Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 08-07-2010, 05:02 AM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
DIY - Voice Command Retrofit
I just retro-fitted Voice Command into my '02 ACS7 as it was the only module that wasn't fitted.
Before you start you'll need to already have the Telephone fitted and the Voice Command button on the Steering wheel....
Super easy to do .....all you need is :
1 off Voice Command Module
1 off Retro-fit Cable Harness part no. 6112 0148 343 ............(which is just two fibre optics, one power & one ground cable connected to one connector that goes to the voice command module)
You just connect the two Fibre optics inline with the Nav Module then just connect the Ground cable (Brown/Black) to the car chassis ground connector & connect the Power cable (Red/Green) to the HI-Fi connector (which is right beside the ground one).....
That's it ....all working.....no coding required !!
My BMW ACS7
Closed Thread
