020-20. [Volume: It has been said to be just under 2 quarts; I used about a quart to flush twice just my power steering reservoir using a turkey baster to remove fluids out the top.] Note: I6=rack and pinion attached to an aluminum subframe, V8=recirculating ball and nut attached to a steel subframe. Replacement Interval: Bentley says it's "permanently filled"; but most of us would suction out and refill the reservoir with about a quart of fluid every few years because it's a hygroscopic fluid and the permanent filter on the bottom of the reservoir doesn't prevent the fluid from becoming dirty. Some even replace the reservoir in order to have a new filter. Most also replace or cut off the tip of the bottom hoses whose clamp often allows leaks. - Windshield & headlight washer system: surprisingly, I can't find a specification in the Bentley; it should be in book II section 611, Wipers & Washers; but it's not; the Owners Manual, page 150 (Washer Fluid), it says to use "water" and "screenwash when required" (whatever "screenwash" is). [Volume: 3.7 quarts (0.9 gallons, 3.5 liters) or 6.3 quarts (1.6 gallons, 6.0 liters) with headlamp washer system]. Replacement Interval: When needed. - Intensive cleaning system: The Owners Manual (page 150, Washer Fluid), says to use "BMW intensive cleaning agent", BMW P/N: 83.12.0.410.745 (500ml bottle). [Volume: 1.1 quarts (1.0 liters)]. Replacement Interval: When needed. - Brakes (9/1998 and later): "low viscosity" "high performance" DOT 4 (nobody seems to know what "low viscosity" means in practical terms; but the Bentleys clearly specify both "low viscosity DOT 4" on page 340-9 and "high performance DOT4" on page 020-11 and just plain old "DOT 4" on page 020-24). ATE Super Blue DOT 4 or any good DOT 4 brake fluid can be used. [Volume: Most people use about 750 ml or about 3/4 quart to flush the four wheels manually so buy about a liter or quart to power flush your entire brake system.] Replacement Interval: Every two (2) years (Bentley page 020-9) starting from date of manufacture. Best to use the pressure method, e.g., Motive pressure bleeder; but the two-man push-and-open method still works. - Brakes (up to 8/1998): "high performance" DOT 4 (nobody seems to know what "high performance" means in practical terms; but the Bentleys clearly specify "high performance DOT4" on page 020-11 and just plain old "DOT 4" on page 020-24 and again on page 340-9). Replacement Interval: Every two (2) years (Bentley page 020-9) starting from date of manufacture. - Hydraulic clutch (manual transmission only): Uses the same reservoir as the brake fluid, Bentley 020-26. - Engine oil (E39 1999 & later): 15W40 LL-01 mineral oil BMW PN: 07.51.0.017.868 (amazingly, only ONE SAE weight is specified! Don't be confused because Bentley page 020-11 lists only SAE 15W40 while page 020-9 confusingly lists only 5W30 & 15W40 but the 020-11 appears to be the specific listing). [Volume: I6=6.9 quarts, V8=7.9 quarts]. Replacement Interval: The instrument cluster Service Interval Indicator (SII) will determine when necessary by lighting the yellow light and indicating "OIL SERVICE". Note: Mixing oil types (mineral vs synthetic) is permissible. On average, most seem to change oil & filter roughly thrice a year at about 4,500 miles. Best to use either the oil-pan gravity-drain method or the MityVac vacuum-extraction method (don't use the Motive vacuum extractor). Most replace the oil filter on every oil change. - Engine oil (gas, E39 1997 & 1998): Synthetic 5W-30 LL-01 (aka long-life 2001) BMW PN: 07.51.0.017.866 (amazingly, only ONE SAE weight is specified! This is confusing because Bentley page 020-11 lists only SAE 5W30 while page 020-9 confusingly lists only 5W30 & 15W40 but the 020-11 appears to be the specific listing). Replacement Interval: The instrument cluster Service Interval Indicator (SII) will determine when necessary. Note: Mixing oil types (mineral vs synthetic) is permissible. On average, most seem to change oil & filter roughly thrice a year at about 4,500 miles. - Engine oil (diesel): I can't find anything in the Bentleys; but the euro owners manual lists on page 152 "ACEA: A3/B3 or ACEA: A3/B4" specifications which all long-life-01 oils meet (according to that owners manual). Replacement Interval: The instrument cluster Service Interval Indicator (SII) will determine when necessary. - Engine coolant/antifreeze: phosphate free (for Europe's high-mineral-content water), amine & nitrite/nitrate free (for USA long-life requirements), & low-silicate or silicate free (for Japan requirements) 50:50 mixture of ethylene glycol & water (the Bentleys say distilled water (Bentley 020-11), aka de-mineralized or de-ionized water, some call it purified water, and the BMW AG TIS 12.11.2007 18:56 specifies water with a pH from 6.5 to 8.0, maximum total hardness of 3.6 mmol Ca++/liter, maximum chloride content 100 mg/liter, and maximum sulphate content 100mg/liter; interestingly the BMW TIS says "potable tap water usually fulfills these requirements". Despite this, most people say never use tap water due to the ion content. BMW lists a score of coolants in their BMW AG TIS 12.11.2007 18:55 which meet the BMW N 600 69.0 standard, some of which are BMW PN:81.22.9.407.454 1.5-liter; BMW PN:88.88.6.900.316 1 gallon; Castrol Anti-Freeze NF; BASF Glysantin Protect Plus G48, & Havoline AFC (BD04). Others recommend Service Pro Universal Formula; Valvoline Zerex G-05, & Prestone Extended Life 5/150. [Total Volume: 1997 I6=10.5 quarts (2.6 gallons), 1997 V8=12.0 quarts (3.0 gallons), 1998-2002 I6=11.1 quarts (2.8 gallons), 1998-2002 V8=12.7 quarts (3.2 gallons), 1997-2002 V8 with latent heater=13.5 quarts (3.4 gallons)]. Prestone says the only reason for phosphate free is the extremely high mineral content of water in Europe - and that in the USA, it's not needed. Replacement Interval: Every three years (Bentley page 020-9) or every four years (aforementioned BMW AG TIS) starting from date of manufacture (except for M-Power vehicles which have 3-year intervals). Note: Mixing BMW-recommended coolant brands is permissible; but mixing types is not permissible unless it's an emergency. - Air conditioner: Refrigerant 134a (aka R-134a) with poly alkylene glycol oil, sometimes referred to as poly