Tranny and differential fluid - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 08-03-2005, 08:44 PM
jayf jayf is offline
Mein Auto: 2002 m3c
Time for my Inspection II and the manual says to change the Tranny and differential fluid. I called the dealer and they don't sell it by the quart, only by the gallon at like $50 each. Anyone know what I should use and where to get it?
Old 08-04-2005, 02:43 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Suck it up and get a few friends together and do a few trannies. 5 Liter bottle, $120 with BMW CCA discount. One bottle will do about 3 cars.
Same with diff fluid.
WHile I would use other fluids in other BMWs, I stick with factory fluids in the M3 due to warranty concerns. Especially in the diff, which is not like any other BMW diff.
Some dealers will sell you a quart or so if you bring your own clean container. They buy it in bulk packages.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 08-10-2005, 11:31 AM
Mein Auto: 2002 m3c
Thanks Pinecone, but there ought to be a law against this type of thievery by BMW. Anything to keep us D-I-Y'ers from doing it ourselves.
Old 08-10-2005, 11:40 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
It's enough to do trannies in two M3s, and one regular E46. It's also a much better fluid -- make absolutely certain that you get BMW MTF-LT2. I need to pick up another bottle myself.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 08-10-2005, 05:05 PM
Pinecone's Avatar
M Mad
Yeah, so it is only about $40 per car. But, if you can't afford to maintain it, you can't really afford the car.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 08-13-2005, 12:31 AM
EuroRocket EuroRocket is offline
Send a message via MSN to EuroRocket
Mein Auto: BMW soon to be! volvo/toy
lol i never heard of anyone call gear oil -diff oil!!!
Old 08-14-2005, 02:39 PM
Pinecone's Avatar
M Mad
Huh?
We are talking about two different fluids. One for the tranny, and one for the diff. Both are special BMW fluids. LTF-2 for the tranny, XJ for the diff. ESPECIALLY the diff fluid.
You could use Royal Purple or RedLine or Mobil 1 in the tranny, but since at leat one board member has had a tranny replaced, I wouldn't want to give BMW any excuse to make good on their warranty (within warranty period, outside of warranty, do what makes you happy).
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 08-26-2005, 09:05 PM
johnw johnw is offline
Mein Auto: 2001 M3
Be sure to get limited slip fluid for your M3. Most dealers are getting their oil from drums which are for all BMWs. Only M-cars have limited slip and most Dealers have no clue. Using regular oil will damage the clutches in time. The correct oil is #83222282583. My ex-dealer almost ruined my diffy because they used the wrong oil at Insp 2.
Old 08-26-2005, 09:09 PM
Mein Auto: 2001 M3
The correct XJ is SAF-XJ + FM Booster, bmw 83222282583. This oil is correct for limited slip which M-cars have. Any other oil without the booster is primarily for bmw's without limited slip which is all bmws except for M-cars.
Old 08-26-2005, 10:28 PM
Moderato's Avatar
Moderato Moderato is offline
VIII
Mein Auto: 07 E92 335i 6MT
I can't believe the dealer would use the wrong oils in an M car, that really sucks.
Old 08-27-2005, 04:44 AM
Pinecone's Avatar
M Mad
This hasn't been a problem at most dealers for a while now. But good to check.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-24-2005, 07:38 PM
Mein Auto: 2001 M3
BMW is recommending a new fluid for their limited slip differentials, 83222282583. If dealers use the old fluid, 83221470080, the differential is destined to start grinding. There is a SIB 330102, but the dealers are interpreting it a bit foolishly, some think, the differential has got to grind a bit before adding this special oil. To avoid a problem, that is, if the dealer refuses to put in the new oil unless it grinds, it might be best to say you hear some grinding when the car is cold when making left or right turns. Or, you can accept what they say and change to the new oil when it begins to grind which won't be long on the old oil. Just hope you are still in warranty because if long term damage occurs, it takes $3K to get it right at the BMW dealer.
Old 09-24-2005, 09:30 PM
Moderato's Avatar
VIII
Good God has your useless propaganda spread to bimmerfest now?
