Old 07-28-2008, 12:27 PM
Say MMMM Say MMMM is offline
Mein Auto: 02 M Coupe
What Gas? Octane? Ethanol?
Just seeing what kind of gas you have good experience with. I have chipped to 93 octane. Can I put a higher octane in it? Is it better to use gas without ethanol?
Mods: A Few
Old 07-28-2008, 04:27 PM
Dammmittt's Avatar
Dammmittt Dammmittt is offline
///M
Mein Auto: 07 M Coupe
When I lived in SC, I had good experiences with BP. I'm currently running on Sunoco. As far as ethanol goes, it's like taxes...no way to escape it, 'cept for maybe race fuel.
BMW recommends running on top tier gasolines. There's a whole website on it.
I run the highest octane I can find, usually 93.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website in the History of the Internet!
Old 07-28-2008, 10:36 PM
NJREDZ06 NJREDZ06 is offline
Alpine White Collector
Mein Auto: Z4, 545i, 740IL, MCS, 528
www.toptiergas.com
99 M Coupe
04 M3 Coupe
04 Mini Cooper S MC40 1 of 1000
02 5 Series M Touring
98 318Ti M Sport Pkg
90 M3 Diamond Schwartz
Old 07-29-2008, 04:49 AM
ANILE8 ANILE8 is offline
Mein Auto: BMW Z4 - M Coupé
ALWAYS use the highest octane fuel you can buy in your ///M
I forgot how good us Aussies have it down under.....
In Australia 98 octane gasoline is commonly available from nearly every service station in all the major cities and most of the smaller country towns aswell. Either fron BP, Shell, Caltex or Mobil, they all make 98 octane over here.
I knew we were called the 'Lucky Country' for something
2007 ~ Z4 M Coupé - Carbon Black
Old 07-29-2008, 06:10 AM
caseysc1 caseysc1 is offline
Joiner
Mein Auto: 2005 Z4 2.5 and 2010 128i
BTW, BP is not listed as TopTier gas. Here in SC I use Shell premium which is 93 octane. No issues at this point, but I also use Techron every 3K miles.
If you are wondering about Ethanol, here is quote from the Toptier web site on Ethanol content:
"1.3.1.2 Base Fuel. The base fuel shall conform to ASTM D 4814 and shall contain commercial fuel grade ethanol conforming to ASTM D 4806. All gasoline blend stocks used to formulate the base fuel shall be representative of normal U.S. refinery operations and shall be derived from conversion units downstream of distillation. Butanes and pentanes are allowed for vapor pressure adjustment. The use of chemical streams is prohibited. The base fuel shall have the following specific properties after the addition of ethanol:
Contain enough denatured ethanol such that the actual ethanol content is no less than 8.0 and no more than 10.0 volume percent.
Contain no less than 8 volume percent olefins. At least 75% of the olefins shall be derived from FCC gasoline as defined by CARB (advisory letter, April 19, 2001).
Contain no less than 28 volume percent aromatics.
Contain no less than 48 mg/kg sulfur. At least 60% of the sulfur shall be derived from FCC blend stock.
Produce a 90% evaporation distillation temperature no less than 290°F.
Produce IVD no less than 500 mg averaged over all intake valves."
Pat Casey
2005 Z4 2.5i
Old 07-29-2008, 07:10 AM
dug01's Avatar
dug01 dug01 is offline
Mein Auto: '07 X3, '03 Z4
Taken from Wikipedia about world wide octane ratings--
"[edit] Measurement methods
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.
There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of Europe and Australia) the "headline" octane rating, shown on the pump, is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, the octane shown in the United States is 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, is 91-92 in Europe. However most European pumps deliver 95 (RON) as "regular", equivalent to 90-91 US (R+M)/2, and some even deliver 98 (RON) or 100 (RON).[citation needed]
The octane rating may also be a "trade name", the actual figure being higher than the nominal rating.[citation needed]
It is possible for a fuel to have a RON greater than 100, because iso-octane is not the most knock-resistant substance available. Racing fuels, straight ethanol, AvGas and liquified petroleum gas (LPG) typically have octane ratings of 110 or significantly higher - ethanol's RON is 129 (MON 102, AKI 116) reference[1]. Typical "octane booster" additives include tetra-ethyl lead, MTBE and toluene. Tetra-ethyl lead is easily decomposed to its component radicals, which react with the radicals from the fuel and oxygen that start the combustion, thereby delaying ignition. This is why leaded gasoline has a higher octane rating than unleaded."
It appears that the numbers mean different things...
Old 07-29-2008, 08:03 AM
Dammmittt's Avatar
///M
Yeah...but every time I fill up with Shell my car idles rough.
Old 07-29-2008, 09:12 AM
It may just be that particular station, and not the brand.
