Old 10-04-2010, 08:24 AM
tadtaggert tadtaggert is offline
Mein Auto: M6 F12
Originally Posted by solstice View Post
I got curious and did a quick rough check on my F10 535i using the speedometer and manual shifts and it seemed to me ( didn't want to keep it at redline for more than a moment ) that my car redlines at around 57 mph in 2nd gear. That can hardly be optimal for 0-60 times. The 550i is probably differently geared so it doesn't mean much for 550i vs. 750i especially since I also don't know where the 750i redlines in 2nd.
What size wheels are on your car?
Old 10-04-2010, 08:58 AM
solstice solstice is offline
Mein Auto: 2015 F80 M3
The 19' from ZSP with the run flats that comes with it.
Old 10-04-2010, 09:29 AM
Mein Auto: M6 F12
With the auto, 535i with 19" tires, you'll probably have to make two shifts, top speed in 2nd is somewhere around 50mph.
With the manual, top speed in 2nd is around 71 mph.
So an extra shift, but as we've already seen in the C&D numbers (550i auto and manual, same gear ratios) the auto is quite a bit faster.
So your post/position has more merit.
EDIT: To be precise, what does the 535i redline at? I just used the same as the 550i (6750) above, should be close.
Old 10-04-2010, 10:27 AM
Auto and manual are really hard to compare due to the big human factor. I.e who is doing the shifting. I'm not at all curious about that comparo. My 535i redlines at 7000 that's probably why it looks more like 55 mph than 50 mph at redline. To get back to this threads subject I wonder where the 6-speed auto in the 750i redlines in 2nd?
Old 10-04-2010, 12:46 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2014 M5
Actually tire size is more pertinent than wheel size, since often people reduce tire wall when increasing wheel size to keep overall radius constant and ensure speedo remains accurate, avoid rubbing, etc.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
