E89 Z4 (2009 - current)
RFT on 19" Wheel changed to Standard Tire
Have you replaced your RFT with Standard Tires on the 19 Inch Wheels?
If so can you share with us... A) Type of Tire you now have B) How many miles / KM have you driven on the new tires and C) How would you rate them on a scale of 1 to 10 compared to the RFT Thanks for sharing, Cheers, Rolf-Dieter
Driving mt 2012 /// M3 LMB & Black Leather Interior Fully Loaded
I drove a Z4 35i across the USA in 2010 & loved it. Somehow I just had to get back into the /// M3 and so I did. |
Not a lot of use to you but I intend re-new with run-flat tyres, for me they are a better ride on 19" than my old E85 Z on 18" with run-flats
Anxious to see the answers on this question. Thanks for asking it, Rolf-Dieter.
Rft
Since it's my wife's daily driver we will keep the RFT's........
Rolf-Dieter
No, I guess not, but I still plan on changing. I am going to stick with a 30 aspect tire but will go wider with a more pronounced sidewall. If the wheel is the issue, the increase in tire volume should help driving over rougher roads. |
I am still waiting for BMW to get back to me with a cheque and another wheel. Then I'll make my move on the tire. My M3 (sold this year in early spring) had 19 inch wheels and regular tires, never ever did I have an issue. Will keep you posted.
I'll chime in with my 2 cents:
On my E93 I took off the RFTs immediately after delivery and installed a set of Yokohama ADVAN S4s in the OEM sizes on 18" CSL wheels. Ride was markedly improved, handling did not suffer and I had no problem for the 2.5 years that I owned the car. Sold the RFTs for almost enough money to buy the non-runflat tires. Did the same thing on my E89 Z4 except I went with the new Yokohama ENVigor UHP AS tires. So far so good but only have 3000 miles on the tires in 6 months of ownership. Would I do it again? YES. I do not like the ride, feel or cost of the RFTs. I know they are supposed to be getting better but they still weigh more, ride worse, cost more, etc. OK, maybe this is more like 5 cents. Cheers!
Colonel (Ret) US Army / Hagerstown, MD 2010 Z4 s30i Alpine White/Beige PP/SP/CWP/6MT/CA/NAV/ipod/USB ED 1-29-10/Redelivery 3-8-10 (weekend car) 2013 Audi A6 Quattro (daily driver) 2011 335d (Ret) 2009 335i vert (Ret) 2007 335i vert (Ret) 2000 740iL (Ret) 1998 328iC (Ret) 1990 535i (Ret) 1988 635CSi (Ret) |
I'd say you will wipe off the rear within 10k and the front would last until 15k. Of course it depends on the way you drive and the roads you drive on too.
2000 Z3 2.8 TiAg (retired) 2002 330i Orient Blue (retired) 2005 330Ci TiAg (retired) 2009 Z4 30i Space Gray (for sale) 2011 Z4 35is Space Gray 2011 535i GT xDrive Space Gray |
Wow! Is that all? How many would you expect from non run-flats?
2011 Z4 35is |
Well this is also because we have these Bridgestone RE050 which are only rated 140 for treadlife... The same tires in non RFT are rated the same but have the reputation not to wear as fast as RFTs. I do not know how long they would last though. For reference the PS2 on my 330CI of the same size are have a 220 rating and last me about 20k.
My plan as well - wear out the RFT's and change out at that time. (I'm not ready to toss out $1500 worth of tires right now) Not sure what I'll replace with, but by then there should be some here who have some experience/opinions on the best options.
I assume that there are advantages to having a lower treadwear rating, e.g. 140 on our Bridgestones. For example, is the tire compound softer resulting in better handling but shorter tread life?
2009 Z4 35i Titanium Silver 2011 135i Space Gray (Sept. '10 ED) 2011 535i Jet Black |
yes in general but it is more complicated than that. You will have some tires which will have better treadwear but handle just as well or better (PS2, GY F1 etc)
My stones are the RE 050A RFT's on 19" 296's. My first almost 2K miles in Germany lots of curves and at least 750 miles sustained above 100mph. I was not pushing it in the corners as I was trying to avoid motion sickness of the Frau. I haven't even worn the tites (tire molding) off the inside edges of my rear tires yet. So far no sign of excessive rear camber related wear. I'm at an average of 10/32 F&R @ 2500 miles. At 9/32" available wear this projects out to 22.5K miles. From the pics of Rolf-Dieter tires @ 18K km (~ 11K miles) aside from the abnormal/inside wear, the main portion of the tread seemed to be in good condition. Not knowing the tread depth I'd guess the rear tires would easily made it to 20K miles. Rolf did/do you have any tread depth of your tires at removal? New is 11/32" or 8.7 mm for the RE 050A.
HerrK - Keine Eifelfahrt ohne eine Runde über den Nürburgring May 2010 ED l 2011 35i l Crimson over Ext'd Coral Red w/brushed Alum l 6sp MT l Prem Sound l Sport Pack l 296's l Comfort Access l Alarm l Power Heated Seats l & Nav. |
HerrK
You have been driving on very smooth german highways. Not on the grooved pavement here. From what I can see on Tirerack, people get 15k at most with these tires. http://www.tirerack.com/tires/tires....ge&tab=Reviews
Well, I read more of the reviews and amazingly some people got 30k miles out of these tires. I don't know how it is possible. The vast majority though change them at about 13-15k in average. Some only after 5k. So Cal has pretty nice roads trust me. The concrete might be a little rough at some spots but compared to Oregon where people drive with studded tire in the winter even when there it snows an average of 7 days a year...
I only have 3000 miles on my car and I only drove 800 of them as I bought it used. The rear are already down to 8/32" I usually change my tires with about 2/32" left so I am basically 1/3 through the treadlife already.
I'll get back to you and the thread depth
#25
When you guys say, RFT gives a harsh ride , What do you mean exactly? Harsh meaning, bumpy, stiff etc?
