Old 03-31-2008, 06:53 AM
PUZZ PUZZ is offline
Mein Auto: 08 X5 4.8i & 07 530xiT
iPod/USB vs. AUX Plug.
Other than the integration into iDrive, what is the advantage of the iPod/USB integration over the standard AUX plug that is standard equipment?
Old 03-31-2008, 10:18 AM
cross5x cross5x is offline
BMW Lover
Mein Auto: 2008 Bmw X5
It charges your iPod.
'08 X5 4.8i Black/Black
I just LOVE my X5.
My Garage- http://directory.bimmerfest.com/user...wUser&UId=4371
Old 03-31-2008, 06:03 PM
pureflames pureflames is offline
Mein Auto: 2007 x5 blacked out
what hardware is involved with the iPod/USB integration? does it fit into the AUX input in the center armrest via the Y-Cable?
Old 02-20-2010, 01:04 PM
Pootz19 Pootz19 is offline
Mein Auto: 2007 X5 3.0
Recognizing that the aux cable will not charge the ipod, can you use the aux cable to transmit sound and also use a separate charge cable in the 12V connector at the same time?
Old 02-20-2010, 01:53 PM
RedRockin RedRockin is offline
Mein Auto: X5
Probably, I suggest you ask your salesperson to verify. I ordered my X5 with the iPod/USB because I wanted to be able to load MP3 files to the car's hard drive via the USB port. There was absolutely zero indication, in any if the BMW documents, to indicate that the vehicle already comes with a USB port in the glove box for this exact purpose. So, while I am not 100% sure I have this correct, I am at least 95% certain that I could have saved myself the $400 option that puts an ipod and USB connectors in the center console. From post I have read in these forums, it appears that the additional USB port in the center console is only for playing music directly from a USB connection while the USB port in the glove box is for downloading to the hard drive and I am 95% convinced the one in the glovebox comes as standard equipment even if you do not pay for the iPod/USB. Thus, any files you have on an iPod, you can use your computer to drag and drop onto a USB thumb drive stick (cheap - about $20 for a 4GB stick and less than $30 for an 8GB stick). Then you can simply plug that stick into the USB in the glove box and download to the hard drive. Once you have filled the HD (12.5 GBs) you can continue to use the USB port in the glove box to play additional files and you can have multiple thumb drive sticks so you have potentially endless supply of music.
Using the iPod does give you more capacity in one place (on the iPod if you have a 40 GB or larger iPod). But not many people actually have THAT much music (some do but not many).
Finally, I suspect (not sure as I don't even have an iPod to test this theory) if you pass on the ipod/USB and connect your iPod via AUX (and use the 12 v to charge), I think you will have to use the iPod to change songs and navigate thru your music. If you have the iPod connector, I THINK you can navigate the ipod's music through your iDrive.
Again, I suggest you verify ALL of this with your salesperson but if I am correct, you can save yourself $400 by simply copying your iPod music onto a USB thumb drive stick and loading to the HD. Oh, BTW, my salesperson told me (at delivery) that the HD's 12.5 GBs are shared between music files and stored/saved NAV points. I do not know how much HD space each saved NAV point uses but I doubt it is very much. If you only have a few stored NAV points this would not be much to worry about but if you have many NAV points to permanently store - it will likely reduce your music capacity to that extent.
All I can say is that I am still absolutely furious that no-one told me the vehicle comes with the glove box USB for downloading music to the HD. As I said, I don't even have an iPod so I did not need that $400 option. And, I have even re-searched through the X5 brochure and all dealer supplied options lists and that glove box USB port isn't listed anywhere!
Old 02-20-2010, 04:08 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Just as a heads-up to people reading this thread, there's also another way to load music files onto thr X5 hard disk.
