Old 01-14-2008, 08:29 AM
cngizbleevng's Avatar
cngizbleevng cngizbleevng is offline
hardtop potentate
Mein Auto: 2001 Z3 3.0i Steptronic
Post z3 Seat Swap DIY--older seats into newer car
Recently, when I bought second-hand black leather Z3 seats to replace my blue leather seats, I discovered that the electrical wiring had changed during the course of Z3 production. I'd need to rework the electrical wiring if I wanted seat adjustment, heat, and occupancy sensors to work correctly. After many months of stalling, and occasionally taking another befuddled look at the wiring, I decided to just dive in.
Wiring diagrams were of no real help, since the wiring colors didn't match what was present on the seats. I purchased a complete wiring harness in the hopes that I could scavenge the needed parts. In retrospect, that wasn't necessary, but it did help me determine which wires on the seats connect with which wires in the car.
I'll be the first to admit that I'm no wiring expert, and I offer these instructions simply as a helpful guide to you if you're contemplating the same mod. There may be other approaches that work better, and these instructions may not pertain to all seats and all year vehicles. In this case, the seats are 01/97 production and the car is 04/2001 production. I believe the wiring changed in 04/99 with the 2000 model year cars, though there may have been other iterations along the way. Also, I believe the ///M seats maintained the earlier wiring throughout production....
Supplies Needed:
~ 10mm, 13mm, 16mm sockets w/wrench
~ adjustible wrench
~ hammer
~ blankets or towels to place seats on (they'll be upside-down alot of the time)
~ wire stripper and crimper tool
~ butt connectors, blade connectors, wire nuts, or soldering tools
~ portable lighting to see under seats
~ plenty of workspace at the side of the car
~ several hours to complete the task
Step 1:
Use the power adjuster to raise both seats as high as they'll go--this will give you more working room under the seats later on. Slide both seats back far enough to expose the nuts on the floor at the front of the seats' rails. Use the 13mm socket to remove all four nuts (two for each side of each seat). Next, slide the seat forward to expose the nuts at the rear of the rails. If your seatback is reclined, release it to full upright position to get better access to the rear. These nuts will now be removed with the 16mm socket. Now use the adjustible wrench to remove the bolt that holds the seatbelt to the seat base, and in the case of the roadster, work the strap out of the seatbelt guide at the top of the seat.
Step 2:
Disconnect the negative battery cable using pliers or the 10mm socket. Make sure you have your car's stereo code #--once the battery is reconnected, you'll need to reenter the code to use your stereo.
Step 3:
Tilt the seatback rearward as far as possible--this will allow better leverege for working under the seat, and also easier removal from the car. lift the back of the seat forward toward the windshield and get in behind it with lighting so you can see where the connection from the floor meets the seat connection. It is a yellow and black boxlike plastic structure that is fastened to the seat bottom. You can twist it to unfasten it from the seat. Once it's unfastened, the wiring can be disconnected by pulling on the black plastic piece on the side labelled 'a' in this image (The connection is shown already disconnected):
Here is an image of the connection that comes out of the floor (already disconnected):
Step 4:
Remove the seat from the car being careful how you lift and swing it out--It's easy to gouge your sill plate or center console. Set it upside down on the blacket or towel for easy reference to its underside. Set the replacement seat near it so you can compare the connections.
Step 5:
Remove the black plastic 'caps' on the floor's yellow connector for easier access to the wiring. Remove the cap on the seat-side connector as well.
Step 6: Passenger Seat only
Look at the underside of the replacement seat and you'll see the "seat occupancy sensor" which is shown in the following image. This needs to be connected in order for the seatbelt tensioner to fire and passenger side airbag (if equipped) to go off in event of an accident. The airbag indicator lamp will light up on your instrument panel if this is not connected when the battery power is restored. You will then have to pay for either the reset tool or a trip to the dealer to reset it. The driver's side doesn't have the occupancy sensor--the car assumes there is a driver present in the event of a crash. This image shows it disconnected--a white plug inserts where the arrow is:
Step 7:
On both replacement seats you'll see connections like the following:
The black plug is for the heating feature, and the white plug is for the seat motors. Because I had bought a separate wiring harness, I was able to salvage the parts that plug into these and make the following connection using butt-connectors (you can use blade connectors, wire nuts, or solder if you prefer). If you use butt-connectors, gentle pulling will ensure that you've crimped them sufficiently.
As I hope you can see, I only cut and rewired what was necessary to make the circuits complete. Some of the wiring from the old seats was compatible with the wiring in the yellow floor connector, and I plugged those seat wires right into the yellow seat-side connector as shown is this image (the central three blocks of wiring in the connector):
The outside blocks of wiring--one at each end--are what were converted to the old style plugs.
Place the replacement seats back into the car and get in behind them to reconnect everything. Reconnect the battery cable and test your connections.
I don't know what some of the connections were for, but none of it was redundant, and they've worked well since completion. This isn't the complete story, as I've forgotten some details in the 2 weeks since I did this. Questions, comments, or corrections are welcomed, but please post replies to the following thread:
http://www.bimmerfest.com/forums/sho...d.php?t=255325
Old 05-04-2008, 04:39 PM
GBimmer GBimmer is offline
Banned
Mein Auto: 1998 M Roadster
How to fix trashed roadstars: http://www.bimmerfest.com/forums/sho...d.php?t=282991
Old 05-18-2008, 05:42 PM
jaspendlove jaspendlove is offline
Mein Auto: A multitude of cars
well I did a DIY for the code p1423.
here is the link
http://www.bimmerfest.com/forums/sho...ighlight=p1423
Old 05-23-2008, 11:11 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Fuel tank strap cushion fix:
http://www.bimmerfest.com/forums/sho...d.php?t=281932
Daniel
2002 M roadster
Old 07-12-2008, 05:24 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
S54 coil bulletin
Old 11-16-2008, 01:54 PM
Finaidoc Finaidoc is offline
Mein Auto: 1996 Z3 Roadster
Question 1996 Z3 seat rail bushings
Does any one have installation instructions ?
