E90/E91/E92/E93 (2006 - 2013)
Old 10-19-2010, 11:25 PM
ykang0816 ykang0816 is offline
Mein Auto: 2007 328i sedan
Xenon Light vibrates while driving
It has been raining last couple of days in Southern California so I had the light on all the time. I noticed that my xenon light was shaking/vibrating a lot. I took my car to the Shelly BMW and told SA that my xenon light is vibration too much. I left the car there and went to work. SA called me hours later and told me that they replaced head lamp unit. When I went there to pick up the car, I found out that they only replaced left one and now my lights are unbalanced. I don't think they replaced any bulbs but why is there a difference in brightness?
What do you guys recommend me to do? Any input would be appreciated. Thanks.
Old 10-20-2010, 03:24 AM
Jimbo335 Jimbo335 is offline
Mein Auto: 2007 335i
My xenons shake when I go over bumps. Service dept. said it is normal.
Old 10-20-2010, 05:19 AM
E92Submarine's Avatar
E92Submarine E92Submarine is offline
Officially Contaminated
Mein Auto: 2009 E92 335i
The driver's side light should be aimed lower than the passenger's side. It's a safety thing. That might be what you describe as the difference in brightness.
If you can stand in front of the car and notice that one light is more intense than the other, well then maybe there is a problem. But as for how far each lamp illuminates, the left will always be shorter than the right.
2009 E92 335i | 6MT | Black Sapphire | Black Dakota | Aluminum Trim | Premium | Sport | Heated Seats | PDC | iDrive | HD Radio | M-Sport Shift Knob |
Old 10-20-2010, 05:42 AM
brewder brewder is offline
Mein Auto: '07 328xi
I have the Xenon's... headlight shake is NOT normal. I don't care what the SA tells you. I had mine repaired using SIB 63 10 07. Now mine are ROCK SOLID like the Xenons in my Audi are and my halogens in my Suburban!
Keep in mind there are variations of this SIB based on the model of your car....
Headlight Vibrates when Vehicle is in Motion
MODEL
E92, E93 (3 Series)
Vehicles produced from May 31, 2005 to February 11, 2007
SITUATION
The headlight shakes or vibrates when the vehicle is in motion.
CAUSE
The front-end carrier arm of the headlight is very sensitive to vibration.
CORRECTION
Do not replace any parts. Perform the following procedure to both headlights.
Check all connections that are used to secure the headlight. If screws are missing or not sufficiently secured, then they must be replaced or tightened to correct BMW specifications.
If the headlight still vibrates:
2. Secure the headlight arm with additional screws P/N 63 12 8 372 243 (1).
3. Install an additional headlight arm support (1) to both headlights, P/N 51 64 7 019 777 (Left) and P/N 51 64 7 019 778 (Right).
4. Remove the front bumper cover per repair instructions RA 51 11 156.
5. Remove the left and right brake air ducts.
6. Remove the round-head Torx bolt (1) to install the additional headlight arm support.
7. Install the additional headlight arm support (1). Make sure that the support surface of the headlight arm support (1) engages onto the headlight carrier (2).
8. Secure the other end of the headlight arm support (1) with a new self-locking M6 X18 round-head Torx bolt (2) P/N 07 14 6 978 618.
9. Reinstall the left and right brake air ducts.
10. Reinstall the front bumper cover per repair instructions RA 51 11 156.
PARTS INFORMATION
Part Number
Description
Quantity
51 64 7 019 777
Headlight Arm Support (Left)
1
51 64 7 019 778
Headlight Arm Support (Right)
1
63 12 8 372 243
Additional Screw
4
07 14 6 978 618
M6X18 round–head Torx Bolt
2
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
63 12 02 37 00
Labor Operation:
63 99 000
Work time for installing the 4 screws in step #2.
Labor Allowance:
3 FRUs
Labor Operation:
63 99 000
Work time for installing the 4 screws in step #2 and
both headlight arm supports.
Labor Allowance:
15 FRUs
//Brew
('07 E92 328xi / '08 E83 X3)
Old 10-20-2010, 05:45 AM
furby076's Avatar
furby076 furby076 is offline
IntarWeb Stalker
Mein Auto: 2013 335xi M-Sport
15 FRUs
Are you sure about that? Mine vibrate a little bit and so have others, that I have seen, including brand new cars. I think it is more that the lights have such a defined cut off point people can notice the vibration of the light when the car is moving... So basically not a flaw, just being able to notice the flaws...like in HD pr0n.
