X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
#26
Sorry mish, this one line of yours opened up for some fun on this hot and humid summer day in NY.
#27
By all means, take a swag at it...
--------- Hers : 2013 335xi Imperial Blue/Black with lots of stuff... His : 2013 X5 35d Deep Sea Blue/Black with all packages Previous : 2010 335xi Monaco Blue/Black with just about every option... Previous : 2008 X5 4.8i Space Gray/Black with just about every option... |
#28
On the second point, there is a legal mistake in BMW's stated warranty and maintenance booklet that creates a problem for them. While their policy is how you've outlined, they WILL, when pressed by someone that can press the issue, agree to cover DEF service outside of the oil service. in your case it is a no-brainer, you were not using DEF at a high rate, rather the BMW dealer service organization was not doing their jobs. (Or your def system was/is defective.) A |
#29
Should I try to get the dealer to fill it for free, or just schlep myself out to buy some and fill it up myself? |
#30
Great discussion and worth a read for those considering d
94 530i sold (That was difficult for me) 01 530i >144,500+ miles SOLD ![]() 06 330XI winter's especially fun drive (SOLD) 10 M3 Sedan (sweet) 13 Nissan GT-R Black Edition ![]() 13 Porsche Cayenne Diesel ![]() BMWCCA 4215 |
#31
If it runs out of DEF that soon, it either was not filled when you got the vehicle, or the pump from the primary to the secondary tank is not working. I would insist the dealer address the issue, even if they fall back on the new BMW policy that DEF refills outside of the oil change interval are the owners responsibility. I suspect the dealer will argue, but unless people push the dealers hard on this issue, BMW will do nothing to correct it. BMW typically does not fix the squeaky wheel, but they generally do when the wheel begins to smoke. |
#32
Almost certainly, a warning on a new 35d at 3-4k is because both tanks were not filled properly or the larger passive tank is not refilling the small active tank do to a malfunction. The dealer should fix this at BMW's cost. What is troubling is that this was a PC delivery. There have been a few reports that the connections that allow DEF to be transferred from the passive to the active tank were either never established, or failed due to pinched lines, broken parts. etc. FWIW the active tank is in the front clip* that is installed intact, fairly late in the assembly process. There are a lot of connections between the main vehicle and the front clip that could be incorrectly assembled (e.g. wiring for the headlights, other lights. headlight washers, turbo intercooler, DEF plumbing and wiring, etc.). A mistake in most of these connections would show up quickly in the final QC inspection at the factory (e.g. headlights don't come on, coolant leaks, etc.). OTOH it appears that the final QC on the DEF connections/functioning is done by 35d owners 3-4k miles later ![]() Funf Dreisig * right front fender just behind the headlight. Last edited by Funf Dreisig; 08-01-2010 at 09:30 AM. |
#33
when i shut off the engine, i hear some pumping/hissing noises once in a while in around the area of active def tank... I wonder if that is when the transfer takes place ?
#34
![]() In addition to the passive->active DEF transfer you suggest, there is the possibility that these noises have to do with recovering the DEF that is between the active tank and the DEF injector so that in cold weather this DEF would not be subject to freezing. ![]() Funf Dreisig |
#35
#36
If I wouldn't have stumbled across this thread I might have never known about this useless emissions feature on the vehicle. Ive been on the forum for a week or two to find out as much as I can before my purchase, and this DEF feature is definitely a factor for reconsideration.
My first question would probably be, how do you disable DEF it and override the sensor? |
#38
Correct. The EPA would not approve/certify any engines using the SCR system unless it included a system which "could not be overridden" to prevent continued operation without DEF for the SCR system being present. Can the system be overridden? I'm sure that it is possible. But I also believe it would be a lot easier to just make sure the vehicle had DEF. After all, you do get a thousand mile warning, and most truck stops sell DEF. |
#40
But thennnn ... he called later in the day to say that my passive tank was full and transfer pump was bad; they had to order one and it would be in tomorrow. And thennn ... when I went in at the end of the day to pick up a loaner car, he said that a pump had come in on the parts truck this afternoon and he was psyched that he was going to have my car ready, until ... it still didn't work when they replaced the pump! At this point they don't know what's wrong. Oh my. |
#41
As I posted previously, there have been reports that the line between the passive tank and active tank was "crimped" during assembly. Of course this would stop/slow the transfer of DEF. This may not be your problem but it never hurts to check the plumbing before you replace the pump ![]() Funf Dreisig |
| Tags |
| diesel, exhaust fluid, roadtrip, run flat tire, x5 |
