E28 (1982 - 1988)
Old 10-14-2010, 06:06 PM
newbie-newbie newbie-newbie is offline
Mein Auto: nothing
BMW 1986 L7 - Worth Buying at 1k or a headache?
Have a chance to get this for 1K. Worth it?
Old 10-15-2010, 05:59 AM
catswiththumbs catswiththumbs is offline
Mein Auto: '84 Alpineweiss 633CSi
Post pics/specs - they're ALL headaches; just don't buy a migraine.
Old 10-16-2010, 04:55 PM
catso's Avatar
catso catso is offline
catso
If you like working on cars and it's not too rusty, buy it!
Old 10-17-2010, 06:32 AM
I agree - if the interior leather is good (and that thing should be ALL leather - dash, doors, etc.) and the head is OK, you're good - you could sell the interior parts/head and recoup your investment if it became necessary.
An L7 for a thousand dollars sounds too inexpensive, though. Is it super rusty?
'84 Alpineweiss 633CSi, 111,000
Garage Sale!
Old 10-26-2010, 07:01 PM
Mein Auto: nothing
Bough the Car
Hi all,
took the plunge, bought the car for a grand. But now have a check engine light and all the red indicators lit up. Like to find out how to find and diagnose the error codes and then release them.
Any ideas?
ID:	252095   Click image for larger version
ID:	252096   Click image for larger version
ID:	252097   Click image for larger version
ID:	252098   Click image for larger version
ID:	252100   Click image for larger version
ID:	252102   Click image for larger version
ID:	252103   Click image for larger version
ID:	252104   Click image for larger version
ID:	252106   Click image for larger version
Old 10-26-2010, 08:11 PM
catso's Avatar
catso
Hi all,
Any ideas?
The routine inspection lights are probably on because no one reset them for many, many miles. Do a search and you'll find the procedure. Washer fluid is no big deal. I don't know if there's any on board diagnosis capabilities. Does it run poorly? What are the symptoms? Disconnecting the battery sometimes resets the light.
Old 10-28-2010, 06:12 AM
From the pics, it looks like you got a hell of deal for 1000.00 - nice going! ^^^What he said about your check engine/inspection lights.
Garage Sale!
Old 11-03-2010, 06:16 PM
Roku35's Avatar
Roku35 Roku35 is offline
Full Blown Euro Addict
Mein Auto: 1985 Euro E24s
Wow, that is a lot of car for $1K. I know that the A/C for the 7-Series are a mess and very hard to fix it they are not working right. Electrical issues also plague these 7-Series, but the engines are rock solid. Great deal, hope everything goes well.
635CSi CR 5-Spds (Schwartz & Polaris Metallic )
628CSi Automatic (Zobelbraun Metallic)
540iT Sport Automatic (Schwartz)
http://hawaiisharks.tripod.com/
Old 11-06-2010, 02:08 PM
Rajht Rajht is offline
Mein Auto: 328ic
Boy I would buy it from you for a grand if you were close to me and I would not care about any of those lights.
Old 01-15-2011, 07:18 PM
Mein Auto: nothing
Update. Reset inspection lights but have ac issue
Hi all,
Thanks for your thoughs. Had no idea if I was making a huge mistake.
Updates:
Jumped the 7 & 1 pins at the data link connector to reset service indicator lights. This was useful, though the link connector on my L7 was much smaller than the one pictured. Regardless, finally got it to work. http://www.unofficialbmw.com/e36/ele...ce_lights.html
My next problem is the AC. The car has hot air blowing through at the base of the windshield whenever the engine is engaged and moving forward. Smelling (if I'm not imagining things) slightly of coolant (slightly sweet smell).
The heat and fan is turned off. Defrost as well. Anybody have this problem before? I can park the car, thoroughly close all windows and sunroof, and come back to find the car fogged up.
Old 01-16-2011, 10:49 AM
catso's Avatar
catso
Hi all,
Updates:
Sounds like a possible heater core problem. I would start by pressure testing the cooling system. I'm not sure of your model, but on mine you need a special adapter that costs about $50. Maybe you can borrow one from a repair shop.
Old 01-17-2011, 09:25 AM
If it's the heater core, it's a HUMONGOUS PIA to replace. Are you noticing any water/coolant on the driver's side floor?
If it's just the heater valve (in the engine compartment, on the firewall driver's side), you can either bypass it or replace it - easy fix.
Garage Sale!