"Booberry" -ED 2013 335xi | B45 | ZMM | ZDA |Heated Seats | HK |EBII
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 10-20-2010, 06:02 AM
LOL on the HD P0rn! All i can say is that mine don't shake AT ALL since they installed the support arms. I'm VERY happy that I had that service done. But i think it's STUPID it doesn't come from the factory with those installed. Obviously, they feel it's an issue too or the SIB wouldn't exist I suspect.
//Brew
Old 10-20-2010, 06:37 AM
AzNMpower32's Avatar
AzNMpower32 AzNMpower32 is online now
Tar Heel Faithful
Mein Auto: X3
No problems with excessive vibration on our 325i. Never needed any service on those.
The dipped (low) beam headlights should be aimed slightly lower on the driver's side. This prevents glare to oncoming vehicles.
Old 10-20-2010, 07:19 AM
heffdiddy's Avatar
heffdiddy heffdiddy is offline
Mein Auto: 550i; 335i Sedan
mine vibrate but i figure its more due to the stiffer ride than anything. i did not notice it in the 5 or 6. the 3 is definitely stiffer and i attribute the headlight vibration to that. personally i dont really care since i usually drive with night vision goggles instead of the headlights.
BMW 545i-Sold
BMW 650i-Sold
BMW 335i-Current
BMW 550i-Current
Old 10-20-2010, 07:24 AM
furby076's Avatar
IntarWeb Stalker
So is this a free service fix? If it applies to the 2006 I would get it. I don't enjoy the vibration but if it's normal then so be it, but if a fix is available then I'll take it.
My Drive Style
Because I can.
I agree with furby
Old 10-20-2010, 07:37 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Roger that - no shake here.
Old 10-20-2010, 08:03 AM
1fastg 1fastg is offline
Mein Auto: 330i
might be your tires that are shaking! check them just in case!
330i Marlon
Old 10-20-2010, 08:14 AM
furby076's Avatar
IntarWeb Stalker
My Drive Style
Because I can.
I agree with furby
Old 10-31-2010, 12:48 AM
BerfsBimmer's Avatar
BerfsBimmer BerfsBimmer is offline
Boosted Bavarian
Mein Auto: '08 335Ci
Originally Posted by ykang0816 View Post
....When I went there to pick up the car, I found out that they only replaced left one and now my lights are unbalanced. I don't think they replaced any bulbs but why is there a difference in brightness?
I know xenon bulbs will lose brightness over time, but I don’t think that 3 years would make that much difference. If they did not replace the bulb, then that could not be the answer anyway. More likely, the unbalance you are referring to is because you are comparing the light output through one brand new headlight lens and one that is 3+ years old.
Try polishing the old lens and then compare. There are a number of polish manufacturers such as 3M, Mother’s, etc. Try a search on the DIY sub-forum.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=93468&dateline=1203123566
'08 E92 SpaceGray/Gray/Burl/ZSP/ZPP/ZCW/Step/Nav/CA/6FL/HD/Original HPFP
Old 10-31-2010, 08:48 AM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Re-Badged
Mein Auto: 2013 BMW M3
The Xenon lights "float" so a little shaking is normal.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 12-03-2012, 07:25 PM
mpower310 mpower310 is offline
Mein Auto: bmw
MODEL
E92, E93 (3 Series)
SITUATION
CAUSE
CORRECTION
PARTS INFORMATION
Part Number
Description
Quantity
51 64 7 019 777
1
51 64 7 019 778
1
63 12 8 372 243
Additional Screw
4
07 14 6 978 618
2
Defect Code
63 12 02 37 00
Labor Operation:
63 99 000
Labor Allowance:
3 FRUs
Labor Operation:
63 99 000
Labor Allowance:
15 FRUs
Wen I look up the part number on getbmwparts.com, it says that the brackets are for a 2011 328i. Will it still work?
http://www.trademotion.com/parts/ind...&siteid=214672
Old 12-05-2012, 12:09 PM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
its definitely not normal, mine are stationary over bumps.
Old 12-28-2012, 03:21 PM
Nader-Vancouver Nader-Vancouver is offline
Mein Auto: BMW 328i 2011 convertible
I have a question related to this discussion, Recently I noticed that when I start the car , the xenons ( the middle ones and mostly the driver lamp) are a little yellowish but after I start driving it becomes normal . Why is it yellowish sometimes ? Is color change normal ? My car is E93 2011 under warranty .
