Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 10-05-2010, 09:34 PM
740IL 740IL is offline
2001 BMW 740IL
Mein Auto: 2001 BMW 740IL
01 740iL - Sport suspention
Hi, im sure this has been covered before so im sorry to repeat if I am, but im finding conflicting answers. I have a 2001 740IL with a factory sport package. Im being told that all sport packages have self leveling suspentions but ive also been told that if your power steering cap says "ATF ONLY" then you dont have self leveling. I have both of those things so now you understand why i might be a little confused. I really dont care either way but would really like to have a clear answer if anyone can help because im trying to buy lowering springs and turns out I need to know to figure out what ones to put on her. Please help if you can and I thank you in advance.
Old 10-06-2010, 05:42 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
This part is wrong...
This part is right. ATF only means no self leveling.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 10-06-2010, 12:29 PM
balance balance is offline
Mein Auto: 97 740iL
Are you sure that it is a 2001 model? I thought that all of the 2001 models got all of the options included in the car, which includes the self-leveling option.
What is the build date on your door? (mm/yy)
Old 10-06-2010, 04:12 PM
M.Wong's Avatar
Mein Auto: The E38
Originally Posted by balance View Post
I thought that all of the 2001 models got all of the options included in the car.
Where did you hear that??? Pretty sure that is not at all the case. As the years went on, some items that were options became standard (like NAV, Xenon lights, rain sensing wipers...) but there wasn't a "ALL OPTIONS" year.
M.Wong
Old 10-06-2010, 04:45 PM
Mein Auto: 97 740iL
Well I'm probably wrong then.
I think I've heard it a few times on different websites, but I never did any research on it myself. Maybe I'm remembering it wrong. Nevermind guys.
Old 10-06-2010, 07:43 PM
Ultm8drvnmchn Ultm8drvnmchn is offline
Mein Auto: 98 740il
Then what constitutes sport suspension exactly?
Old 10-06-2010, 08:18 PM
Mein Auto: 97 740iL
If I'm remembering this right ...
The "iL" models got appearance packages only, it was the "i" sport models that got 10% stiffer suspension front and rear, lowered stance .8 inches front and .2 inches rear, and thicker front swaybar, but they did not recieve the rear sway bar. The only E38 models that recieved the rear sway bars are the ones with the self-leveling suspensions because they use a sensor that attaches to the sway bar (rear) to adjust how high the rear end is sitting. But I'm not sure if the "i" sport models were available with the self-leveling option.
Old 10-07-2010, 04:46 AM
M.Wong's Avatar
Mein Auto: The E38
I'm no expert on self leveling, as I don't have it on my car... The stiffer suspension and lower stance (different springs, etc.) sounds right. Bottom line to the original question, ATF on PS reservior means no self leveling. Take a look at the owner's manual to help with the different reserviors, if necessary.
(Image from 'Q')
M.Wong
