E90/E91/E92/E93 (2006 - 2013)
#26
If the touchless is the ones that just sprays high pressure water, then I can see how that would make a car leak.
Current Stablemates: '12 Porsche 911 GTS Cabriolet; '11 BMW 335is Convertible; '08 BMW 535xi Favorite Cars Gone But Not Forgotten: '09 Corvette ZO6; '01 BMW 740iL; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '67 MG Midget |
#27
'09 335i xDrive Coupe - Space Grey / Black Leather / Alum. Trim / Sport / Premium / 18'' wheels / Cold Weather / CA / Nav / iPod / Logic 7 / PPK1 |
#28
I had a cabriolet back in the day and was told not to take them through a carwash. Why would it be any different now? Of course it's going to leak if you put a high pressure stream to it, why would I expect any less?
Fc Bayern Deutschermeister ja so heißt er mein Verein, Ja so war es und so ist es und so wird es immer sein |
#30
I've taken my E93 through both touch and touchless carwashes many times and not a drop comes in the car. I'll count myself lucky.
#31
TIA
If your sport doesn't put blood, dirt or grease under your fingernails, then it's just a game. Euro Modded|Split Armrest|Rear Foglight Mod|CDV Delete|Shark Fin Antennae Delete|Front Reflector Delete|LUX H8 Angel Eyes|No Bells|Few Whistles|Das Fahren im Freien| BMWCCA#445793
#32
#33
Soft glove/white glove. They don't use bristle brushes on their automatic equipment. It's a soft spongy pad like material. It's your typical full service car wash that they have in just about every suburban area that I have ever visited.
#34
Thanks, Beden.
#35
Excuse me but I'm not washing a friggin car. We either take our cars to a touchless car wash or a hand wash. The '09 vert has never leaked a drop nor has the new 335is.
1980 633csi (Retired 1985) 2005 325i (Retired) 2006 Z4 3.0si (Retired) 2008 135i vert (Retired) 2009 328i vert (Retired) 2011 335is (Retired) 2011 Z4 3.0 (Retired) 2012 328i Coupe 2013 M3 Coupe (Retired) 2013 650i Coupe |
#36
Finally fixed the leak myself after dealer could not help and all he would say is
to lemon the car if we cannot fix the water streaming into the car after 3 repair fixes. The top roof seal for the driver and passenger door window is the problem. Its the side that goes into the roof pillar that needs blocked off. We also filled the v shape seal on top for driver and passenger window with flexible 1/4 inch tubular foam insert that takes up space and makes for better top window seal. It was a very easy fix, my car doesn't leak a bit in car wash when before water just streamed in like a waterfall on both sides. Someone from BMW should be fired over this!! We loved the car and raised and lowered the roof several times before finding the problem that anyone can fix if water is coming in at the corners where the top meets the front window. Good luck with your fix if you need it... |
#37
Whoa. Wait. I'm stunned that nobody's responded to this yet.
This is fantastic news. Is there anyway you can post a picture to show us non-technical folks how you fixed it? My wife is in the process of getting a 2008 E93 and this will make her decision much easier. ![]() Quote:
#38
So far so good. I never take my car to a car wash though. Hand wash every time. N4S
#39
Will see what i can do for pictures, Its a super easy fix that can help
all those 328/335 convertibles that leak inside whether from rain or at the car wash. These cars should not leak water like a waterfall on both sides where the top meets the front windows in the corners. Mine hasn't leaked at all now and i take to high pressure car wash weekly and let it drip dry. Only other thing is i'm on my second set of 30 day tags since somehow the title is lost and the dealer trying to get new one from BMW. Paid cash for the car so would like to get the dealers name plate off my car for good. |
#40
Can we sue?
#41
The General Manager told me straight up that they would talk
to BMW about the problem and see what they can do with the seals, They said nothing wrong with the seals and that if he could not fix the problem that to lemon the car after 3 fixes. We were going to go that route until i really looked at the roof and the seals and new i could fix it since i loved the car. A new designed window seal that is mounted on top part of roof should not have any hole in the end, it should be a solid end. I can see a recall for a new seal if enough people have water entering at that point in the seal. The water is leaking not from pressure alone but from a poorly designed seal and gravity. |
#42
Ok, took some pictures and as you can see the flexible foam tube that
is inserted just pull the seal down and push in the whole length of the window seal and cut off.This will give the window a better seal. Then we sealed the end off with some black flexible super sticky stuff that BMW used on parts of the retractible roof....we just picked a little bit here and there and filled the hole in the window seal end..think anything that remains flexible and will adhere to the window seal will worWk. Then glued a small pc of rubber to the end. This in water tight now...we only sealed the front part of seal that sits into the little cradle on both sides of car. The rear part of seal as shown is not sealed shut showing the foam tube end...good luck |
#43
USING a brushless car wash is bad idea period.
My Mercedes SLK 350 AMG (invented the retractible hardtop on this model) would leak at 80MPH in a hard rain. I did get a leak and it was a CPO, with 50K miles, they replaced the roof seal from the A pillar to the rear window, and it did the trick, these tops are tricky, lots of moving parts and pressure points..
------------------------------------------------------------------------ 2007 335i|Space Gray|Coral Red Leather|6 MT|Sport/Premium/Cold Pkg|Logic 7|HK 300W|Xenon|Hankook V12's|M3 Rear Lip Spoiler|M-Tech Front Aero Spoiler| M-Sport Aluminum pedals| M-Sport Shifter| BMWCCA Last edited by RaceBlood; 11-13-2010 at 05:13 PM. |
#44
people read your owner's manuals from cover to cover. Follow the manufacturer's recommendations and remember they are just that.....recommendations aka (official ORDERS TO NOT SCREW UP YOUR RIDE). |
#45
Not me. I'm old school. Just fix it, I say....wrench, hammer; air gun. If that's not workin', I like to post for help under an assumed name. Yo! Gotta rep t'protect. If no luck, and here desperation is an element, I Google! Yup, gotta be bad, but hey.... Even that may be of no assistance. I know! Suffering terrible and lasting defeat, I open my manual. My Bentley manual. If it's not there, I must give up, for all resources known to me are explored and I am left wanting. I go to my Indy. But I do not, under any circumstance, read my owner's manual! That's a move for young players, and I am no noob. I'm no noob at all. |