Old 11-28-2008, 08:05 AM
Ron Stygar's Avatar
19,585 Miles
Hose Job: Z3 non M hose
Old 01-16-2009, 07:32 PM
Ron Stygar's Avatar
19,585 Miles
Lets remove the Z3 door panel (part one)
Old 01-16-2009, 07:33 PM
Ron Stygar's Avatar
19,585 Miles
Lets remove the Z3 door panel (part two)
>>>> SEE ABOVE POST #58 <<<<
Screws are one use.
Pin tool is now $76.74r
Hook tool is now $34.51r
Removing outside handle:
Lock Cylinder removal:
Old 02-16-2009, 08:19 PM
Ron Stygar's Avatar
19,585 Miles
Replacing Flexible disk
Old 02-17-2009, 06:46 AM
Ron Stygar's Avatar
19,585 Miles
Operating Fluids Group 11
Old 04-23-2009, 06:44 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
Upgrading 1.9 non-.vented brakes to vented rotors.
http://www.houston-bmwcca.com/z3/Tech-Tips/Index.htm
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 08-22-2009, 07:59 PM
Ron Stygar's Avatar
19,585 Miles
Bulletin sib 12 01 03
Old 10-25-2009, 10:38 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
The Z3 FAQ post is for how to content. Please do not post in this thread asking for specific information not listed in this post. Please create a new thread in the general Z3/Z4 forum with your questions–you will get better responses this way!
Follow us on Facebook for news and current promotions
08 E82 135i | 02 Z3 Coupe | 01 R1100S
Old 01-03-2010, 10:30 AM
Ron Stygar's Avatar
19,585 Miles
Z3-M coupe (S52) Data
I knew the sunroof headroom was more.
Never noticed the head room data without or with sunroof.
Old 01-23-2010, 01:46 AM
maxwell123 maxwell123 is offline
Banned
Mein Auto: santro
nice links ..i got useful info from the links...thanks....
Old 01-23-2010, 10:27 PM
Ron Stygar's Avatar
19,585 Miles
Z3/318ti HVAC
See this too.
http://www.bimmerfest.com/forums/showthread.php?t=17021
Old 05-06-2010, 08:44 AM
wbbaz wbbaz is offline
Mein Auto: 97 328ic
Went to your highlighted "Skins seat bushing lineup" but I was taken to an unrelated site. I have an 98 Roadster with about 52K and the seats are loose. Will the bushing kit from BMW fix this problem?
Thanks.
BB
Old 05-06-2010, 09:43 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
wrong place to post - but Order bushing from http://www.whalenshiftmachine.com/
and check out the You tube video
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 06-21-2010, 03:53 AM
z3power's Avatar
z3power z3power is offline
Dragon Master of TEXAS!
Mein Auto: '00 Z3-2.8L, '07 335i
My website....http://www.z3power.net
Ciao! - - Nathan
2000-2.8L Z3 StahlGrau Roadster (some mods) ~ 2001-335i (BONE STOCK!)
BMWCCA Tejas Chapter & iZ3 Project Coordinator for the San Antonio area
FEAR MY TWO SEATER!!!!!!!
Hello, I'm a MOD-A-HOLIC, check out my site to see my addictions! www.Z3POWER.net
Member Since May 17, 2002
Old 07-30-2010, 12:41 PM
Mike Clark Mike Clark is offline
Mike
Send a message via ICQ to Mike Clark Send a message via AIM to Mike Clark Send a message via Yahoo to Mike Clark
Mein Auto: 2006 BMW M Roadster
Recently inspected a 2000 M Roadster for sale for a fellow board member. As part of the inspection noted a problem with the temperature control which I think is becoming fairly common on the older cars that spend lots of time outside. Accordingly, I think this link is appropriate.
http://www.bimmerfest.com/forums/sho...+control+issue
Mike
2006 M Roadster Imola Red
2000 M Roadster Imola Red (gone but not forgotten)
1997 Z3 2.8 Roadster Red (gone but not forgotten)
2008 328i Sedan Gold
Old 07-30-2010, 01:04 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I have invested in metal balls, taps, etc to fix this. I even bought a drill press to make sure the hole was straight.
If anyone wants me to fix their lever arm, they can mail it to me and I will repair and return it for $15.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 08-30-2010, 10:10 PM
dwm's Avatar
dwm dwm is offline
slk32 hasn't been around in a while, but this post from him should be in the FAQ since all of the Z3's suffer from the blend flap getting stuck and it's getting more expensive to deal with the consequences (broken flap control arm). What I mean is that instead of linking to it, it'd be nice to have it copied into the FAQ.
http://www.bimmerfest.com/forums/sho...5&postcount=11
Daniel
2002 M roadster
Old 10-01-2010, 06:59 PM
Z3PO Z3PO is offline
Mein Auto: 2001 BMW Z3 3.0i
Exclamation Everything TIS for Z3!!!!
Behold! The holy grail of repair documents for Z3! The BMW TIS Sheets!
CLICK HERE!!!!
2001 BMW Z3 - 3.0i - Hellrot II - 100% OEM; Down to the Tires (Dunlop 8080E)
Old 11-06-2010, 08:37 AM
BillyRVing88 BillyRVing88 is offline
Mein Auto: 1996 Z3
Winter wheels & Tires?
I have a '96 Z3 1.9 w/current 16". Have an opportunity to buy 225/50R17 BMW wheels & AS tires? Will they work? I need new AS tires! Can order Continentals, but this is a pretty good deal? What do you think?
