Old 08-27-2010, 05:13 PM
Ultm8drvnmchn Ultm8drvnmchn is offline
Mein Auto: 98 740il
Rear wheel bearing DIY?
I found the instructions on E38.Org for the front wheel bearings, which I will do, but cant find anything for the rear. Anyone know where to look?
TIA
Old 08-30-2010, 06:52 AM
Mein Auto: 98 740il
NO ONE HAS DONE REAR WHEEL BEARINGS???
Old 08-30-2010, 05:11 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
I would also be interested in a DIY on the rear bearings.
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 09-01-2010, 08:25 PM
balance balance is offline
Mein Auto: 97 740iL
It would probably be more involved than the fronts, since you would have to take CV axle out of the hub by removing the lower ball joint or control arm, but I wouldn't think that it would be too difficult. The CV axle nut should be on there tight, so either have an air gun ready, or loosen the bolt with a breaker bar while the wheels are on the ground first.
