Old 09-30-2010, 09:39 PM
mrpumpk1n mrpumpk1n is offline
Mein Auto: 540i 1997
thank you filon, il call up the dealer tomorrow and find out more info on it. il report back here about my findings.
"Owning any german car is like hanukkah,
every day another light"
Old 10-30-2010, 10:20 AM
Artavash Artavash is offline
Mein Auto: E38 728i
Hi
This is my first post since I bought my bimmer (E38 728i) for £1060 just last week. I'm also having the same issue with the fuel cutting out - so I wondered how you got on when you contacted the dealer and whether you managed to fix the problem?
I'm also going to try the other suggestions too.
As an aside I also had a similar issue with a 3.5Efi Vogue Range Rover I once had, although I got much more fuel in that in one go than I do with the bimmer.
Cheers
Old 10-30-2010, 06:44 PM
hey artavash, i went to the dealer and decided not to pay the $160 to get it diagnosed (on a problem i can deal with), and my indy just said to keep driving it like this because it would be too expensive to fix or even hunt down. ive tried what was suggested here and it hasnt worked .
Old 10-30-2010, 09:11 PM
filon102 filon102 is offline
Be american, get a bimmer
Mein Auto: 00' 540i, 87' benz 300DT
did you buy the actual part or no? (charcoal canister)
Old 10-30-2010, 09:15 PM
not yet because i have no idea on how to put it in
Old 10-30-2010, 09:24 PM
hmmm... i see what i can do for DIY off from "Alldata" from the college im going to... stay tuned
Old 10-31-2010, 04:21 AM
Mein Auto: E38 728i
Cheers for the reply.
Keep us posted
Old 11-02-2010, 11:53 AM
Well, here is what i found, hope it helps:
* Remove rear left wheel.
* Remove rear left wheel trim.
Loosen activated-carbon filter.
NOTE: Release the connections for the intake pipe and tank ventilation before pulling off with special tool 16 1 050.
Layout of Connections :
1. Ventilation
2. Suction tube to engine
3. Tank venting
Disconnect connections (1 ... 3)
Part #, and misc:
Evaporative Emission Control Canister
Vapor Canister:
OEM Part Price
To 3/97 16136758757 $138.07
From 3/97 16131184272 $138.07
Good luck
Old 11-02-2010, 06:01 PM
thanks so much filon! il get this done asap and report here as to how it works out
Old 11-03-2010, 11:16 AM
Anthony MV Anthony MV is offline
Mein Auto: 2003 E39 M54
dude,ur effing funny,thx for the laugh
temporarysanity
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
made me laugh good.......lol thx! i cant swim
SCHNELLER ARSCHLOCH!!!!!
BMWCCA # 386993
Mods: 2011 Mazda MX-5. Mazda Ipod kit,weathertech liners,garmin nuvi 1390 LMT,eclipse sunshades,front plate delete. Soon: tint 20% sides 5% back. Covercreaft NOAH car cover
Old 06-25-2012, 10:26 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
1. Ventilation
3. Tank venting
Part #, and misc:
Vapor Canister:
OEM Part Price
Good luck
Filon102,
Good information...!
Thank you!
I also have had problems with my car's fuel system...
I had the fuel pump replaced last year, and now, I can hear the new pump whining the same way the old pump did when it was failing...
Also, last year, when I was filling-up the car at the gas station, the pump did not shut-off, and shot gas all over the side of my car...!
This happened again about 1 month later...
I am wondering if the over-flow of gas may have damaged the Charcoal Canister and/ or the Fuel Vent Pump (Leak Detection Pump - #12) connected to the Charcoal Canister...?
http://www.realoem.com/bmw/showparts...96&hg=16&fg=10
Similar (BimmerFiver's thread):
http://forums.bimmerforums.com/forum....php?t=1438653
http://forums.bimmerforums.com/forum....php?t=1723195
Another:
http://www.bimmerfest.com/forums/sho...d.php?t=226044
Old 05-05-2013, 03:07 PM
Studawg's Avatar
Studawg Studawg is offline
bimmerfest Supporting Member
Mein Auto: 2003 540iT M Sport
I have this problem on my wagon. Does anyone know what causes it? Pulling it out and trying to find the sweet spot does not work. I have to barely squeeze the handle or it will cut off. Does a problem with the charcoal canister cause this? It is enough to drive me crazy!
Black Sapphire Metallic/Black leather, CWP, DSP, rear shades, Climate Comfort windshield.
fuel, fuel filter, techron
