Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 10-08-2003, 09:08 PM
kneebiters's Avatar
kneebiters kneebiters is offline
Grabastic Slug
Send a message via AIM to kneebiters
Mein Auto: '12 335i, Luxury + KS
First Oil Change - Rookie Question
I should specify that this is my first oil change in a BMW. I've changed oil in a lot of beaters before, but I don't want to screw this up. So here is the million dollar question -- where is the drain plug? I think I spotted it (seems pretty obvious), but does anyone have a picture or diagram?
2003 530i.
Old 10-08-2003, 09:14 PM
kowached kowached is offline
Mein Auto: 1998 540iA Sport
Nope, 6 Cylinder guys are second rate with DIY documentation.
Maybe the DIY links below will help, or maybe some I-6 guy will get off his arse and put together a proper DIY, best of luck.
540i DIY Oil Change: http://www.540isport.com/DIYoilchangemodem.htm, or http://www.bmwtips.com/tipsntricks/t...ocedures_2.htm
bimmerfest 5-Series Welcome
Later,
Dave
E39 - 1998 540iA Sport (11/97 Production)
E30 - 1989 M3 (44k miles)
1979 Triumph TR7, still have my first car ;-)
Past cars:
E21 - 1980 320i (sold at 130k)
E23 - 1986 735i
Avatars under the signature are MUCH more prestigious than to the left of the post...
Old 10-08-2003, 09:42 PM
bluer1 bluer1 is offline
fahrer
Mein Auto: doesn't have rear fogs!
Here's a pic.
Old 10-10-2003, 06:45 AM
F1Crazy's Avatar
F1Crazy F1Crazy is offline
racer wannabe
Mein Auto: '12 X5,'08 535i, '03 325i
Here's a DIY for 330i that should give you a good idea on I-6 oil change:
http://www.bmw330ci.com/DIY_Oil_Change.htm
Old 10-11-2003, 08:11 AM
kneebiters's Avatar
Grabastic Slug
This was very helpful -- thanks! A couple of comments -- on my 2003 530i, there is no plastic cover over the oil pan. It was fully exposed already, which in fact was my point of confusion. Everything I had read and heard (including the advice from my local dealer) indicated that you had to first remove some sort of cover. It appears that is not the case.
One other itnteresting note. The oil plug was finger tight, with no copper washer. That was a little disturbing to say the least. Glad that I checked.
Anyway, thanks for all the helpful comments.
Old 10-11-2003, 08:26 AM
F1Crazy's Avatar
racer wannabe
I have yet to hear from '03 MY owner that had the cover. If this the kind of cost cutting that it takes to keep making these wonderful I6s then I'll take it.
Old 10-13-2003, 02:27 PM
marinakorp marinakorp is offline
Mein Auto: 540iT
I was also looking for a door... but it seems that the previous owner pulled it off... no biggie
FINGER TIGHT AND NO WASHER..... YIKES, glad you got there to rectify the issue!
__________________________________________
99 540iT Sport
264 rhp 300 tq - pre powerchip
262 rhp 300 tq - post powerchip
Modifications:
Performance: Powerchip Gold 93, M5 rear Sway
Styling: Shadow Badge, Shadow Chrome Grill
