Old 04-10-2002, 10:00 PM
Polar Bear Polar Bear is offline
Send a message via ICQ to Polar Bear
Mein Auto: '99 M Coupe
best way to get at teh Cylinder Heads?
hi all, I have a rather strange project going, and need to get down to the cylinder heads (not actually inside, just free access to the sparkplugs).
has anyone dissasembled the top parts of the engine (plastic covers and such) and gotten down that far?
TIA
PB
Name:	egt&cht guage.jpg
Old 04-11-2002, 06:23 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
What Model (98-00 or 01-02)?
It's not hard to get to the plugs.
Just remove the bolts holding on the covers.
Where (on the headers) are you getting the EGT?
On a more modern note, when I put a Buick 3.8 V6 into an MGBGT that I had, I put an O2 sensor in each header collector and monitored the A/F ratio that way.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 04-11-2002, 08:25 AM
tolerences too close just getting to plug
the 6 inches of tube that you have to dive down into is not wide enough to acommodate the wrench socket and the CHT sensor =(
I might make a custom tool that is thinner, but am hoping that getting down to the cylinder heads themselves is possible (install sparkplug, and sensor, then reassemble everything on top)
if it was just 1mm wider!
shucks =(
PB
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
Do you really remove slave cylinder to flush? ayn Do-It-Yourself H.Q. 5 06-09-2003 10:59 PM
Clutch Master Cylinder zcasavant General BMW Questions 18 06-06-2003 01:11 PM
Heads up CDN (401-area) drivers MD2b General BMW Questions 12 01-07-2003 06:51 PM
Any Europeans with 4 cylinder Valvetronic? DaveN323i 3 Series & 4 Series 0 02-03-2002 10:50 AM