alkaline glycol oil (aka PAG refrigerant oil). Bentley book II, 640-2 & 640-3 & 640-23. The PAG oil is known by other names such as ND8, PAG46, and BMW PN: 82.11.1.468.042 and travels with the refrigerant as a mist. Best to empty and then refill refrigerant by total weight; second best is the evaporator temperature method (i.e., in the shade, ambient temperature less than about 75°F and relative humidity below about 60% - then add R-134a until the evaporator exit air temperature with A/C set on max at 60°F is 4°C/39°F or colder - the best you can do without MoDIS is probably the center-dash vent at something like 10°C/50°F); third best is the pressure method (i.e., add refrigerant until the low-pressure side is 25 psi to 45 psi ... aim for around 32 psi (assuming shade, ambient, & humidity listed prior); worst is by can weight (e.g., adding a 12oz by weight can or a 16oz can by weight but the AC is a critical-charge system that won't tolerate refrigerant quantities much outside + or - .05 kg). [Volume: E39's built up to 12/97 contain 1,225 grams +/- 25 grams (2.70 lbs +/- 0.05 lbs) of R-134a; E39s built after 12/97 contain 750 grams +/- 10 grams (1.65 lb +/- 0.03lb) of R-134a. The amount of PAG oil misted in the system is said to be about 1 ounce by volume.] Replacement Interval: Lifetime charge. - Manual transmission (yellow sticker): BMW PN: 83.22.9.408.942 or MTF-LT-1 (manual transmission fluid, lifetime, I'm not sure what the "1" means) Bentley page 020-10 & 020-30. [Volume: See chart below.] Replacement Interval: Lifetime oil (Bentley 230-6). A user-recommended fluid is "Royal Purple Synchromax 1512 manual transmission fluid" & Redline MT-90; the user-recommended replacement interval is roughly 5 years or about 60K miles. - Manual transmission (orange sticker): The Bentleys, on page 200-4, simply say "ATF" (aka ATF-Oil). Nothing more. Note: This orange sticker is not mentioned in the Bentleys page 020-10 & 020-30 but is noted on page 200-4. Replacement Interval: Lifetime oil (Bentley 230-6); but the user-recommended replacement interval is roughly 5 years or about 60K miles. - Automatic transmission (green sticker): BMW PN: 83.22.0.024.359 or Texaco ETL 8072B or Shell LA2634 (this is extremely confusing, not only because these are cryptic "types" but also because the Bentleys list different fluids and volumes on page 020-10, 240-6, & 240-8). [Volume w/o torque converter/with torque converter, see chart below]. Replacement Interval: Lifetime oil (Bentley 240-6); but the user-recommended replacement interval for the fluid and filter is roughly 5 years or about 60K miles. Apparently Pentosin is the OEM oil but FEBI also works (ATF Auto Transmission Fluid equivalent to ESSO LT 71141). Note: Mixing ATF types will cause transmission failure (Bentley 240-6). My 2002 525i with the ZF 5HP19 (aka A5S 325Z) transmission (6.2 liters/8.9 liters or 6.6 quarts/9.4 quarts) has this green sticker. - Automatic transmission (black sticker): Dexron III ATF (realistically Dexron VI ATF) BMW PN: 83.22.9.407.807 or Exxon LT-71141 which seems to also be called Esso LT-71141) (all this is extremely confusing, not only because these are cryptic "types", but also because the Bentleys list different fluids on page 020-10 than on page 240-6). [Volume w/o torque converter/with torque converter, see chart below]. Replacement Interval: Lifetime oil (Bentley 240-6); but the user-recommended replacement interval for the fluid and filter is roughly 5 years or about 60K miles. Note: Mixing ATF types will cause transmission failure (Bentley 240-6). Some users suggest Mobil1 Synthetic ATF. See this thread for complete details on fluids, torques, volumes, locations, etc and to find which transmission is in your model E39: Manual transmissions: BMW 525i 2001-2002 M52TU, M54: Getrag S5D 250G, 1.2 quarts (1.1 liters) BMW 540i 1997-2002 M62: ZF/Getrag S6S 420G, 2.0 quarts (1.9 liters) BMW 528i 1997-2002 M52: ZF S5D 320Z, 1.4 quarts (1.3 liters) BMW 530i 2001-2002 M54: ZF S5D 320Z, 1.4 quarts (1.3 liters) Automatic transmissions: GM THM-R1 (A4S 270R), 9.3 quarts/8.2 quarts (8.8 liters/7.8 liters) BMW 528i to 9/1999 M52: GM THM-R1 (A4S 310R), 9.3 quarts/8.2 quarts (8.8 liters/7.8 liters) BMW 528i from 9/1999: GM 5L40-E/GM5 (A5S 360R), 9.5 quarts/8.5 quarts (9.0 liters/8.0 liters) BMW 525i to 3/2001 M54: GM 5L40-E/GM5 (A5S 390R), 9.5 quarts/8.5 quarts (9.0 liters/8.0 liters) BMW X5 GM 5L40-E/GM5 (A5S 390R), 10.1 quarts/9.1 quarts (9.6 liters/8.6 liters) BMW 530i to 3/2001 M54: GM 5L40-E/GM5 (A5S 390R), ? quarts/? quarts (? liters/?liters) ZF 4HP22, 7.9 quarts/3.2 quarts (7.5 liters/3.0 liters) ZF 4HP24, 8.6 quarts/3.3 quarts (8.1 liters/3.1 liters) ZF 5HP18 (A5S 310Z), 8.2 quarts/3.4 quarts (7.8 liters/3.2 liters) BMW 525i from 3/2001 (2.5L M54): ZF 5HP19 (A5S 325Z), 9.4 quarts/6.6 quarts (8.9 liters/6.2 liters) BMW 530i from 3/2001 (3.0L M54): ZF 5HP19 (A5S 325Z), 9.2 quarts/6.5 quarts (8.7 liters/6.1 liters) ZF 5HP24 (A5S 440Z) for 4.4 L, 9.5 quarts/5.7 quarts (9.0 liters/5.35 liters) BMW 540i from 1/1997 M62 TU: ZF 5HP24 (A5S 440Z) for 4.6 L, 10.5 quarts/5.7 quarts (9.9 liters/5.35 liters) BMW 540i to 1/1997 M62: ZF 5HP30 (A5S 560Z) 13.8 quarts/5.8 quarts (13.1 liters/5.5 liters) - Differential (conventional, i.e., non-limited-slip E39s): The Bentleys specify "BMW SAF-XO synthetic final drive gear oil" which doesn't exist (it's Castrol). The Bentleys don't specify the weight (it's SAE 75W-90); and the Bentleys don't specify the quality (it's API GL-5 hypoid gear oil). Given that, suitable replacements are Amsoil Synthetic Manual Transmission Fluid (MTF) API 75W90,Mobil1, Royal Purple Max-Gear, & Redline SAE 75W90 API GL-5 synthetic gear oils. Unfortunately, there's no way to tell which of the three (3) different differentials you have w/o looking at the numbers molded into the metal. Bentley page 020-11 & 020-26 & 331-6. [Volume: Type G=1.7 quarts, Type 188 Compact=1.1 quarts, Type 220/215 Compact=1.5 quarts.] Replacement Interval: Lifetime fluid (but most recommend replacing differential fluid at the same time you replace transmission fluid, which is about 5 years or roughly 60K miles). - Differential (limited-slip E39s, such as the M5): BMW SAF-XJ API GL-5 SAE 75W-140 synthetic hypoid final-drive gear oil (aka Castrol