Old 05-10-2010, 08:06 PM
ethopianmike ethopianmike is offline
Mein Auto: 2003 745li
03 745Li - Trunk keeps opening
The trunk on my 745LI keeps coming up with the car in park or in drive, I have to keep the it locked or else it won't stay closed. If in the unlocked position it will go up. Does anyone know what that might be from.
Also after I turn the car off and I am listening to the radio after about 10 mins, the recharge battery light comes on, a few minutes after that comes on everything will shut off that is running on the battery. It will start back up, is this a sign of a more serious problem, or maybe a bad battery?
Does anyone suggest changing the mircro filters themselves?
I have a lot of questions hopefully someone can help.
Thank you.
Old 05-11-2010, 02:32 PM
udoknow udoknow is offline
Mein Auto: 2003 745i
Its your battery. Low batteries on these cars causes nightmares.
Old 05-11-2010, 02:58 PM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
Yes, 5-minute job, very easy.
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 05-11-2010, 03:41 PM
STRTWYZ's Avatar
STRTWYZ STRTWYZ is offline
Mein Auto: 4 Chevy's and a Bimmer
Do you have a trunk monkey? Maybe he's trying to get out!
Old 05-11-2010, 03:47 PM
Wilassasin's Avatar
Wilassasin Wilassasin is offline
Wilassasin
Mein Auto: 07' 750Li(sport)/C6 conv.
Mr. Officer
335i xdrive coupe,750 sport(sold), S550 sport pack,C6 vert...
Old 05-11-2010, 09:06 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
'03 745i - modded - GONE -
