7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
DIY - Coolant pipe tools & procedure
Ok guys this is what is needed & how i did it. (NO LEAKS) Hope this makes any sense.
2002 BMW 745Li 2004 LAND ROVER RANGE ROVER HSE Last edited by 07841-tb; 10-17-2009 at 07:27 AM. |
Wow ! I don't need this right now but thank you so much. Its going to be invaluable when my time comes.
Any pictures by chance? |
http://www.bimmerfest.com/forums/sho...453&highlight=
2002 BMW 745Li 2004 LAND ROVER RANGE ROVER HSE |
Hey I really want to Thank you for posting this. I am a female that have no clue about cars, but I knew for sure I wasn't about to pay 7565.00 to a BMW dealer to fix this. Apparently there is and should be some kind of recall with this coolant pipe. I recently had to replace water pump, upper and lower hoses, thermostat, and this was right after a coolant flush by the dealer. After the coolant flush and replacement of these parts, got home, and coolant was leaking in my garage, next day took it back and they claimingly stopped the leak and then the windshield wiper wlasn'tskeeting water under the car when you turned them on, took it back they told me I had to pay to replace the wiper motor when there was nothing wrong with when I brought it to them. Less than a week later the service engine light came on, I took it back again after having Auto Zone read the engine light and they told me a hose was disconnected, secondary air vacuum hose, or some hose was not connected to take it back, did spoke to manager and a female tech that had no clue. They told me that now this had nothing to do with what they did and it would be 1400 to replace, I insisted that they fix and it was not one trouble with my car until they touched my car. I really believe they clearly messed up something when they put the water pump in. However they are telling me the two parts have nothing to do with eachother. Someone else tells me they do. I am asking you are there some possibilities they did something wrong installing a Reman Water Pump in Could have affected this coolant pipe?
On behalf of everyone, thank you very much for posting this! Even if some people don't do this themselves, they will surely still save a good bit of money at an indy shop or dealer knowing it can be done this way. Easily one of the most valuable posts on this board.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
Excellent write up. If i ever have that problem i still wont be able to do that type work myself.
WOW!!! You are the man and my new hero! I would have never tried this even though I have rebuilt many motors in my time. After your write up I feel confident I could pull this off if the need should arise. Many thanks for taking the time to write up, photograph and share.
02 745i (Titanium Silver-Black Interior/Roof Spoiler/Staggered 20" Breyton Wheels/H&R springs/Bell Built-in Radar Detector- Laser blocker/Sun Shades/L7/Cold Weather Package/Convenience Package/BTUM/Other stuff I have forgotten) |
Wonderful write up! Thank you for taking the time to do that !
-------------------------------------------------- 2003 745i Sport Sterling Gray/Black 2001 986S Seal Gray / Boxster Red Past: 98 540i Sport 6 944's |
ha how does it feel to be a new and loved 7 series hero
I would'nt call being a hero but THANKS ANYWAY!!! just trying to put this out there to help others.
Thanks - this seems like useful info! I hope I never have to do this though ... I just replaced the thermostat and it was quite a project! Glad I had a bike to rely on for a few weeks...
Do you need to remove the radiator to replace the coolant pipe or just buy a collapsible pipe kit from bimmerparts and do the job.