SAF-XJ). This requirement is not listed in the Bentley manual; it is gleaned from the Castrol literature and from what is stated about the M5 in this thread below (please correct if necessary). Replacement Interval: Lifetime fluid (but most recommend replacing differential fluid at the same time you replace transmission fluid, which is about 5 years or roughly 60K miles). - Battery: A charged battery is 33.5% (volume/volume%) sulfuric acid (4.2 Molar H2SO4, ) & distilled water (Bentley 020-23) with positive plates containing lead dioxide (PbO2) and negative plates of lead (Pb), both mixed with calcium (Ca) to minimize gassing (i.e., loss of water) and other elements (such as tin, antimony, & selenium to harden the plates and simplify manufacturing) in a polypropylene case. In the discharged state, both plates turn to lead sulfate (PbSO4) as the electrolyte loses its dissolved sulfuric acid and becomes primarily water (which can freeze in cold temperatures and the lead sulfate may form insoluble crystals which, over time, reduce the capacity of the battery if it is not recharged immediately after discharge). [Total Volume: unknown but users have reported adding about 20 ml per cell after two years of use]. Replacement Interval: Lifetime fluid (top off only if needed, after removing steel strap, two stickers and then unscrewing the six cell caps, and filling to the fill line which is 1/4 inch or 5mm above the top of the plates at the very bottom of the internal black plastic depth indicator). The OEM battery has built-in hydrometer where green indicates a charged battery and black indicates a discharged battery, and yellow indicates a defective battery. Better to test at 27°C/80°F by loading battery with 15 amperes for 1 minute (or just turn headlights on w/o engine running) and then perform a 1.265 specific-gravity hydrometer test of each of the six cells (add or subtract 0.004 to the hydrometer reading for every 10°F/6°C above or below 27°C/80°F respectively); and a 12.6 volt open-circuit voltage test across the battery terminals (Bentley 121-5, 121-6). OEM specs are BMW 61.21.8.381.762, USA 729905-10, EN 12V 90Ah 720A, SAE 160 RC 720 CCA. Aftermarket batteries are NAPA #7549, Deka 649MF, Interstate MTP-93, Werker model???, Batteries Plus model???, East Penn model??? (need specific model info) with a stamped date code within the last month or two. - Engine fuel (gas): The sticker on the inside of the fuel filler specifies the octane rating to use; most E39s in the USA specify unleaded 91 AKI (the AKI is the average of the RON & the MON). Lower octane ratings can be used as the two piezoelectric knock sensors will retard timing if they sense detonation vibrations which may adversely affect performance but which won't damage the car under normal circumstances. [Volume: 70 liters (18.5 gallons) with a reserve capacity of 8 liters (2 gallons) in the 525i & 530i and a reserve of 10 liters (2.5 gallons) for the 540i]. We're not sure the algorithm for the small round yellow fuel-warning light, but most people say it goes on approximately at 40 miles remaining fuel; chime sounds at approximately half that (need more data). Replacement Interval: Monthly, as fuel reputedly goes "stale" after 30 days; also it's reputed you should fill by the 1/4 to 1/8 mark in order to better cool the fuel pump. Fuel can't be siphoned out due to siphon restrictions 4 inches in but can be bled using other methods. - Engine fuel (diesel): On page 23 of the Owners Manual, it lists "Diesel oil DIN EN 590", whatever that is. It specifically says not to use rapeseed oil methyl ester (aka RME), or bio diesel oil. Replacement Interval: As needed. ??? - Tire pressure & mixture: Standard air (i.e., 78% nitrogen, 21% oxygen) or 95% to 98% nitrogen (it's not pure nitrogen because they generate the nitrogen from air instead of using pure liquid nitrogen bottles). [Volume: About 10 to 18 liters at 30psi at 25°C, mass is about 26 grams of air].Pressure is more important than volume. The stated reason for the higher rear inflation is to handle weight transfer upon acceleration but nobody is really sure. You want to stay within 3% (+/-) between the axles as greater differences can create problems with ABS & the car's traction control systems. Some say you also need to take into account the load rating if you deviate from the standard 94 load range for the OEM E39. If you buy tires rated, say, 97, they say you need to adjust the pressure down or the tires will be overinflated. There are many reputed reasons for nitrogen over air, the main one being tires lose air at about 2.7 pounds of pressure per month while nitrogen-inflated tires lose it at only 0.7 pounds per month. Here is a general BMW E39 inflation table from QSilver. 18" - 38/41 front/rear (up to 4 passengers) (this is the only one that is different) 18" - 41/48 front/rear (5 passengers) 16"/17" - 35/39 front/rear (up to 4 passengers) 16"/17" - 41/48 front/rear (5 passengers) 16"/17" - 30/35 front/rear (up to 4 passengers) snow tires & Q/T/H speed rated tires 16"/17" - 36/44 front/rear (5 passengers) snow tires & Q/T/H speed rated tires ---------------------------------------------------------------------- BIMMERFEST REFERENCES: Reference - Glossary of BMW terms and abbreviations E39-wiki BMW Acronyms Acronyms? Acronyms... BMW-specific E39 acronyms (list and definition) Most recommended BMW parts suppliers What does the ULF stand for in "BMW Bluetooth ULF"? 1-page printout of the dozen fluids in the E39 INTERNET REFERENCES: BMW E39 acronyms BMW technical terms (pdf) BMW technical acronyms BMW abbreviations and acronyms What does E mean anyways Autohauz definition of Aftermarket, DO, OE, OEM, & OES ---------------------------------------------------------------------- Please add more BMW-specific acronyms & definitions & technical translations ... or correct these above. Please do not add BMW joke acronyms & definitions (there are already too many threads for that). I'll update this with your input for as long as it will let me. Last edited by bluebee; 07-07-2010 at 04:26 PM. |
Stealer: BMW dealership servicing
'07 335xi 6-spd 4dr, Montego blue '98 540i 6-spd Sport, Jet Black II(sold) '92 325i 5-spd 4dr, burgundy(sold) |
moderators? can you guys make this a sticky?
