Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 11-02-2010, 08:44 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Two of the Top Ten Surprisingly Unreliable Cars are BMWs
There are some cars you buy, expecting a certain degree of mechanical fallibility. In some cars, it's part of the character of owning one. In others, it's an inherent design issue that's well known and you learn to work around it. No one really buys an old Alfa Romeo expecting it'll never have wiring issues. People with a Citroen SM-Maserati didn't purchase it for it's Swiss Watch durability. Only the truly misinformed expect an old RX-7 to spend more time on the road than making the lawn look pretty.
But some vehicles have an absolutely baffling reputation for reliability in the face of considerable evidence. These are cars that people buy because their reputation leads them to believe they'll enjoy a few years of trouble-free motoring, and it's an unpleasant surprise when their wallet bleeds itself dry keeping them on the road. Here are a few to keep an eye out for that you might not have been aware of.
BMW N54-powered vehicles
This was the original idea behind this post. For those not well-versed in BMW-ese, the N54 is BMW's 3.0L iron-block straight six, fitted with twin sequential turbochargers that is fitted to almost all of BMW"s range in various states of tune, including the 1, 3, 5, and 7 series, as well as the X5, X6, and Z4. When it came out in 2006 as a replacement for the M54 3.0L engine, the automotive press and consumers alike were ecstatic. The N54 made a ton of power (306bhp) with almost no discernible turbo lag, a silky straight-six roar, and returned respectable fuel economy. Finally, the 3-series had the power to not get embarrassed by Infiniti G35's!
Problems arose pretty quickly, though. It shouldn't have been surprising; the N54 was BMW's first gas-turbo engine since the 745i in the mid-eighties with it's 3.2L M102 straight six. The issues weren't really related to the turbochargers themselves, so much as the direct injection system and it's high pressure fuel pump (HPFP) that supplies the ridiculously high fuel pressure needed to run the injection system. No one really knows what exactly causes the high frequency of failures with the HPFP, but some third parties suggest it's related to the low-pressure fuel sensor. Regardless, since the motor came out in 2006 the fuel pump has been through 6 different designs in the last four years, and owners on BMW boards are still reporting pump failures after only a few thousand miles.
After a few years of dodging warranty claims and calling it user error or attributing it to regional gasoline quality (a trend we'll see again), BMW issued a voluntary recall that covers 160,000 BMWs powered by the N54 engine. Considering the failure of the fuel pump can lead to the engine stalling and the loss of power steering and power brakes, it's a legitimate safety concern. If your twin-turbo BMW is exhibiting symptoms like an unwillingness to crank over in cold weather, stalling or sputtering at idle, or a check engine light and limp-home mode, then your HPFP could be dying. BMW is now covering this part with a 10-year, 120,000 mile warranty, so that helps.
BMW M60 V8
Another BMW engine snafu. The M60 was BMW's first modern V8 engine, which replaced the M30 "big six" in the 5 and 7 series lines. It was quite a high-tech design for the time: aluminum block, aluminum chain-driven twin-cam 4-valve heads, forged crankshaft, magnesium valve covers, direct ignition, all the works. Also new for the M60 V8 were Nikasil cylinder liners, which were made of a combination of Nickel, aluminum, and silicon rather than the traditional iron cylinder liners. This proved to be an issue.
The Nikasil liners suffered significant corrosion when low-quality gas with high sulfur concentration was run through the engine, leading to cylinder liners failing near the top of the piston and allowing for significant compression loss. Over time, it would literally cause the motor to not start at all. Since Nikasil was a spray-in liner, it wasn't possible to simply bore the block and sleeve it with iron liners, so the only solution was to replace it with a short block using the later Alusil lining, which didn't suffer from the corrosion issues that Nikasil did. Although the only regions that really suffered from this issue were America and Brazil, it still did not reflect well on BMW, who extended a 6-year 100,000 mile warranty to engines made with Nikasil liners.
Read the full story here - http://www.carthrottle.com/10-surpri...reliable-cars/
ID:	252940   Click image for larger version
Old 11-02-2010, 11:58 AM
Mk23's Avatar
Mk23 Mk23 is offline
Corner Carving Addict
Mein Auto: 09 - 335i E92
Funny I see no statistics on that site.
