Old 09-15-2010, 08:00 PM
acetner acetner is offline
Mein Auto: 2008 E60
Sport wheel durability
Hi All,
I'm about to place my order for a 535xi (P1, P2, sport seat, Black Sapphire/Oyster) and have been debating the addition of the sport package. I have driven a sport package equipped and non-sport 535 back to back and prefer the slightly firmer ride of the sport (I imagine this is from the larger wheels and lower profile tires, as I understand that there are no differences in the tuning of the suspension). My question--are the 19 inch rims with the lower profile tires less durable? Are you more likely to damage a rim on a pock-marked road? Here in Detroit we are accustomed to heavily damaged road surfaces. Furthermore, is the wider tire a detriment in snow? Thanks!
Old 09-15-2010, 08:20 PM
savela savela is offline
Mein Auto: 550i
19" are more prone to damage from bad roads. Wider tires better for snow ( more contact).
Old 09-15-2010, 09:24 PM
baloo588 baloo588 is offline
Mein Auto: car
I also live in suburban Detroit and in my experience I rather have the 19 inch rims with air suspension as opposed to the normal steel suspension to help absorb the impact to prevent damage to the rims. My Audi A8L has 19 inch wheel with low proifle rims and it has not had any damaged rims for 4 years as compared to my 2006 Lexus GS300 with 18 inch rims and my 2008 BMW 335xi coupe with 17 inch rims. The reason is that the Audi has air suspension that makes the ride more supple and prevents all the road imperfection and pot holes damaging the rims. The steel suspension in the BMW makes the force on the rims harder causing small bends and vibration on the highway. So far, I had 3 damaged rims on the BMW 335xi coupe and 2 damaged rims on the Lexus GS and 0 damaged rims on the AUdi in the last 4 years. So with the 19 inch rims I will be ordering the dynamic handling package.
Old 09-15-2010, 10:41 PM
solstice solstice is offline
Mein Auto: 2015 F80 M3
I'm scandinavian and trust me, wider tires are worse in snow. You get more pressure per sq/inch on a narrower tire which is a plus when friction is low. In deep snow a wider tire will also "float" more and reduce friction. So, fat low profiles are a drag in snow.
Old 09-16-2010, 03:02 AM
Slaymaster's Avatar
Slaymaster Slaymaster is online now
Mein Auto: 2011 528i Sport Package
+1 Go to Tire Rack and read up on winter snow tire packages.
BMWCCA Member #458528 www.bmwcca.org
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
Old 09-16-2010, 05:17 AM
Newmanium Newmanium is offline
Mein Auto: Zipcars
Wider tires are definitely not better in snow - narrow is best.
Past: 2011 X5 35d .... 2007 530i ..... 2002 530i ..... 1999 Honda Civic ..... 1990 Honda Accord ..... 2008 TSX
Old 09-16-2010, 07:26 AM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: E92 335i
You must be from Texas
Old 09-16-2010, 08:10 AM
dunccfp dunccfp is offline
Mein Auto: F10
Originally Posted by acetner View Post
Hi All,
The sport package does give you the option to tighten the suspension. Take the RF tires off and save them for the summer and return car with them at lease end. Use 1 for a spare (get a rim at tire rack for $80). Get the conti extreme contact DWS tires. Best all weather tire on the market. There great. $950 for a set of 4.
Old 09-16-2010, 08:56 AM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
I'm from Buffalo NY, wider is not better.
Old 09-16-2010, 09:11 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
Unless the tires are studded?
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 09-17-2010, 12:45 PM
tturedraider's Avatar
Freedom isn't free!!
wider tires better for snow ( more contact).
-1
i'm scandinavian and trust me, wider tires are worse in snow. You get more pressure per sq/inch on a narrower tire which is a plus when friction is low. In deep snow a wider tire will also "float" more and reduce friction. So, fat low profiles are a drag in snow.
+1
Originally Posted by newmanium View Post
wider tires are definitely not better in snow - narrow is best.
+1
Originally Posted by tjpark01 View Post
you must be from texas
+1
i'm from buffalo ny, wider is not better.
+1
www.bmwcca.org
Old 09-17-2010, 07:19 PM
Mein Auto: 550i
Right you are. Not much snow in TX. I did spend 4 years in Ann Arbor and drove quite a bit but honestly used the same size tire the entire time. I guess common sense didn't prevail here. I stand corrected and I should be more careful before adding my 2 cents in in the future.
Old 09-17-2010, 07:29 PM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
Not on the xi models. It is the same suspension with or without sport package.
2014 i3 Rex
Retired 2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
Old 09-19-2010, 04:18 AM
Mein Auto: 2008 E60
Is it a different suspension when you order the sport package on the non-xi model?
Old 09-19-2010, 07:16 PM
Mein Auto: F10
No it isn't, you just get the option to tighten on the non xdrive. He's probably mistaken on the x drive but I'm not totally sure.
You also get the option to speed up the linkage.