Old 09-25-2005, 04:10 AM
Pinecone's Avatar
M Mad
Please post the SIB then.
Back in 2002 when the grinding problem came to light, the SIB did say to ONLY use the new fluid when the customer compains of grinding, and that the fluid was NOT to be used all the time. In fact the SIB says to change out the special fluid after a certain number of miles.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-25-2005, 06:27 AM
Moderato's Avatar
VIII
Here's a link to the SIB and also a thread where we're having this discussion. The SIB says that the oil with the FM booster is for diffs that grind. It makes no mention of an "across the board" change for the diff oil. Johnw & Zimmer insist that the oil with the FM booster is the oil that all M3's are supposed to have. I would believe it if they could prove it but whenever I ask for proof they convieniently ignore my posts. The thing is that some dealers are putting the oil with the FM booster in at the 1200 miles service and acting as if it's the proper oil, whereas other dealers are using the standard 080 LSD oil. Read through the thread and you'll see what I'm talking about. Either way I'd like to get to the bottom of this.
http://www.thatsoundsagoodidea.com/b...ins_330102.pdf
http://www.m3forum.net/m3forum/showthread.php?t=83475
Old 09-25-2005, 11:47 AM
Mein Auto: 2001 M3
Good god, you were embarrassly run off M3forum...do your brain-dead preaching somewhere else.
Old 09-25-2005, 11:49 AM
Pinecone's Avatar
M Mad
OK, the first link is the newer SIB than teh one I had mine serviced under. The older one said to replace the special fluid with standard fluid after a certain interval. This one says that the special oil should be used from then on.
But again, it only says that it should be replaced IF there is a problem. I suspect the special fluid actually increases the slip in the diff, just like running more friction modifier does in any LSD. And that is why some racers run diff fluid without ANY FM to increase the lockup.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-25-2005, 02:47 PM
Moderato's Avatar
VIII
First of all "embarrassly" isn't a word. Second, I wasn't run off from anywhere if anything you're the one who's left the thread because you can't come up with any proof. Third, I'm not "preaching" anything, I'm just trying to find the correct answer to this question and I could really care less if you're right or wrong. What I do care about is getting to the bottom of this and making sure that false information isn't spread on the message boards.
Don't get mad at me because I won't allow you to advise people without questioning your credibility. Empty insults will not hide the fact that you have no factual information to prove what you're suggesting. If you really want to earn the respect of the people here why don't you devote some time to researching this and help us out by actually providing some credible evidence to back up what you're saying. I can't understand why you don't get this, but just because "you say so" or "you think so" doesn't mean you're right.
Old 09-25-2005, 02:53 PM
Moderato's Avatar
VIII
This is the same way I interpret the SIB. In fact the guy I spoke to at the dealer told me if I was racing the car that I wouldn't want the oil with the FM booster, so this further makes me believe that 080 is the proper oil to run if you do not have grinding issues. Someone also mentioned that the FM booster might increase the slip in the diff and wasn't really an ideal solution, but I forget who. Wouldn't BMW publish a TSB if the specified diff oil was to be changed in ALL M3's?
Old 10-17-2010, 07:46 PM
genuity genuity is offline
Mein Auto: 2001 330iS
This post is for reference and anyone coming across this in the future:
Code:
http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B330102g.htm
http://www.bmwtis.com/tsb/bulletins/...p/B330102g.htm
Similar Threads
Lets 3.46 differential my '01 M-Z3 coupe, part 1 Ron Stygar E36/7 Z3 (1996-2002) 82 11-28-2013 06:42 AM
Has anyone changed their AT fluid? TurnAround X5 E53 (1999 - 2006) 2 12-03-2004 09:11 AM
Manual transmission "jerky" shift feeling resolved in my case. jaisonline 3 Series & 4 Series 11 11-13-2004 07:10 AM
Transmission fluid emPoWaH 5 Series 1 08-07-2004 06:40 PM
Redline gear oil jmig 5 Series 13 07-19-2004 02:23 PM
