What is this engine part? (Getting to know my M54 engine bay)
Over time, I've come to know (by necessity) almost every large item in the M54 engine bay ... but some items still are unknown to me ...
What is this engine part? |
Air pump valve cold start, disa, heater left right valve, vanos solenoid, cvv tube to cvv, dunno last
ooooh- a pop quiz!
intake DISA valve heater valve for the dual HVAC system VANOS solenoid/ VANOS adjustment unit hose to CCV from valve cover that is simply an electrical connector you have circled, unless my eyes are missing something The "box" with all the brown wires is a common chassis ground for several things. that would be the high side. |
I look at Real OEM and the like when I need to know what I'm looking at.
http://www.realoem.com/bmw/partgrp.d...3&mospid=47584 http://bmwfans.info/parts/catalog/E3...vember/browse/ http://www.penskeparts.com/DiagramsMain.aspx?vid=47584 |
Thanks Mark,
I appreciate the help. What I'm doing is getting an annotated photo ready, for newbies and oldies alike, with all the visible parts labeled. That way, anyone who opens their hood would know what everything is! Thank you for taking the time and energy to help me in that endeavor! |
glad to help!
I wonder what the air filter looks like? Rather dusty where that vehicle is operated.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Here is a picture of the old engine-air filter and the new filter side by side.
The old one looked OK but I replaced it anyway. It won't rain here for the next 10 months and I take the bimmer for a drive over the mountains at least once a week, so, there is a lot of dust in the mountain roads. Do you guys actually "wash" the engine? I've never done that as I'm too afraid I'll wash the oil out of things that need grease and electrical components that aren't supposed to get soaked. |
I wipe mine down with a damp cloth, that is about it. I don't do that often either. I've never been one to detail an engine, I just don't have the time or energy to devote to it.
I clean mine two to three times a year, I've done it on all my cars and my wife's as well. I use a generous amount of Simple Green from a pump spray bottle, a soft paint brush for stubborn spots and a stiffer brush for really stubborn spots (like around the power steering cap and bracket) and a gentle spray from a hose to wash the grime/dirt/grease away, top and bottom. I will dry what I can with a towel or rag then drive the car until the engine bay warms up enough to dry the remaining water. Sometimes I will "condition" the plastic and rubbery parts with a protectant like Armorall. Be sure to cover your power steering reservoir cap with a plastic bag to prevent water from entering thru the small weep hole before spraying anything! You may need a few paper towels to soak up the water that will accumulate in the wells on top of the struts, too.
"The wise speak of only what they know." |
Following your caution, it makes sense for me to recommend the use of Meguiar's Silcone Free dressing or a similar product. Works the same on rubber, plastic and vinyl without the danger (and it won't discolor tires, intake ducts, etc. if used often, as Armor All would).
I mix up a bucket with very warm water and Dawn dish soap, Wet the engine bay down first with a light spray of water, then use a wash mitt and the Dawn mixture to suds up the engine bay, then rinse it off with a light spray, and blot it dry with a few old towels. The dawn cuts grease and oil quite well, but if you get it on the body of the car it will also remove every speck of wax. In fact, I use it for stripping wax when I'm doing a full detail on the paint. As far as water causing problems, a light spray isn't a problem, but NEVER use a pressure washer or coin-op high pressure on the engine.
And yes, you can go crazy and detail the entire engine compartment:
chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
Been using it for years, how much could really be sucked in and where could it be sucked in from.
Oh my! I'm never posting a picture of my (dusty) engine ever again!
![]() PS: Is it silicone or silicon that you are worried about for the 02 sensors? |
#25
This picture seems showing the high pressure one. It is large and close to the tank and radiator. It is connected to a junction where other pipes are also connected.
The low-pressure one seems to be towards center and right side of the engine. It is connected to a pipe. Smaller cap on this port. However, the valve came with the can does not fit well (popped the outer valve) and freons leak from the system when i tried connecting and the pressure shows high (60 psi) in the beginning of red zone. Now I see the air that blows from both the vents inside the car are not cooling. May be another problem that does not give cool air. -Rabi |
