Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 08-10-2010, 04:36 PM
wpacello wpacello is offline
Mein Auto: 740i
Module for turn signals, lights, etc
Has anyone had problems where their turn signals, hazards, high beams not operating while the headlights stay on?
This is a 1998 740i and I was told it was some type of module. I would like to find out the exact part number so I can get pricing.
I have a leak - I assume it's a moon roof leak - which may have caused the fault.
Old 08-11-2010, 04:08 AM
Adi's Avatar
Adi Adi is offline
Mein Auto: E38 750iL, A6 (4f) Avant
I guess you need the LCM (Light and Check-Control Module) which will be about $500 from a dealer ---> http://www.realoem.com/bmw/showparts...20&hg=61&fg=25
Yes, I had similar problems with my E39. Indicators would not work correctly, etc. It needed a new LCM - make sure you pick the right one because it depends on whether you have Xenons or not.
An LCM will need coding to your vehicle, so you will probably still need to go to a dealer workshop to get that done. (At least this was the case on the E39 same model year so I don't see why it would be different for the E38).
Audi A6 Quattro Avant (2007) - Oyster Gray Met.
E38 750iL (1995) - Cosmos Schwarz
Sign by Danasoft - Get Your Free Sign