Just the other week I wanted to load my modest collection of songs from i-tunes onto the hard disk in my X5. Not having a large capacity memory stick, I found the easiest way was to simply use itunes to make a "back-up" DVD with all the songs in Apple's AAC format, and then just put the DVD into the CD/DVD slot and save all the songs to the X5 hard disk. Now all the songs are in the X5 and still in the native ipod format, without a need to change all the files to MP3 format.
And now I've got a DVD as a backup for all the music in the X5.
Old 02-20-2010, 04:22 PM
Mein Auto: X5
funny, I knew I could burn my files (pretty much all Mp3 and wav but also all in itunes) and load to car from CD. Just figured with my collection that would take a long time and it would be so much quicker to drag/drop and load thru a thumb drive. What never occurred to me was burning to a DVD which has so much more capacity than CDs.
Still, amazed that the glove box USB port for loading is not mentioned anywhere in any of the docs and the SA didn't mention it either! I guess they don't want us to know so we will throw down another $400
Old 02-20-2010, 06:05 PM
kutchins kutchins is offline
Mein Auto: 2010 X5
Just to see what it would do, I hooked my iPhone to the glove box USB port and it indicated it was charging. I kind of remember the manual saying it wouldn't.
I didn't leave it connected very long so I don't know if it would have fully charged the phone, but it would have been good to know on my first road trip the other day when my out-of-car phone usage nearly drained the battery.
Old 02-20-2010, 10:20 PM
R6soldier R6soldier is offline
Mein Auto: 2008 Acura MDX/ Yamaha R6
how big is the hard drive for the 2010 x5 35d?? i thought my dealer said it was a 50gig
can anyone correct me on this??
Old 02-20-2010, 10:27 PM
Mein Auto: X5
I have read few different numbers ranging between 50-80 GBs but regardless of actual most is used by the Nav system (possible other vehicle software as well). All reports are that 12.5 GBs are allocated for music. And, as I posted above, my SA told me that 12.5 gets shared between music and storing saved navigation "location" points. Haven't seen or heard any confirmation about this last part but it makes sense. If 12.5 GBs are user allocated, some would be used for storing saved nav points.
Old 02-21-2010, 07:48 AM
Marwan Marwan is offline
Mein Auto: 2012 X5 xDrive 35d
Absolutely. I have my ipod connected through the auxiliary input for sound transmission, and connected through a separate Belkin charging cable to the 12v connector to keep the ipod juiced up and the system works flawlessly.
Old 02-21-2010, 02:02 PM
Thanks. Exactly the answer I was looking for.
Old 02-21-2010, 02:20 PM
AM123 AM123 is offline
Mein Auto: BMW X5, Mercedes ML350
If u uses MP3-player instead of I-pod then through I-drive u can change songs and etc.. if u connected it through USB-port. And since USB -port also gives in the reverse direction electric power it charges MP3-player.
Otherwise if u connected it through AUX u are just giving low volume audio signal ( as to headphones) to the main unit of the car which amplifies it and gives to speakers in its order. Disadvantage of AUX in the case of MP3-players: 1) it is not charging (2) u'd manually push buttons on MP3-player to change songs.
AUX is simply "line-in" port as usually in all audio devices.
Old 02-21-2010, 02:31 PM
Mein Auto: X5
Anyone ever try to use this USB port to connect a Blackberry for music and/or Pandora? If yes, which BB are you using and are you using the standard USB cable that comes with the BB (micro USB to phone and regular USB to car)? Or, will only a double male 3.5mm work? Thanks.
Old 02-21-2010, 08:59 PM
sampsonite sampsonite is offline
Mein Auto: x5
Is it just the 2010 or newer x5s that have this hd capability or does it include the 2009 idrive harddrive?
Old 02-22-2010, 08:39 AM
CHUBZUBZ CHUBZUBZ is offline
Mein Auto: BMW X5
If you have the IPOD/USB attachment and leave your IPOD connected after you turnoff the car are you still drawing power from the car battery?
I'm hoping this is not the case. If so, anyone have any idea what kind of power draw it consumes?