![]() "Owning any german car is like hanukkah, every day another light" |
BMW: Bleed Money Weekly
Rules to live by: - Fast, reliable, cheap. You can only have two. - BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one. |
ZKE is actually "body electronics" and is not limited to just windows.
![]() BMW Technical Acronyms ![]() A - "out" (Aus) AB - Airbag ABL - Brake system warning Lamp (2 color) ABS - Anti-lock Braking System AC - Air Conditioning (from ETK) ACC - Active Cruise Control ACS - Active Comfort Seats ADB(X) - Automatic Differential Braking ADS - engine intake air control ADV - windshield wiper pressure control AEGS - Automatic Electronic Gearbox Control (also EGS) AFM - Air Flow Meter AGD - suction silencer (from ETK) AGR - emission reduction AGS - Adaptive transmission control AG - Automatic Gearbox (transmission) AHK - Active rear-axle Kinematics AHK - trailer hitch (from ETK) AHM - trailer Module (not for US models) AHPS - Advanced HPS AIC - Automatic Interval Control (rain sensor) AKF - activated carbon canister (from ETK) AKS - Active head restraint AKS - pressure regulating device (from ETK) ALC - Automatic Light Control ALR - Automatic Lamp Range Adjustment AMM - Air Mass Meter AMP - radio system AMPlifier ARI - car radio information system (from ETK) ARS - Active Roll Stabilization ASC - All Season traction ASC-EZA - ASC w/ engine timing and injection intervention ASC+T - ASC+ Traction control ASK - Audio System controller (Kontroller) ASR - self starter block relay (from ETK) AST - Automatic Slip control (marketing term) AT - remanufactured part (from ETK) AT - Antenna (from ETK) ATF - Automatic Transmission Fluid (from ETK) ATL - exhaust gas turbo charger (from ETK) AUC - Automatic air recirculation AUT - AUTomatic transmission (from ETK) AVT - Antenna amplifier Tuner AZD - tightening torque specifications (in TIS) A/D – Analog/Digital B - Benzene (gasoline) BAT - BATtery (from ETK) BC - Board Computer BC1 - Body Controller 1 BL - Brake Light (from ETK) BLS - Brake Light Switch BMBT - Board Monitor BS - Block diagram BST - Battery Safety Terminal BVA - Brake pad wear indicator (from ETK) BZM - center console control center BZMF - center console control center, rear CAN – Controller Area Network (Multiple ECU Controller) CAN-Bus - Controller Area Network (bus) CANH-Bus - CAN bus, High CANL-Bus - CAN bus, Low CANP - fuel tank ventilation valve CAS - Car Access System CBC - Corner Braking Control CBS - Condition Based Service CCM - Check Control Module CD - Control Display CDC - Compact Disk Changer CDS - CD player (from ETK) CEL - CELsius (from ETK) CIM - Chassis Integration Module CO - Carbon monOxide (from ETK) COMBI – Electronic Instrument Cluster CON - CONtroller CU - Copper (from ETK) CVM - Convertible top Module CVT - Constantly Variable Transmission CW - drag coefficient (from ETK) D1 - Xenon light/ gas discharge (from ETK) D-Bus - Diagnosis bus (same as TXD) DBC - Dynamic Brake Control DBS - Dynamic Braking System DCS - Dealer Communication System DE – Diagnostic Unit DD - Dynamic motor Drive DDE - Digital Diesel Electronics DIN - German industrial standards DIS - Diagnosis and Information System DISA - Differential air intake control DIVA - continuously variable length intake runners DK - throttle housing/valve DKB - throttle w/ brake intervention DKE – Throttle Increase DKI - throttle position DKR - throttle reduction DKT - throttle position signal DKV - preset throttle position value DME - Digital Motor Electronics DM-TL - Diagnostic Module Tank Leakage DOHC - Double Over Head Camshafts (from ETK) DS - gasket set (from ETK) DSC - Dynamic Stability Control DSP - Digital Sound Processing DTC - Diagnostic Trouble Code (SAE) DTC - Dynamic Traction Control DWA - theft deterrent system DWS - tire pressure Warning System DZM - revolution counter (from ETK) E - "in" (Ein) EBA - installation instructions (from ETK) EBV - Electronic Brake force proportioning ECE - European market version (from ETK) ECM - Engine Control Module (SAE term) ECU - Electronic Control Unit EDC - Electronic Damper Control (from ETK) EDR - Electronic throttle control E-KAT - Electrically heated catalytic converter EZA - see ASC-EZA ECM - Engine Control Module (SAE term) ECO - Controller for I-Drive system EDC - Electronic Dampening Control EDC-K - Electronic Dampening Control - Continuous EDK - Electronic throttle valve EDS - pressure regulator EFH - Electric window lifter (from ETK) EGS - Electronic transmission control EH - Electronic-Hydraulic EHC - Electronic Height Control EKM - Electronic body Module EKP - Electric fuel Pump ELV - Electronic steering lock EM - Electro-Mechanical EMF - Electro-Mechanical parking brake EML - Electronic Motor Load regulation EMV - Electro-Magnetic sensitivity (from ETK) EO - component location EPC - Electronic Parts Catalog (also ETK) EPROM - Erasable/ Programmable chip Memory (from ETK) ETK - Electronic parts catalog (also EPC) ETM - Electrical Troubleshooting Manual ESS - Electronic anti-theft device EV - injection Valve EWS - Electronic drive-away protection FB - Function description FBC - Fading Brake Control FBD - remote control services FBZV - radio frequency locking system FGR – Vehicle Speed Control (Cruise Control) FH - window lifter FHK - rear Heater/ air conditioner FLC - automatic Light Control FRU - Flat Rate Unit FS – Crash Sensor FZV - central lock receiver GAL - speed dependent sound volume GM - General Module GMR - yaw moment control GPS - Global Positioning System GRII - cruise control GRS - rotation Rate Sensor GS – Belt Tensioner GWK - torque converter lock-up control H - "rear" (Hinten) H2 - Xenon headlights HA - rear Axle (from ETK) HC – Hydro Carbon HD - Heavy Duty (from ETK) HDC - Hill Decent Control HFM - Hot Film air mass Meter HG - manual Gearbox (transmission) HKL - Hydraulic trunk lid Lift HLM – Hot Wire Air Mass Meter HPS - Head Protection System HR - Heater control (from ETK) HVA - Hydraulic Valve Adjuster (from ETK) Hz – Hertz (Cycle) I-Bus - Information bus IB - Interior lighting control signal IHKA - automatic Heating and A/C IHKAF - IHKA w/ micro filter IHKR - regulated Heating and A/C IHKRF - IHKR w/ micro filter IHKS - standard Heating and A/C IHPD - Internal High Pressure Deformation IHR - Integrated Heater control (from ETK) IKE - Instrument cluster Electronics ILH - Interior Lighting, rear ILV - Interior Lighting, front IMS - Instant Mobility System (from ETK) IR – Infrared IRS – Infrared Locking System ISC – Idle Speed Control ISIS - Intelligent Safety Integration System ISN - Individual Serial Number ISOFIX - standardized