Video of cold idle engine intermittent squeal (how to determine cause)?
Attached is a video of my cold idle engine intermittent squeal.
Debugging hints to isolate the cause are welcome. I replaced the power steering reservoir fluid twice with a quart of Dexron VI which seemed to help a little - but it still came back (the power steering fluid container is empty so you see the white bottom; all the ATF sucked out twice filled the S. Pellegrino water bottle). Caveat: This is my first video upload ever so I may screw it up. Here is the video: Last edited by bluebee; 05-19-2010 at 09:56 PM. |
Donna, I thought we need Dexron III, and is there a negative effect in using Dexron VI?
I am not sure what actually the difference is between the different Dexron labels: Dexron III vs. Dexron IV vs. Dexron VI. (I didn't see a Dexron V yet, and I purchased Dexron IV for my steering). Also, from the pic, your ATF seems grey? This should not be normal - it's light pink. Addendum: In this case (that grey color), I would try to get rid of as much as I can of that grey stuff - it will kill your steering rack (if it didn't already). Here are some methods - beware though they are from a v8, which is different from ours - but close enough for procedure, including cleaning the reservoir which has a build-in filter. GL
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby Last edited by doru; 05-19-2010 at 03:22 PM. |
The squeal sounds like a bearing, possibly an idler wheel, or alt/water pump/PS pump.
Pull fan, remove belts, and examine all the rotating machinery on the front of the engine. Be sure to mark the operating direction of the belts, so you can put them back on correctly. The idler pulley bearings can be cleaned and repaced, if not worn or scored.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Take a spray bottle with water in it....spray a little on the idler pulley....if the noise goes away, the pulley is bad....if not, spray some on the belt...if the noise goes away, replace the belt.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
AFAIK, Dexron III no longer exists. According to what I had read, GM no longer "certifies" compliance with Dexron III; but not to worry. AFAIK, Dexron VI supercedes Dexron III specifications.
Unfortunately that means I'll be taking it apart twice! ![]() Once to identify the culprit; the other to replace it. It would be nice to be able to identify the sqeaky wheel without having to remove the belts! Note: I found an E46 DIY and an 330i M54 DIY (is a 330i M54 engine belt configuration the same as a 525i M54 engine belt configuration???) Last edited by bluebee; 05-20-2010 at 04:17 PM. |
I'm going to have to replace the belt anyway (it has 85K miles on it and has cracks).
I'm not sure which is the idler pulley so I'll look that up... ok. it seems to be related to the A/C and water pump so maybe a debugging hint is to run the AC to see if the sound changes... Last edited by bluebee; 05-21-2010 at 12:11 AM. |
Idler pulley morning squeal = common, I put oil on it to verify, easy to replace
Thanks Blue for the reply.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
Too bad. Cn90 didn't start any threads with idler pulley in them. Lemme search for something else ... Ok, searching the Internet for cn90 and idler gets me closer (on bimmerboard) ... Is this the idler pulley? Is the "idler roller" the same as the idler pulley?
have you used a mechanics' stethoscope to locate the origin of the noise when that happens? It shouldn't be hard to pin point the location. If you find the noise is indeed from the PS pump, try use the ATF from Redline.
Yeah, a stethoscope might help. It helped me locate a bad water pump. Mine didn't screech though, it made a rattling noise.
![]() OEM BBS Style 42 (18x9) | Conti DW 245/40-18 | KraftStab Strut Bar | Bilstein Sports | Vogtland Springs | Eibach Sway Bars | Mason Sway Bar Links | e36 M3 Steering Wheel | Biarritz Blue Metallic | Nimble & Graceful
Portland BMW Club Member |
Would belts or pulleys cause a constant sound? The intermittent is throwing me off.
What happens when you raise the RPM's say to a steady 2500 or so?
![]() I can't imagine a stethoscope working safely because of the moving parts (I mean, you can't just put it on a pulley, can you?) But I'm looking online in AutoHauz for the stethoscope as I'm getting the cabin air filters anyway). Luckily, I need to replace the serpentine belt (it has cracks); but while I'm at it, I'd rather not take it apart twice so may I ask what is the total list of possible components that could cause the intermittent squeal? - idler pulley bearings (can be repacked with grease, right?) - alternator bearings - water pump bearings - power steering pump bearings - the 5-ribbed (6 valleys) serpentine belt In cn90's diagram, I see a few more parts (do you think they have bearings that could cause that noise)? - idler roller - two other rollers - hydraulic tensioner - ??? I hate to take it apart twice just so it would be good to diagnose before getting all the parts. I will try the suggested 2500 rpm test if I can get a helper so that I can videotape the noise.
FYI the part numbers may be different for the M54 engine (different style of pulley I think). Last time I tried neither BMW nor an OE shop sold the M54 tensioner pulleys separately (they sell tensioner only). I didn't look on the internet. I hope you have better luck. Also some cars omit the idler roller pulley.
Mine is doing that now but only when stopped while in gear.
The Ultimate Driving Machine INDEED! |
Call Bill at Bimmerclinic - He might help you out.
Also, check oembimmerparts,com for the parts you need, then shop around.
The only problem I foresee is that those parts can rip your arm off so I am not sure HOW I'm going to get a stethoscope in there w/o getting coiled up in the belts, rollers, and fan! PS: I have a friend coming over to help me videotape the noise since I need to rev the engine and film at the same time for that debugging test. |
Plus, they lowered the number of ribs from 5 to 4 in cars built after 9/2002 (I have 5 valleys, 6 hills, which I think they call a 5-rib belt) so these pulleys change even within the model year! Methinks we should get a group collection up so cn90 can buy a newer E39 so his pictures will correspond to all our BMWs! ![]() I found I think a decent picture labeling half the parts, here: A: Alternator belt tensioner pulley B: Alternator belt idler pulley C: Alternator pulley D: Power steering pump pulley. |
Maybe this is a better picture (does it include all the rollers & pulleys)?
(What's the difference anyway between roller, pulley, and tensioner anyway?) A: Alternator belt tensioner pulley B: Alternator belt idler pulley C: Alternator pulley D: Power steering pump pulley. E = ? F = ? G = ? H = ? ? = (are there others missing in this picture)? |
bluebee i'm have the same problem. ps pump loseing fluid once a week. what i had to do was get under the car and take down the engine sheild too see where the fluid was going too.
but my problem is a little different. i hit, well the rabbit wanted to die. but any ways after running over the little turd i started to have problems. most people need to either tighten some hose's or replace them, cn90 cover this in one of his diy's while working on something else, kind of killed two birds with one stone, or diy. my problem, is when the rabbit went under, the boot that goes over the tierod, tore, and i think he knocked the tierod back some or enough to mess up the seal on the rack. good luck with finding the problem.
The more you complain, the longer God makes you live. :
OK on the stethoscope.
I'm still confused which pulleys, rollers, and tensioners are in the M54 engine! And I don't know how to tell if I have spring-loaded or hydraulic belt tensioners. Is this guess correct yet? A = alternator belt tensioner pulley B = alternator belt idler pulley C = idler roller? D = power steering pump pulley E = crankshaft pulley (aft) F = AC compressor pulley G = crankshaft pulley (fore) H = AC belt tensioner I = alternator pulley Do I have spring-loaded or hydraulic belt tensioners? (anything missing) |
#25
I'm still working on creating an identification diagram for the 2002 525i M54 engine!
If I use CN90's 1998 as the example, do I finally have the right names for all the spinning objects yet? A = water pump pulley B = water pump to crankshaft roller C = deflector roller (aka idler roller) D = power steering pump pulley E = crankshaft pulley, aft (for 5-ribbed serpentine belt) F = air conditioning compressor pulley G = crankshaft pulley, fore (for AC compressor belt) H = AC roller pulley I = alternator pulley QUESTIONS: 1. Are these the right names for the 535i 2002 M54 engine? 2. What's the difference between a roller, a pulley, an idler, & a tensioner? 3. How do we know if we have hydraulic or spring-loaded tensioners? |