Here in NJ over 300 stations were recently fined, temporarily closed or permanently closed due to an audit by the states weights and measures dept.
99 M Coupe
04 M3 Coupe
Old 07-29-2008, 10:50 AM
Dammmittt's Avatar
///M
Good point, for now though, Sunoco works fine, and is a convenient stop for me.
Old 07-29-2008, 11:28 AM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
I use CA 91. Car hasn't blown up yet.
Old 07-29-2008, 12:33 PM
Wil325 Wil325 is offline
Mein Auto: 2008 535i
My 535i threw an "Engine Malfunction! Reduced power" icon at me last month. At the same time, my engine was running so rough that it felt like a Harley Davidson. Anyhow, took it into the shop to have it looked at. They suspected a fuel pump problem but they couldn't warranty the pump because the Ethanol content was too high (I think they measured it at 14%). They told me it needed to be below 9% (that's impossible in my state as 10 percent is the minimum permitted). My options were to pay them $150 to drain my tank and refill the car with Shell gas OR continue to drive it until the gas was almost empty and refill it myself (I went with option two).
Refueled with new gas and the car wasn't any better. Took the car back in but they still wouldn't replace the pump (FYI - the BMW shop I took it to wanted to replace the pump but BMW national wouldn't authorize it). Anyways, when I brought the car back in the Ethanol was at 10%; a bit better. Consequently, under the the better gas (ie, lower ethanol), they were able to 'reset' the computer and the car is running fine again.
Lesson learned: I used to fill up at any ol' gas station, but now I only go to Shell or Marathon. These cars can't handle Ethanol - period!
2008 535i - Black Sapphire Metallic, Black Leather, Bamboo Anthracite Trim with Anthracite Headliner, Premium Package, Sport Package, Cold Weather Package, Steptronic, HUD, Navigation, Night Vision, HD Radio, and Logic 7 with the iPod
2008 Z4 Coupe - Space Gray, Black Leather, Dark Poplar Wood Trim, Premium Package, Sport Package, Steptronic with paddles, Heated Seats, M-Sport Seats, Navigation
Old 07-29-2008, 02:28 PM
Joiner
Again, Toptier rated fuel has no less than 8% and no more than 10% ethanol by volume. So, BMWs run fine as long as the ethanol, by volume, is less than or equal to 10%. Read the "Deposit Control" link, Section 1.3.1.2, on http://www.toptiergas.com/ or read my post above.
Pat Casey
2005 Z4 2.5i
Old 07-29-2008, 07:09 PM
I had the same problem in my Corvette Z06, what happened was that the fuel level sender would malfunction with the high ethanol mixed fuels. I checked the vette msg boards and found that this was a common problem and the fix was Chevron additive added with a full tank of top tier fuel. My tank was reading empty even though there was fuel in the tank, but after the additive and a Shell 93 fill up, my sender worked fine.
Weird how sensitive these cars can be.
99 M Coupe
04 M3 Coupe
Old 08-16-2008, 12:32 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Exactly, US 93 is the same fuel as overseas 97/98. Different rating numbers. But the MON is not always 10 points under the RON. A few years back, BMW found engines were being destroyed by long high speed runs, even runniing 97/98 RON fuel. They found that in all cases, the fuels MON was too low. So they state you should not run a fuel where the MON is more than 10 points lower than the RON. IOW, 91 or 93 AKI depending on the car.
That said, most engines will not perform better with fuel with a high AKI/RON than that specified by the manufacturer. Some do. The S54 in the 2001 and later MZs and E46 M3s gains performance up to about 96 AKI (50/50 mix of 93 and Sunoco GT100, AKI 98). I find the E46 M3 and the LTW both run better on GT100, they seem more response if rev better. I have not tried it in the Roadster.
But running a low AKI fuel may cost performance and actually increase fuel usage (lower gas mileage) as the computer is reducing performance to reduce detonation.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 08-16-2008, 12:48 PM
uncle ken's Avatar
uncle ken uncle ken is offline
Mein Auto: 2014 M6
Good info on ethanol in gasoline here..
http://www.fuel-testers.com/state_gu...anol_laws.html
Note that:
1/ not all states require a sticker on the pump if the gasoline contains ethanol
2/ octane rating can drop quickly if the ethanol is old or contains water
3/ not all the gasoline out there contains ethanol - it varies by location
"Whither goest thou, America, in thy shiny car in the night?"
- Jack Kerouac, On the Road
Old 06-06-2009, 07:55 AM
Scubapiper's Avatar
Scubapiper Scubapiper is offline
Mein Auto: 96 Z3 08 Mini Clubman S
Top Tier Fuel
I did not know about this until reading here as I am fairly new to my Z3. I have tried over the past few days to access the the Top Tier website without success. Is it no longer active? I've used the links in this thread and done a Google search.