mounts for child restraints ITS - head airbag assembly/ Inflatable Tubular Structure IVM - Integrated power supply Module K-Bus - body bus (Karosserie) KAT - catalytic converter KATON - converter creating (signal) KD - Kick-Down KHI - interface for headphones KL - terminal designation KL15 - run bus (ignition switch run position) KL30 - battery bus (hot at all times) KL31 - ground bus (chassis ground) KL50 - start bus (ignition start position) KLR - accessory bus KO - compressor "on" signal KOMBI - instrument cluster KOREL - compressor relay signal KR – Contact Ring KSK - Knock Sensor KVA - fuel consumption signal/value KW - crankshaft KW - KiloWatt (from ETK) LCM - Lamp Check Module LDP - Leak Diagnosis Pump LEV - Low Emissions Vehicle LEW - Lateral acceleration sensor LHD - Left-Hand Drive (from ETK) LKM - Lamp control Module LL - closed throttle LM - Light Module LMM - air flow meter/sensor LMR - Light alloy wheel LRA - vertical headlight aiming LSM - steering column memory LSZ - Lamp Switching center LVA - air supply system (for EHC system) LWR - vertical headlight aim control LWS-5 - steering angle sensor M-Bus - IHKA/IHKR stepper motor bus MAL - center armrest MBC - Maximum Brake Control MDK - Motorized throttle valve/system MFL - Multi-Function steering wheel MFC - Multi-Function Controller MFU - Multi-Function Clock MID - Multi-Information Display MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp MIR - Multi-Information Radio MMC - Multi-Media Changer MoDiC - Mobile Diagnostic Computer MOST-Bus - Media Oriented System Transport bus MRS - Multiple Restraint System MSR - engine drag torque Regulation MV - Magnetic Valve (solenoid Valve) n-ab - rotational speed, transmission (rpm) n-mot - rotational speed, engine (rpm) NAVI - Navigation module NG - New Generation (as in N73 engine) NG - tilt sensor NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK) NSD - rear muffler (from ETK) NSL - rear fog Lamp (from ETK) NSW - fog lamp (from ETK) NTC - Negative Temperature Coefficient NW - camshaft (from ETK) OBC - On-Board Computer OBD - On-Board Diagnosis (SAE) P/N – Park/Neutral position P-Bus - Periphery bus PB - Pin assignments PBS - Parts Bulletin System (in TIS) PDC - Park Distance Control PGS - Passive Go System PM - Power Module PP – Impact Pad PTC - Positive Temperature Coefficient RLS - Rain-Light Sensor PWG - Pedal position sensor/ potentiometer RA - Repair instructions (in TIS) RAM – Random Access Memory RAL - Aluminum wheels (from ETK) RAL - standard color (from ETK) RDC - tire pressure Control RDS - Radio Data-broadcast System RDW - tire pressure Warning RHD - Right-Hand Drive (from ETK) RM - Relay Module ROZ - Research Octane rating/ fuel grade (from ETK) RPA - tire puncture warning (from ETK) RPS - Rollover Protection System RS - Repair kit (from ETK) RSW - back-up lamp (from ETK) RXD - wake-up Diagnosis line RZV - direct stationary ignition SASL - Satellite, A-pillar left SASR - Satellite, A-pillar right SAV - Sport ACTIVITY Vehicle SB - fuse assignments SBE - Seat occupancy detector/sensor SBFH - Seat module, passenger-side rear SBSL - Satellite, B-pillar left SBSR - Satellite, B-pillar right SBT - SI techniques/ tech reference information (in TIS) SCA - Soft Close Automatic/Actuator SD - sliding roof (from ETK) SD - silencer/ muffler (from ETK) SE - Special Equipment (from ETK) SES - voice recognition System SFAH - Seat module, driver's side rear SFZ - Satellite, vehicle center SG - control unit SGS - Seat integrated belt System SHD - sliding/ lifting roof (from ETK) SHD - Sunroof module (also SHDM) SI - Service Information (in TIS) SIA - Service Interval system (ver. I, II, III, IV, etc.) SII - Service Interval Indicator SIL - SILicon (from ETK) SIM - Safety Information Module SINE - Siren/tilt sensor SKD - Steel sliding roof (from ETK) SKHD - Steel sliding/ lifting roof (from ETK) SM - Seat Module SM/SPM - Seat/Mirror Memory SMBF - Seat Module, passenger side SMFA - Seat Module, driver's side SMG - Sequential Manual Gearbox SP - Schematic SRA - headlight/fog light cleaning SRS - Supplementary Restraint System SSD - Steel sliding roof (from ETK) SSH - Seat Satellite, rear seat ST - connector views Steptronic - transmission shift control STVL - Satellite, left front door STVR - Satellite, right front door SVS - Speech processing System SWR - headlamp cleaning system (from ETK) SWZ - Special tool listings (in TIS) SZL - Switch center, steering column SZM - central switch center Module TAGE - door handle Electronics TCM - Transmission Control Module TD - engine speed signal (ignition pulse) TD - Technical Data (in TIS) TE - fuel evaporation control TEL - TELephone control unit TEV - evaporative purge control THZ - Tandem master cylinder (from ETK) ti - Injector "on" Time (duration) TIS - Technical Information System TL - part throttle / load signal TLEV - Transitional Low Emission Vehicle TMBFT - door Module, passenger side TMBFTH - door Module, passenger side rear TMFAT - door Module, driver's side TMFATH - door Module, driver's side rear TP - Tandem Pump (from ETK) TPS - Throttle Position Switch/Sensor TR - engine speed signal (rpm) TR - TRansistor (from ETK) TRG - fuel level sensor (from ETK) TRI - Technical Reference Information (also SBT) TRS - battery isolation Switch TSD - Torsional vibration dampener (from ETK) TSH - door lock Heating TSZI - Transistorized coil Ignition system (from ETK) TU - Technical Update (as in M50tu) TXD - Transmitting Diagnosis line U-batt - Battery voltage U-vers - supply voltage UERSS - rollover bar (from ETK) URS - rollover protection System USIS - Ultrasonic passenger compartment Sensor V - "front" (Vorn) V - vehicle road speed VA - front Axle (from ETK) VAT - front axle support (from ETK) VANOS - Variable camshaft timing VEP - distributor-type injection Pump (from ETK) VID - VIDeo module VL - full load (wide open throttle) VSD - front muffler (from ETK) VVT – Valve tronic WBG - hazard warning switch (from ETK) WIM - Wiper control Module WK - torque converter lock-up clutch WSS – Wind Shield (from ETK) WT – Valve tronic control unit Z - "central" (Zentrum) ZAB - ignition fade-out (reduction) ZAE - central Airbag Electronics ZAS - ignition starter switch (from ETK) ZGM - central Gateway Module ZK - cylinder head (from ETK) ZKE - central body Electronics ZKH - cylinder head cover (from ETK) ZMS - dual-Mass flywheel (from ETK) ZV - central locking system ZS - central lock (from ETK) ZSD - center muffler (from ETK) ZV - central locking system (from ETK) ZVM - central locking Module ZWD - idle control valve |
Here's another I just found ...
