E28 (1982 - 1988)
Old 07-10-2009, 07:09 AM
stjhrc stjhrc is offline
Mein Auto: 1984 528e
speedometer
My speedometer has stopped working. It works every so often until about 2 months ago when it has not worked since. Any ideas. The Bentley book doesn't seem to have anything in there, or at least I couldn't find it. You bailed me out before with the turn signal, hoping to strike more gold. Thanks,
Old 07-10-2009, 10:17 AM
hugh1850's Avatar
hugh1850 hugh1850 is online now
Mein Auto: 335i
I assume you checked the fuse. Other than the speedo is any other instument not working? Is your radio working?
2011 335i M-Sport
Old 07-10-2009, 10:20 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
There are two possible problem areas: The sender located in the differential or the instrument cluster. Take a look at the connector in the differential and make sure that the connectors are clean and make a good connection. You can test it by moving the wheels and connecting a multimeter to the leads and you should see the signal increase and decrease (it is a toothed gear like the ABS sensors). If that part is ok then you might need to open up you cluster and see if you have bad solder joints. This one takes skill and time, patience and did I said time? I changed the whole board on mine as it was destroyed by the battery acid!
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
Old 05-25-2010, 05:10 PM
kkau kkau is offline
Mein Auto: 1988 M5
My speedometer runs slow - about 6/10 of the actual miles (comparing to the GPS reading). Would you say it's the diff sending unit at fault? The rear differential was changed by the previous owner recently... Any ideas? Thanks!
Old 05-25-2010, 05:29 PM
Mein Auto: 1988 M5
Sorry, just to clarify - the speed indicator works fine. COme to think of it, it may not be the sensor... It could be the speedometer drive gear problem. I would have to take it out and see... In any case, any helo would be appreciated! Thanks!
Old 05-25-2010, 05:31 PM
Mein Auto: 1988 M5
Try it again - the oddometer is running 6/10 slower than the GPS. It will show 5.5 miles when actual it's 10 miles. Thanks.
Old 05-25-2010, 06:12 PM
catso's Avatar
catso catso is offline
catso
Some E28's have the typical problems that almost all old BMW's suffer from, worn cheap plastic gears. Bav Auto was selling some kits, but I'm not sure if they have them for your particular application. There's places that can rebuild them. If you do a search you might find out more. Mye28.com may be of some help also.
Old 06-15-2010, 12:46 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
I have found hundreds of times that it's the speed sensor located in the diff.
Old 06-15-2010, 05:55 AM
Mein Auto: 1988 M5
It turns out to be the odometer gears - the small gear lost half the teeth, so it only turns 6/10 on a mile. I replaced the gears - works fine now. Except I don't see the oil pressure light come on (and I forgot whether it was working or not). All light bulbs are fine, so it may be the sensor, or connection somewhere... It's fun troubleshooting...