Bagpipes: Putting the fun in funerals
Old 06-06-2009, 08:02 AM
uncle ken's Avatar
Mein Auto: 2014 M6
Top Tier Gasoline Retailers:
76
Chevron
Conoco
Entec Stations
Kwik Trip/Kwik Star
MFA Oil Company
Phillips
QuikTrip
Shell
Somerset Refinery
Texaco
Tri-Par Oil Company
Canada:
Petro-Canada
Shell-Canada
Sunoco-Canada
Chevron-Canada
Hawaii:
Aloha Petroleum
Old 06-06-2009, 08:36 AM
tnsbruce's Avatar
tnsbruce tnsbruce is offline
///M Coupe Pilot
Mein Auto: '08 Z4M and '03 530i
Sunoco's 260GT fuel (100 Octane) makes my car run awesome. With the ESS tune the car really performs. At $7 gallon it is not cheap, but makes for a great day at the track.
2008 ///M Coupe
CDV Delete | CSL Wheels | Super Sprint Exhaust | Strong Strut | RE-11's | Cosmetic Blackout | Super Sprint Stepped Headers
3.91 diff | Ground-Control Sway Bars | RRT Rear Control Arms | UUC Short Shifter | KW Club Sport | StopTech BBK |
Old 06-06-2009, 09:16 AM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
I try to run Shell V-Power (93 US octane) as often as possible and Sunoco 93 as a second choice. And I try to stay away from BP since they run (supposedly) 10% Ethanol all year round. Incidentally, I usually get the best mileage with Shell as well.
That being said, on my VW GTI I have had bad luck with one particular Shell station around here- car smelt of rotten eggs every time I would fill up there (high sulphur in the gas probably) and not when I filled elsewhere. Never take the M there.
Every now and then when I am close to empty on a track, I throw in a few gallons of the Sunoco 100 in there to complete the day. The car seems to run smoother - not sure if it is quicker though since I am still on the stock ECU/DME.
Old 06-06-2009, 10:26 AM
Scubapiper's Avatar
76
Chevron
Conoco
Entec Stations
Kwik Trip/Kwik Star
MFA Oil Company
Phillips
QuikTrip
Shell
Somerset Refinery
Texaco
Tri-Par Oil Company
Thanks for the fast response. I've already started running higher octane gas. We don't have a lot of the above stations around here, anyone know if Kwik Fill is the same as Kwik Trip/star, I am assuming they are the same refinery based on the spelling.
Old 06-06-2009, 01:34 PM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
I had carbon deposit issues running 76 for the Los Angeles area 76 stations. It took 2 big doses of Techron to clean it out.
I generally stick to Chevron or Shell these days.
NB: Some old magazine tests on the E46 M3 showed that the S54 performance peaked out at about 95 octane (stock engine software). So don't waste money filing with just 100 octane, do a mix to get into the 95 / 96 range.
Old 06-06-2009, 10:19 PM
skyjmpr skyjmpr is offline
Mein Auto: '07 Z4 3.0i Sport
Refinery may have nothing to do with it. It's the specs of the 'brand' (like Shell, Conoco, etc) that determines what's in the fuel.
Old 05-23-2010, 11:07 PM
aestheticstorm's Avatar
aestheticstorm aestheticstorm is offline
Rad Racer World Champion
Mein Auto: '08 Z4 M Coupé (S.Bronze)
Just crossed the border into Canada yesterday (from Seattle) and discovered Chevron's 94 Octane with zero ethanol
I wonder why the US doesn't get this stuff...
'08 Z4 M Coupé Sepang Bronze, Black/Black, Madeira Wood, CDV delete // 49th from End of Production
Old 05-24-2010, 12:55 AM
Daneborough Daneborough is offline
Mein Auto: Z4M Roadster - 335i Conv
Both my (recent) Z4M and (current) 335i have stickers inside the filler cap quoting "minimum 95 RON" - I've always used 98 RON in both cars when available but never less than 95 RON on occasion when necessary, and never had any issues with either - personal preference is Shell, but will use BP as second choice, or Caltex as last resort
Current:
2008 335i Convertible - Sapphire Black
Not Current:
Z4M Roadster
130i Hatch (wife's drive)
Z4 3.0 (x2)
Mini Cooper S (wife's drive)
Z3 2.8
Z3 1.9
(other marques don't rate a mention!)
Old 05-24-2010, 06:46 AM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
It's my understanding that Ethanol is mixed at the station so ethanol % is completely up to human error. To this point, even amongst "Top Tier" stations, you'll get a larger variance of % between different stations and even the same station. Ethanol is great for engines that are made for it it really bad for those that aren't. It's also banned as an aviation fuel because it has a short shelf life, lowers power, and generally eats engine parts that aren't specifically made to handle ethanol.
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