A Processed Vehicle Speed AB Airbag ABS Anti-lock Braking System ADS Engine Intake Air Control ADV W/wiper Pressure Control AGS Adaptive Transmission Control AIC Automatic Interval Control (rain sensor) ARS Active Roll Stabalization ASC All Season Traction ASC+T ASC+Traction ASK Audio System Controller AST Slip Control (Marketing term) AUC Automatic Air Recirculation B Benzene (gasoline) BC Board Computer BC1 Body Controller 1 BLS Brake Light Switch BMBT Board Monitor BS Block Diagram BST Battery Safety Terminal BZM Center Consol Control Center CAS Car Activation System CBC Corner Braking Control CAN-Bus Controller Area Network(bus) CCM Check Control Module CIM Chassis Integration Module CVM Convertible Top Module CVT Constantly Variable Trans. D-Bus Diagnosis Bus (same as TXD) DBC Dynamic Brake Control DCS Dealer Communication System DDE Digital Diesel Electronics DIN German Industrial Standards DIS Diagnosis and Information System DISA Differential Air Intake Control DK Throttle Housing DKI Throttle Position DME Digital Motor Electronics DM-TL Diag.Module Tank Leakage DSC Dynamic Stability Control DSP Digital Sound Processing DTC Diagnostic Trouble Code DWA Theft Deterrent System DWS Tire Pressure Warning System EBV Electronic Brake Proportioning E-KAT Electrically Heated Catalytic Converter ECM Engine control module (SAE) EDC Electronic Dampening Control EDK Electronic Throttle Valve EGS Electronic Transmission Control EH Electronic Hydraulic EHC Electronic Height Control EKM Electronic Body Module EKP Electronic Fuel Pump ELV Electronic Steering Lock EM Electro-Mechanical EME Electro-Mechanical Emergency Brake EML Electronic Motor Load Regulation EO Component Location EPC Electronic Parts Catalog ETM Elec. Troubleshooting Manual EWS Electronic Driveaway Protection FB Function Description FBZV Radio Frequency Locking FRU Flat Rate Unit GAL Speed Dependent Volume GM General Module GMR Yaw Moment Control GRII Cruise Control GPS Global Positioning System HDC Hill Decent Control HFM Hot Film Air Mass Meter IB Interior lighting Control Signal I-Bus Information Bus IHKA Automatic Heating and A/C IHKR Regulated Heating and A/C IHKS Standard Heating and A/C IKE Instrument Cluster Electronics IR Infrared ISIS Intelligent Safety Integration System ISN Individual Serial Number KAT Catalytic Converter KATON Converter Heating (signal) K-Bus Body Bus KL Terminal Designation KO Compressor "ON" Signal KOMBI Instrument Cluster KOREL Compressor Relay Signal KW Crankshaft LCM Lamp Check Module LDP Leak Diagnosis Pump LEV Low Emissions Vehicle LKM Lamp Control Module LL Closed Throttle LRA Vertical Headlight Aiming LSM Steering Column Memory LSZ Lamp Switching Center LVA Air Supply System LWR Vertical Headlight Aiming LWS 5 Steering Angle Sensor MBC Maximum Brake Control MDK Motororized Throttle Valve MFL Multi-Function Steering Wheel MEC Multi-Function Controller MID Multi-Information Display MoDiC Mobile Diagnostic Computer MRS Multiple Restraint System MSR Engine Drag Torque Reduction NG New Generation OBC On-Board Computer OBD On-Board Diagnosis (SAE) PB Pin Assignments P-Bus Periphery Bus PDC Park Distance Control PWG Pedal Position Sensor RDC Tire Pressure Control RDW Tire Pressure Warning RM Relay Module RPS Rollover Protection System RPW Tire Puncture Warning RXD Wake-up Diagnosis Line RZV Direct Stationary Ignition SB Fuse Assignments SBE Seat Occupancy Detector SCA Soft Close Actuator SG Control Unit SGS Seat Integrated Belt System SHD Sunroof Module SII Service Interval Indicator SM Seat Module SP Schematic ST Connector Views SZM Central Switch Center Module TD Engine Speed ti Injector on time TL Part Throttle TLEV Transitional Low Emission Vehicle TRS Battery Isolation Switch TSH Door Lock Heating TU Technical Update TXD Transmitting Diagnosis Line VANOS Variable Camshaft Timing VL Full load - wide open throttle WK Converter Lock-up Clutch ZAE Central Airbag Electronics ZGM Central Gateway Module ZKE Central Body Electronics ZV Central Locking System ZVM Central Locking Module ZWD Idle Control Valve |
Here is a English translation of the German BMW terms ...
