Cloudy ATF in PS resevoir
Have a whine from the steering, particularly when parking. Read up on relevant threads here, checked that ATF Fluid level is accurate and it is; so I've drained the resevoir of fairly cloudy and darkish fluid and replaced with clean Dexron III
Drove a bit, checked the fluid and it is again somewhat cloudy and still whines at low speed. Do I need to keep draining and refilling with clean ATF until the fluid remains clear? OR is it normal to be cloudy after running through the PS pump....OR....is this the beginning of the end of the pump...only 62K miles??? |
Keep replacing the fluid until you've run 2 qts through it.
Or, if you're impatient, try this: Method 1 Get two quarts of the best synthetic ATF from your auto parts store. I used Mobil 1. Extract as much of the fluid from the reservoir as you can, using a turkey baster. Optional: remove the reservoir and flush it out with gasoline. I did this, since the filter inside is not removable. Remove the return hose from the reservoir. It’s the forward hose, coming from the radiator, and into the bottom center of the reservoir. Have something ready to plug the reservoir pipe, and catch any residual fluid in the reservoir. I used a rubber cap, designed to cap off vacuum lines, and a couple of shop rags. You’ll need a new hose clamp. BTW, this center clamp allows a leak to develop. Best to replace it anyway. Fit a length of rubber hose onto, or into, the return hose so that you can route it into a catch can of at least two quart capacity. I used a cut-off bleach bottle, since, being white, it is easier to do the next step, as well being an easy target for the stream of fluid. Fill the reservoir with new fluid. Have both bottles of ATF open and handy. With one hand on the hose, aiming into the bucket, and the other on the bottle of ATF, have a helper start the engine. Keep pouring ATF into the reservoir until fresh fluid comes out into the bucket. Then shut off the engine, reattach the hose, and top up the reservoir. DO NOT move the steering wheel with the return hose disconnected, and the engine running! It will pump lots more fluid, and, if the hose is not restrained, it will blow fluid all over! Method 2 The power steering pump has a drain plug on it that you can unscrew instead of pulling off one of the hoses. You'll want to remove the filler cap for quicker drainage. The plug has an o-ring for sealing so you don't really need to replace it if you don't have one (and it isn't leaking). This will drain the PS pump, the reservoir, and most of the PS cooling line in front of the radiator, without having to have the engine running. You can refill, start the engine, crank the wheel both ways a few times, then do another drain/fill and you will have got ~80% of the old fluid out.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
ATF whine
Thanks for the comprehensive reply and will follow up. After all the ATF is clear, if the whine continues, I guess its time to move to the pulley and/or pump....Just finished coil springs and fuel pump and could use a break...$$$$
My cold-start whine seems to be vastly diminished after replacing the power steering fluid with about a quart (two refills) of Dexron VI ATF. But, it's still there, so I bought a mechanics' stethoscope to see if I can pinpoint it further. I also bought new belts ... just in case ... and while I was at it, a new power steering fluid reservoir cap o-ring (to replace the M-badged gym sock). |
I apologize for not updating this thread with my followup to the loud noise, which, at first, I suspected the power steering ... but which turned out to be alternator bearings (ironically, perhaps due to power steering fluid leaking onto them!). - One users' example of total electrical failure (AAA towed away) alternator repair (1) (2) One good thing that did come of this is that I now propose to "replace" the reservoir power steering fluid with every oil change as a matter of habit. And, I propose we replace the power steering cap o-ring whenever we do the lower oil filter o-rings (every few years): |
BTW, the two places to check for leaks are the underside of the reservoir as shown by cn90 here:
![]() And, the underside of the power steering pump as I show here: |
But, whatever you do, please do not make the rookie mistake I made a few years ago when I first went to the auto parts store to ask them to look up what power steering fluid I should use!
Bluebee, why did you opt to use a Dexron VI ATF, and what was the problem with the Redline product shown in the pic above?
At that age (1997 528i), I'd suggest:
- Flush with ATF a few times (search for procedure) - Then install a new PS Reservoir (to avoid filter mesh clog at that age). About $25 for reservoir. |
They told me to use the Redline PSF (which said "BMW" in the marketing blurbs on the back, btw); and, at about $15 a quart (IIRC), it was pricey, but I thought I was giving my bimmer the 'good stuff' (yup, price is meaningless when it comes to quality ... rookie mistake #2). As you know, our bimmers take ATF, not PSF, and I called Redline tech support who told me that it 'should be ok' in the short term; but that was when I decided to write the one-page description of one paragraph for the dozen fluids to keep in our glovebox: - BMW E39 fluid summary printout for your glovebox (1) As for Dexron VI (introduced in 2005) versus Dexron III, the only difference, according to the Redline technical support, was in longer-term situations (I forget all the details, sorry, it was a long time ago) but, Dexron VI, he said, was fully compatible with Dexron III and, in fact, he told me that GM no longer licenses Dexron III. Anyway, I confirmed the fact that GM no longer licenses Dexron III on the Internet (yea, you 'could' call that rookie mistake #3, trusting the Internet, but in this case, I believe it). Here's what Wikipedia says: Quote:
This article about the roll out of Dexron VI says ... Quote:
- How to clean the power steering fluid reservoir internal filter (1) & how to replace the cap o-ring (1) (2) & why you want to fix the power steering hose drip onto the alternator (1) (2) (3) & how to debug PSP power steering pump noises (1) (2) (3) or steering rack noises (1) & a nice power steering pump autopsy photo (1) & how to flush fix cloudy ATF fluid (1) (2) and what PS fluid to use (1) (2) & DIYs to replace the power steering hoses (1) (2) (3) (4) (5). So this seems to be a good recommendation for E39 owners:
When I went to NAPA to buy my ATF I saw a bunch of different ones with Dexron III-compatible labelling. So while it may not be certified apparently companies can still label their fluids as such. The obvious risk here is that there's nobody to confirm that these fluids meet that spec since it doesn't exist anymore. Legitimate certified Dexron VI fluids are fully backward compatible with Dexron II and III, are allegedly higher quality, and run about $1 more per quart. I'd much rather pay an extra buck for Dexron VI certified ATF and not have to worry about it. No point in saving a small amount of money and end up with lower quality fluid.
My eyes... getting worse.... Nix that question, B. Can't believe I didn't notice the "power steering fluid" on the Red Line bottle.
BTW, today Vetaid replaced power steering hoses using the following method: - E39 (1997 - 2003) > HELP!!! Power steering pump drain plug locatation for bleeding Quote:
Bluebee, I don't think I did ALL fluid, I did it just enough to change the hose, but that was definitely was not all fluid.
My old fluid was exectly as new one so I decided just fix the hose and don't make more mess to parking lot I will do several more extraction during week or so anyway.
2010 X5 35d Monaco Blue/Saddle Brown with Premium/Technology/Sport/Climat, 47K SOLD - 1997 BMW 528i Silver, 116.5K BMWCCA Member # 447308 |
Ooops. I'll fix that by editing my earlier post. Thanks.
Or, we can do the M-sock mod (see video below): |
Not sure where to xref this wonderful find by the team (cn90, pleiades, & doru):
-> E39 (1997 - 2003) > PS hose assembly bracket mount, rubber cracked .... But, if you crack that particular part, there's a way (the cn90 way). Quote:
