1995 740i stop engine oil pressure low warning - Bimmerfest - BMW Forums
Old 05-19-2010, 09:36 AM
marlonb007 marlonb007 is offline
Mein Auto: 740i
This warining popped up this morning after braking suddenly. The low oil light did not come on just this warining. The warning went off 30 seconds later and did not come back on
Old 05-19-2010, 02:58 PM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
Welcome! I'm rerouting your thread in hopes you can get some help!
Old 05-20-2010, 12:23 AM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
i particularly remember that happening with my old honda when the oil level was low. check the oil level? if not a condition of low oil level, might check have the oil pressure sensor/s checked out making sure the connector isnt broken or incorrectly attached.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 07-25-2010, 12:05 PM
JUNEBLOOD JUNEBLOOD is offline
Mein Auto: BROOKLYN
Did u check the oil
Old 07-25-2010, 04:53 PM
tommyb2b tommyb2b is offline
Mein Auto: 1998 BMW 740IL
Its probably the bolts that hold the oil pump on. In the 1995 year especially these are known to fail. Open it up and tighten those bolts!
http://www.cardomain.com/ride/240317/5
Old 07-27-2010, 11:56 AM
farid740il farid740il is offline
Mein Auto: 2000 740il
need to change oil or add oil it need 7.9 Quarts of oil so hope that helps buddy
Old 07-27-2010, 09:54 PM
Mein Auto: BROOKLYN
That happen to me and then the motor went the timming chain got loose while i was driving and was clicking loud as hell
