E28 (1982 - 1988)
Old 06-26-2010, 07:11 AM
rogerwames rogerwames is offline
Mein Auto: 1988 BMW 528e
Radio antenna / reception
Hi, all...
I'm a new member, and proud recent BMW owner... except:
I have a 1988 BMW 528e... great car, great deal... 65,000 miles on it. The antenna does not raise... have searched wildly for the 'switch' and can't find it (no manual came with the car). I'm assuming the switch is the 'on' button and that something has gone wrong with the electrical connections... typical? Everything is visibly wired and connected, but the antenna refuses to go up - I can't even raise it manually.
Should I just put a manual antenna in its place?
Old 06-26-2010, 09:40 AM
catso's Avatar
catso catso is offline
catso
Originally Posted by rogerwames View Post
Hi, all...
It supposed to go up automatically when you turn on the radio. Check the connections. The easy and cheap solution is a "manual" antenna.
Old 06-26-2010, 06:07 PM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
There coluld be a couple of reasons as to why your antenna is not rising. First, is the radio a factory BMW unit? If not whoever installed might have missed connection the antenna wire (IIRC, the BMW wire is white and in most radios is blue). Second, go back and open the truck while telling someone to turn the radio on and listen for the antenna motor. If you hear it but there is no movement, all you need is a replacement mast (removing the one installed to confirm type: smooth or toothed). Third, remove the right interior trunk cover and make sure that all cables are connected to the antenna (maybe this one should have been the first one!).
Jimmy Moreno
1995 530i
1986 535i