Old 02-22-2010, 08:46 AM
andrew062 andrew062 is offline
Mein Auto: 330i, X5
@sampsonite - its only on 2010 and newer
i have the 09 idrive and i use got myself a nifty 64gb usb stick. works really well if you dont have an ipod.
Old 02-22-2010, 10:38 AM
Mein Auto: x5
I've got an mp3 player that works but preferred using a usb stick because I just leave it in the car. I enjoiy starting the car and having the music immediately qued up. Unless I won't be driving the car for a few days, I leave the usb stick plugged in without any trouble.
Old 07-14-2010, 10:22 AM
JBIZZ JBIZZ is offline
Mein Auto: 2011 335i E90
Best idea I've heard. I didn't know you can play AAC files in the car, I thought they would have to be converted to MP3s. Am I wrong?
I have my car on order, or else I'd confirm myself.
Old 07-14-2010, 12:09 PM
Funf Dreisig Funf Dreisig is offline
Mein Auto: 77 530i & 09 35d
On a 2009 35d, the answer is NONE.
BMW correctly labels this option iPod/USB integration. It does work with the iPhone, but ONLY the iPod app on the iPhone (or iPod Touch) can be heard via the X5's sound system. So forget listening to Internet Radio, etc. while plugged into this $400 USB port and Y cable.
I wish I had understood this when we ordered our 35d. Now we have a $400 USB port in our center console that we hardly ever use.
Funf Dreisig
Old 07-14-2010, 12:17 PM
I thought it would require MP3 as well, but tried it with the AAC files and it worked. Well, mostly.
I found that it would copy the AAC files which I put into itunes from my CD collection, but the few songs I purchased, it would not copy. I suspect it sees some copy protection code and doesn't copy the songs purchased from the itunes store. Those you probably have to convert to MP3's to copy to the BMW HD.
Perhaps it will copy song purchased from the itunes store under the new non-limited use pricing, but I haven't tried it.
Old 07-14-2010, 12:26 PM
hsindogg's Avatar
hsindogg hsindogg is offline
Mein Auto: 2011 xDrive35d
Isn't the AUX input analog, therefore the Y-plug does Digital to Analog Conversion? I would assume you would lose sound quality in the DAC, where as USB to USB is straight digital so there should be no sound quality loss.
I only use the USB port with a 32GB memory stick loaded with 256kbps MP3's encoded with LAME codec. It blows HD-Radio/Sirius out of the water.
My point is, if you have the iPod you should probably use the USB input and not the AUX input since it should yield better sound quality. But someone correct me if I'm wrong since I don't use an iPod.
Sparkling Bronze 2011 X5 xDrive35d
Premium, Technology, Sport Activity w/ 20" 214's, Cold Weather, Premium Sound, Rear Climate, Multi-contour seats, Comfort Access, Roof Rails, Oyster Nevada leather
Old 07-14-2010, 01:30 PM
Sea Doom Sea Doom is offline
OCD Afflicted
Mein Auto: '10 X5d & '08 EX35
Funf Dreisig
A contraire, mein freund Hill Country. I think it was you that relayed instructions on how to make this happen with a series of hand slights (nee, soft resets) on the iPhone. Might be MY specific, but I have no problemo streaming WWOZ via 3G into the '10 X5d sound system via the Y cable option. I did exchange the delivered Y cable for an upgraded ver. when the original proved to not be charging the phone.
Old 07-14-2010, 02:43 PM
samsonitep samsonitep is offline
Mein Auto: BMW
So let me get this straight..
I am getting a 2011 X50i.....now if I have an iphone 3gs now if I don't get the 400 dollar ipod option I can put music on my flashdrive, plug it in the glovebox USB and upload on to my car..
then take the USB out and the music will be CD quality on my car???
can anyone confirm this?
Old 07-14-2010, 03:11 PM
Yes.
e70