This is a copy of the German to English translation of the technical terms BMW uses on their electrical wiring schematics. Abblendlicht Dipped Headlights Abbledschalter Dip Switch ABS (Anti-Blockier-System) ABS (Antilock Braking system) ABS-Diagnose ABS Diagnosis ABS-Druckmodulator ABS Pressure Modulator ABS-Kontrolleuchte ABS Telltale ABS-Relais ABS Relay ABS-Sensor ABS Sensor ABS-Tester ABS Key ABS-Warnrelais ABS Warning Relay Abschirmhülse Screening Sleeve ab modell from model akustisch (akust.) acoustic (audible) Änderung Change Anlasser Starter Motor Anlasserkontakt Starter Contact Anlasserrelais Starter Relay Anlasserschalter Starter Switch Anlaßrelais Starting Relay Anlaßwiderstand Starting Resistor Anlaßwiederholsperre Starting Repeat Lock Anschluß Connection Antennenhalter Aerial Holder Basis Base, Basic Batterie Battery Bedienteil Control Element Begrenzungsleuchte, -licht Marker Light Behördenschaltplan Circuit Diagram (Official User) beige beige Benzinstandgeber Fuel Gauge blau blue Blaulicht Blue Light Blinker Flasher Blinkerausschalter Flasher Cancel Switch Blinkerkontrolle Flasher Telltale Blinkerkontrolleuchte Flasher Telltale Light Blinkerschalter Flasher Switch Blinkgeber Flasher Unit Blinkeuchte Flasher Turn Indicator Bremsflüssigkeitskontakt Brake Fluid Contact Bremsflüssigkeitskontaktschalter Brake Fluid Contact Switch Bremslicht Brake Light, Stop Light Bremslichtschalter Brake Light Switch Choke-Kontrolleuchte Choke Telltale Light Choke-Kontrollschalter Choke Telltale Switch City-Horn City Horn Cockpit Cockpit (Fairing) Country-Horn Country Horn Dauerlicht Permanent Light Diebstahlwarnanlage Burglar Alarm Differenzdruckschalter Differential Pressure Switch Diode Diode Diodenplatte Diode Board Diodenträger Diode Carrier Doppelfanfare Twin Tone Horn Drehstromgenerator Alternator Drehzahlmesser Revolution Counter Drehzahlwarnung Engine Overspeed Warning Drosselklappenschalter Throttle Butterfly Switch Druckknopfschalter Pushbutton Switch Einspritzrelais Fuel Injection Relay Elektrik Electrical System Endschalter Limit Switch Entlastungsrelais Load-Shedding Relay Entstörfilter Suppressor Filter Entstörgeflecht Suppressor screening Entstörhülse Suppressor Sleeve Entstörkasten Radio Suppression Box Entstörkondensator Radio Suppression Capacitor Erläuterungen Note On (Key To) Fahrlicht Low Beam Fanfare Horns Fanfarerelais Horn relay Fanfareschalter Horn Switch Fernlicht High Beam Fernlichtkontrolle High Beam Telltale Fernlichtkontrolleuchte High Beam Telltale Light Fernlichtschalter High Beam (headlight) Switch Fliegende Sicherung Fuse In Cable FMS-Geber (Funkmeldesystem) Two-Way Radio Transmitter France France Frontplatte Front Panel FUG (Funkgerät) Two-Way Radio Set Funk-Batterie Two-Way Radio Battery für (f.) for Fuß Foot Fußbremslichtschalter Foot Brake Light Switch Ganganzeige Gear Indicator Generator Generator Getriebe Gearbox Getriebedeckel Gearbox Cover Getriebeschalter Gearbox Swich Gleichrichter Rectifier grau gray grün green Hallgeber Hall-Effect Transmitter Hand Hand Handbremslichtschalter Handbrake Light Switch Heckleuchte Rear Light Heckteil Tail Heizgriffe Heated Handlebar Grips hinten rear Hinzukommende Teile Additional Parts Hoch, hoher Ton high, high-note Höhenkorrekturstecker Height Correction Plug Horn Horn Horndrücker Horn Push Hornrelais Horn Relay Hornschalter Horn Switch Horntaster Horn Push Hörsprechgarnitur Transmitter/Receiver Equipment identisch mit identical with Induktivgeber Inductive Transmitter Instrument Instrument Instrumentenbeleuchtung Instrument Lighting Instrumentkombination Instrument Cluster Kabelbaum Wiring Harness Kaltstatanhebung – Kontrolleuchte Cold Start-Increased Idle Speed Telltale Light Kaltstatanhebung – Kontrollschalter Cold Start-Increased Idle Speed Telltale Switch Kammernummer Chamber Number Kasten Box Kennleuchten Identification Lights Kennzeichenlicht Number Plate Light Klangfolge Tone Sequence klappbar folding Klemme Terminal Kombischalter (Kombisch.) Combined Switch Kombi-Instrument Combined Instrument Kondensator Condenser, Capacitor Kontaktplatte Contact Board Kontaktschalter Contact Switch Kontrolle Check, Monitoring, Telltale Kontrolleuchten Telltales Kraftstoffanzeige Fuel Gauge Kraftstoffkontrolleuchte Fuel Telltale Kraftstoffpumpe Fuel Pump Kraftstoffstandgeber Fuel Level Sensor Kühlmittelempertur Coolant Temperature Kühlmittelemperturwarnleuchte Coolant Temperature Telltale Kupplungsschalter Clutch Switch Ladekontrolle Charge Telltale Ladestromkontrolleuchte Charge Telltale Light Ladestromwarnleuchte Battery Charge Telltale Lampenkontrolleuchte Bulb Monitoring Light Lampenkontrollgerät Bulb Monitoring Unit Lautsprecher Loudspeaker Leerlauf Idle, Neutral Leerlaufkontrolle Neutral Indicator Leerlaufkontrolleuchte Neutral Indicator Light Leerlaufschalter Idling Switch Leitung Cable, Wire Leitungsverbinder Cable Connector Lenkerschalter Handlebar Switch Leuchtdiode (LED) Light-Emitting Diode (LED) Licht-Hauptschaltung Main Light Switch Lichthupe Headlight Flasher Lichthupe-Relais Headlight Flasher Relay Lichthupe-Schalter Headlight Flasher Switch Lichtrelais Light Relay Lichtschalter Light Switch links (li.) left LTG (Leitung) Lead Luftmengenmesser Airflow Meter Lüftermotor Fan Motor Magnetschranke Solenoid Barrier Masse Earth, Ground Massenpunkt Earth Grounding Point mechanisch (mech.) mechanical Mikrofon Microphone mit (m.) with Modell Model Motor Motor, Engine Motorkabelbaum Engine Wiring Harness Nachtrag Supplement Nebellicht, Nebelscheinwerfer Fog Light nicht belegt not in use Notabschalter Emergency Off Switch Notausschalter Emergency Stop Switch, Kill Switch nur, nur bei only, only with ohne (o.) without Öldruckkontrolle Oil Pressure Telltale Öldruckkontrolleuchte Oil Pressure Telltale Light Öldruckkontrolleschalter Oil Pressure Telltale Switch Öldruckschalter Oil Pressure Switch Öldruckwarnleuchte Oil Pressure Telltale orange orange Plus Positive Pol Pole, Pin -poling -Pole, -Pin Rahmen Frame rechts (re.) right Regler Regulator, Govenor Relais Relay Rundumkennleuchte Rotating Beacon Schalter Switch Schaltgerät Switchbox Schaltkasen Controls Cabinet Schaltplan Circuit Diagram, Wiring Diagram Scheinwerfer Headlight Schlußlicht