Old 07-12-2010, 01:58 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Bentley Publisher Release E60/E61 5 Series Manual
For the 5 Series Do-It-Yourself (DIY) owners, today is a good day. Bentley Publisher, regarded as producing the highest quality technical manual on the market released their E60/E61 manual. If you haven't heard of the Bentley manuals perhaps you've heard of the cheaper part story brands of Chilton or Haynes? Think of this as the M5 manual next to those two Honda Civic manuals.
The BMW 5 Series (E60, E61) Service Manual: 2004-2010 contains in-depth maintenance, service and repair information for the BMW 5 Series from 2004 to 2010. The aim throughout has been simplicity and clarity, with practical explanations, step-by-step procedures and accurate specifications. Whether you're a professional or a do-it-yourself BMW owner, this manual helps you understand, care for and repair your BMW.
Check out this sample section on Front door window, removing and re-installation to get a sense of the details Bentley provides
The do-it-yourself BMW owner will find this manual indispensable as a source of detailed maintenance and repair information. Even if you have no intention of working on your vehicle, you will find that reading and owning this manual makes it possible to discuss repairs more intelligently with a professional technician.
Models covered
525i and 530i
* M54 engine (2004-2005)
* N52 engine (2006-2007)
528i
* N52K engine (2008-2010)
535i
* N54 twin turbo engine (2008-2010)
545i
* N62 V8 engine (2004-2005)
550i
* N62 TU V8 engine (2006-2010)
Manual transmissions (remove, install, external service)
* Getrag GS6-17BG
* ZF GS6-37BZ , ZF GS6-53DZ
Sequential Manual Gearbox (SMG - remove, install)
* ZF GS6S37BZ, ZF GS6S53BZ
Automatic transmissions (remove, install, external service)
* ZF GA6HP19Z, GA6HP19Z TU
* ZF GA6HP26Z, GA6HP26Z TU
Technical features:
* Condition based service (CBS) maintenance procedures from replacing the cabin microfilter to checking and resetting service intervals. This manual tells you what to do and how and when to do it.
* Cylinder head cover gasket and crankshaft seal service (includes removal and installation of Valvetronic motor).
* Cooling system and radiator service.
* Fuel injection and ignition system diagrams and explanations.
* Information about advanced technical features such as Valvetronic, VANOS, twin turbochargers, DSC (dynamic stability control), dynamic drive (active stabilizer bars), active steering, and xDrive.
* Suspension repair procedures.
* Brakes, steering and ABS troubleshooting and repair.
* Heating and air-conditioning repair, including A/C component replacement.
* Body and hood repairs and adjustments.
* Electrical system service, with an easy-to-use illustrated component locator section.
* Comprehensive wiring schematics, including fuses and grounds.
* BMW OBD II diagnostic trouble codes, SAE-defined OBD II P-codes, as well as basic scan tool operation.
* BMW factory tolerances, wear limits, adjustments and tightening torques.
You can pick up a copy for about 2/3s the MSRP price at Amazon.com here
ID:	238023   Click image for larger version
Old 07-14-2010, 10:13 AM
pix335i's Avatar
pix335i pix335i is offline
Enthusiast
Mein Auto: E92 335i Coupe
That is great that they finally got this out!
2007 Montego Blue 335i Coupe | 2014 X1 xDrive28i
Old 07-16-2010, 05:31 AM
ptabaco ptabaco is offline
Mein Auto: 2013 X5 xDrive35i
I received my copy yesterday. Thank you Bimmerfest por a great service.
It looks so nice that I don't want to take it out of the plastic wrapping
2016 F15 - X5 sDrive35i
2013 E70 - X5 xDrive35i - Gone
2010 E60 - 528i - Gone
1998 E39 - 528i - Gone
1991 E30 - 325i - Gone
Old 10-09-2010, 04:59 PM
CL601Pilot CL601Pilot is offline
Mein Auto: 2006 525i
How about a PDF version? Any word?
Old 02-02-2013, 06:57 PM
stevendc stevendc is offline
Mein Auto: 2013 328i
I own these as well.........expensive but worth it.
Old 02-02-2013, 07:26 PM
1naztyx5 1naztyx5 is offline
Account Under Review
Mein Auto: E70 X5/E60 528i
Wow a must have!
Old 02-02-2013, 08:27 PM
Got mine on eBay.......do a search and see there are more.
Old 02-05-2013, 02:43 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
definitely a must have.... and if you need one
http://www.bimmerzone.com/BMW_Servic.../BNT-B510.html
Cheers!
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
product review
