Old 05-17-2010, 11:23 PM
Mpulse Mpulse is offline
Mein Auto: '05 330ci ZHP
Suspension setup in my ZHP
Wondering if anyone has a preference in these coilover kits I've been looking at.
Bavarian autosport height adjustable-front and rear:
springs and shocks $850
Bilstein PSS coilover suspension kit with adjustable adjustable ride height:
$999
Anyone have experience with either?
Old 05-18-2010, 03:38 AM
bishop1977 bishop1977 is offline
Mein Auto: 330i zhp s/c
I'd go with bilstein they have a lifetime warranty
Old 05-18-2010, 04:41 AM
marlin1881 marlin1881 is offline
Mein Auto: 2003 330i ZHP
Just out of curiosity, why are you changing the springs on your ZHP? It's already factory lowered, and I think provides a quality ride for its purpose.
Old 05-18-2010, 05:40 AM
It wouldn't be a permanent mod... Just something for track and summer play. Trust me I love everything about the ZHP package and chose it because of it's everyday appeal over an M.
Old 05-18-2010, 05:50 AM
ffej's Avatar
ffej ffej is offline
Tightrope walking
Mein Auto: Jackwagon!
If you're just looking for 'track and summer play' I would consider getting some camber plates and a slightly beefier front sway bar. I've tracked E36s and E46s in MANY different configurations and I've noticed that the single biggest difference is made with -3* to -3.5* of camber at the front wheels. I got a much better driving experience with that than I did with different springs and no additional neg camber in the front.
Building a ZHP wagon... click the pic!!!
Because BMW wouldn't do it for me
For Sale - HUGE part out of 2005 ZHP sedan
Originally Posted by KrisL View Post
My input is that ffej knows what he's talking about .
Old 05-18-2010, 06:03 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
Bilstein's are pretty good and have a great warranty. My friend had them on his ZHP and really liked them. But they are STIFF!
Check out my BMWBLOG!
Old 05-18-2010, 07:39 AM
interesting... anyone have input on this?.. one thing that also drives me nuts and why i looked at springs is the larger wheel gap in the front.
Old 05-18-2010, 07:53 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
That said, I have ground control coilovers (springs: 450f, 550r) w/ koni single adjustable shocks & vorshlag camber plates... the car is fun.
Old 05-18-2010, 09:00 AM
smolck's Avatar
ROLL TIDE!
I have non sport OEM with 75k miles on them, the car ISN'T fun.
Old 05-18-2010, 10:25 AM
jvr826's Avatar
jvr826 jvr826 is online now
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
What he said, but that said, I have TC Kline coilovers with 500/600 springs, single adjustable shocks, and vorshlag camber plates set at -3.0* of camber. Also have UUC Swaybarbarian sway bars, as does KrisL, mine are at 1 notch from full stiff up front, full stiff in the rear. The car is very neutral and easy to rotate. Oh, also run a square wheel/tire setup, as does KrisL. 255/35/18 all around.
I much prefer this suspension to the stock ZHP suspension. It is firm, but better damped. The shocks are top adjustable and I run mine much firmer than Kris does. At full firm up front, half turn from full in the rear (my track and autox setup) the car is only good on smooth surfaces. For normal driving I move both an additional half turn towards soft and like it there. My "commute" type driving is all mountain twisties, so I choose handling over comfort.
I don't think you'll get -3.0* of camber with the stock springs up front, but I don't know for sure. They are substantially larger in diameter than aftermarket coil over springs. Search on my username and "TC Kline" and you will find a thread from a few years ago where I chronicled my suspension install with lots of pictures comparing stock and TCK. You'll see what I mean about the springs. Their size may limit the movement of the strut assembly...
but I don't recommend -3.0* for a car that does mostly freeway commute driving... you'll wear out the inside edge of your tires in no time. -2.0 is probably better for that and if you desire -3.0 for track days, then you can change it, but you also have to change your toe setting up front as increased camber = toe change. A camber gauge and toe plates is all you need to adjust the front end alignment... and some wrenches and a perfectly level surface.
Jeff R.
Old 05-18-2010, 01:34 PM
well the roads here in NE aren't nearly as nice as CA, and already having done the entire suspension over in another car, i don't think i'll be going all out with this one. i was just curious to see if anyone had a particular spring/shock combo that they preferred for something like a seasonal change and for the occasional track day.
Old 05-18-2010, 01:37 PM
jvr826 our cars are almost identical and i love the way yours sits by the way
Old 05-18-2010, 01:39 PM
KrisL's Avatar
Ubergeek
I'd start with camber and the next step would simply be Koni single adjustable shocks with the OEM springs.
Old 05-18-2010, 07:50 PM
jvr826's Avatar
Is it Trackday yet?
Thank you... and I do too.
Recent pic... left side all loaded up! Courtesy of Cliff...
Werd!
Jeff R.
Old 05-18-2010, 08:06 PM
Cliff Cliff is offline
TMS
Mein Auto: BMW
It was interesting that Kris' car consistently lifted a wheel while yours did not. How did your guys' times compare?
FWIW, Matt (P-Tech nee Edge) and Tony (Edge) both recommend I go with TCK single-adjustables for my car, should I decide to go with coilovers.
Old 05-18-2010, 08:09 PM
KrisL's Avatar
Ubergeek
Interesting, Jeff has stiffer springs and his shocks were set stiffer...AND he's got stickier tires.
My times were faster.
Old 05-18-2010, 08:18 PM
TMS
Mein Auto: BMW
You were faster at Marina too, which is pancake flat. Have you guys ever swapped cars and timed it?
Old 05-18-2010, 08:19 PM
KrisL's Avatar
Ubergeek
Yes. I'm faster in his car too.
Old 05-18-2010, 08:25 PM
TMS
Mein Auto: BMW
I had a feeling that was what the answer would come back as..
Old 05-19-2010, 07:18 AM
ffej's Avatar
Tightrope walking
Can I quote on that?
(I guess I just did )
Yes. It is.
It's that way in a lot of circumstances...
Old 05-19-2010, 07:19 AM
ffej's Avatar
Tightrope walking
crud. double post
Old 05-19-2010, 07:37 AM
TMS
Mein Auto: BMW
I know. I am 100% certain that either Kris or Jeff would be faster than me if we swapped cars too.
(I don't even make it into the top 10 in A class)
Old 05-19-2010, 08:22 AM
jetblackbimmer's Avatar
jetblackbimmer jetblackbimmer is offline
ZHP Baby!
Mein Auto: 2005 330i Performance 6MT
Best place to buy Koni single adjustables for my ZHP?
Old 05-19-2010, 08:32 AM
mrmaico's Avatar
mrmaico mrmaico is offline
BMW driver/rider
Mein Auto: 04 330Ci ZHP/05 12GS
Search on my username and "TC Kline" and you will find a thread from a few years ago where I chronicled my suspension install with lots of pictures comparing stock and TCK..
This one?......
http://www.bimmerfest.com/forums/sho...689&highlight=
Old 05-19-2010, 08:46 AM
KrisL's Avatar
Ubergeek
I think Tirerack sells 'em.