Rear Light schwarz black Schweden Sweden Serienhorn Standard Horn Sicherung Fuse Sicherungskasten, -dose Fuse Box Signalhorn Horn Signalhornschalter Horn Switch Sirene Siren Skalenbeleuchtung Instrument Dial Lighting Sonderausstattung (SA) Special Equipment Spannungsmesser Voltmeter Spanungsregler Voltage Regulator Sprechtatse Speak Button Stadthorn City Horn Standlicht Parking Light Straktonhorn High Power Horn Stecker Plug Steckerleiste Plug Strip Steckerplatte Plug Board Steckerverbindung Plug Connector Steuergerät Control Unit STVB (Steckverbindung) Plug Connection Summer Buzzer Tachobeleuchtung Speedomter Light Tachometer Speedometer Tachometer-Skalenbeleuchtung Speedometer Dial Lighting Tank Fuel Tank Teile Parts Temperaturefühler Temperature Sensor Temperaturschaltgerät Temperature Switchbox tief, tiefer Ton low, low-note Tonfolgeanlage Tone Sequence System Tonfolgesteuergerät Tone Sequence Control Unit Transistorzündung (TSZ) Transistorized Ignition Uhr Clock Umschalter Changeover Switch und (u.) and Unterbrecher Breaker, Contact-Breaker Ventil Valve Verbindungsstelle Connection Point Verkleidung Fairing, Cover Panel Vollenstörung Interference Suppression, Complete Vollverkleidung Fairing, Full Voltemeter Voltmeter vorhandene Teile Existing Parts vorne front Vorwahl Preselection warm warm Warnblinkanlage Hazard Warning Flashers Warnblinkgeber Hazard Warning Flasher Unit Warnblinkschalter Hazard Warning Flasher Switch Zeichungs-Nr. Drawing Number Zeituhr Clock zum (z.) to, for Zündung Ignition Zündauslöser Ignition Trigger Zündkerzen Spark Plugs Zünd-Lichtschalter Ignition-Light Switch Zünd-Lichtschloß Ignition-Light Switch And Lock Zündschalter Ignition Switch Zündschloß Ignition Lock Zündspule Coil Zündspulenbefestigung Coil Mounting Zündsteuergerät Ignition Control Unit Zündunterbrecher Breaker, Contact Breaker zur (z.) to, for Zustazinstrumente Additional Instruments Zusatzschalter Additional Switches Zusatzscheinwerfer Additional Driving Lights Zweifunken-Zündspule Twin-Spark Coil |
And, the E39 wiki has been pointed out ...
+ 1 on the sticky call.
Well done bb. That has the potential to making things a lot easier, especially for the newbs. Nothing worse than reading a thread and coming across a bunch of capital letters and not knowing what they're referring to and then probably guessing the wrong words. I knew most of them (of the first list, lol), now I can know all of them and more, thanks. Do I presume right in that this info (capital letter abbreviation) would now pop up in a search, whether a sticky or not? |
Although it is accepted on this board that "CPS" means camshaft or crankshaft position sensors, that's actually incorrect. CKP is the correct acronym for crankshaft position sensor and CMP is correct for camshaft position sensor. Just some FYI.
And two more, which many unlucky BMW owners may be familiar with:
FUBAR (Fu@ked Up Beyond All Recognition) and BOHICA (Bend Over, Here It Comes Again)
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Or..if you can't find it doing a search here...just remember you can go to google and type "BMW Acronyms" and find the lists that Bluebee posted above.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
I updated the first post to indicate that. Thanks. Together we can make this useful to newbies (like me!).
I searched the Internet (exactly as you said) but I only found the three lists I posted above. I was very surprised there weren't more, nor were there diagrams which showed what I'd like to see - which is diagrams of the car with all the abbreviations pointed out. Of course, I guess I could look at every page of my paper or PDF Bentley or every diagram on realoem - but I was hoping to find MORE than just three lists on the entire Internet. I'll keep looking though (using more imaginative terms) to find the hold outs!
I'd rather keep the jokes to a separate thread.
It's my fault for not saying "no jokes please" in the OP so I just edited the OP to say the additions requested are for valid BMW terms and not jokes as I'd seriously like to compile a complete list - and then we can pare it down to correct the errors. The humor just messes up this serious effort. Searching Bimmerfest, I find this thread tried the same thing four years ago; we're just expanding upon those efforts. And this thread but it petered out before going far. In the end, when all the input is added, we can sort alphabetically and uniquify to come up with the best list on the Internet! Note: Abbreviation is not an acronym nor a definition; but we're combining them here into one list to be posted back into the first post. Last edited by bluebee; 05-12-2010 at 06:21 PM. |
What are the slash slash slash BMW terms?
Can someone explain what the ///M stuff means?
Is there a list somewhere of these slash slash slash BMW terms? My google terms for ///M are too generic. |
///M = Motosport (BMW sports version) |
BMW: Bring My Wallet
good job bluebee, very useful info. thanx
Inspired Technology...Intelligent Design |
hahahaha
![]() Nice Nice list OP. Thanks.
_______________Going to Bimmerfest East AND West ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
It took hours, but I combined ALL the prior listed BMW definitions, acronyms, and technical translations into a single list which I posted back into the first post of this thread.
AFAIK, this is the most definitive list of BMW technical abbreviations (jokes aside) on the Internet. I did this for myself (since I know less than almost all of you), for newbies (since they might even know less than I do), and for the experts (so they can help us clarify and improve this list). Please improve by: - Adding new content - Clarifying existing content Thanks, Bluebee |
BTW, I see mention in Bimmerfest posts about "ULF" as in "bluetooth ulf bracket".
What does ULF mean? |
#25
http://en.wikipedia.org/wiki/Ultra_low_frequency Best guess. Nice thread. If I get time I'll work on the German translation. One of the features of Germanic languages is the ability to string words together, so you get the redcarwithsportssuspensionandtwentyinchchromewheel sandadroptop which is kinda hard to translate.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