Old 11-02-2010, 12:20 PM
TRS550 TRS550 is offline
Mein Auto: 2007 550i
Not sure what statistics are required. N54 problem is recent (well...since 2007)and well documented.
The Nikasil V-8 issue is old news to those of us who've been driving these cars for the past 20 years.
E46 M3's regularly bit the dust until the marketing weenies backed off the 8000 RPM mandate.
BMW's pattern of deny deny deny and then blame bad gasoline is nothing new.
Old 11-02-2010, 04:02 PM
Mk23's Avatar
For them to state they are the TOP TEN worst reliable they need some statistics to back that up. Can't just name what you THINK are the top ten and then say it is fact.
Old 11-02-2010, 05:32 PM
Still no statistics required. The article doesn't say TOP 10. It's titled 10 Surprisingly Unreliable Cars. I think the OP might have misread that as well.
Old 11-02-2010, 06:40 PM
mundo74 mundo74 is offline
Mein Auto: 335i, FX35
Iron block
Who makes iron blocks anymore
Current: F10M5
Previous 08' E90 335 (sadly missed)
ED Pickup: April 20, 2008
Re-delivery: PDC June 25, 2008
Old 11-03-2010, 10:50 AM
sdbrandon sdbrandon is offline
Mein Auto: 2012 535i
The difference between the most reliable car and the worst is negligle although JD Power would like you to believe that there is a huge difference between an average of 1.5 defects per car (Lexus), and BMW with 2.5 for example.
The reality is if BMW were as bad as some suggest, I am confused by the strong sales. I am cofused by them not needing a bailout during the recession. I am confused why they did not recall 10 million vehicles like Lexota.
but oh yeah, Toyota is the best. BMW sucks, and people are plain stupid for even considering a German car.
2012 535i
Old 11-04-2010, 12:28 AM
Adi's Avatar
Adi Adi is offline
Mein Auto: E38 750iL, A6 (4f) Avant
I'd like them to one day make a 5-series touring where the tailgate doesn't rust. You'd think that would be pretty simple to do - no moving parts and all.
Audi A6 Quattro Avant (2007) - Oyster Gray Met.
E38 750iL (1995) - Cosmos Schwarz
Sign by Danasoft - Get Your Free Sign
Old 11-04-2010, 09:39 AM
Scott ZHP's Avatar
We want the Lion!
The E46 M3/S54 engine issue is also well documented. BMW, as usual, condemned the owners instead of admitting there was a problem - one it knew about all along but refused to admit.
Old 11-04-2010, 09:44 AM
jmsent jmsent is offline
Mein Auto: 07 335i Coupe
At least get your facts straight. The N54 is not an iron block. It's aluminum.
Sold-07 335i COUPE-SPACE GRAY-STEP-SPORT-PREMIUM-COLD-SIRIUS-RFT DELETE
Old 11-04-2010, 09:58 AM
Scott ZHP's Avatar
We want the Lion!
It has iron *liners*, which is what I suspect the OP meant.
Old 11-04-2010, 11:19 AM
And I quote: "For those not well-versed in BMW-ese, the N54 is BMW's 3.0L iron-block straight six,"
Seems pretty clear what he said. If he meant "iron liners" then why didn't he just say so?
Old 11-05-2010, 09:41 PM
Jsborn Jsborn is offline
always learning...
Mein Auto: '89 Porsche 944 S2
To the reposter of the article: Why repost an article full of inaccurate statements and unsubstantiated conjecture (and get the title wrong)? As previously stated, the N54 has an aluminum block. Also, I'm fairly certain that the N54's turbo setup is parallel, not sequential.
Also, reposting an article that cites "owners on BMW boards are still reporting pump failures" as anything but support for real data is propagating the same type of hearsay posting that clutters the E90 board on bimmerfest. I have an N54 (no failures) and am VERY interested in actual numbers, but this article is just another poseur.
I usually wouldn't respond this bitingly, but please avoid posting garbage like this on bimmerfest's front page--it's inaccurate on several counts, poorly written, and lacking data for its assertions.
E93 335is DCT w/ Invisihitch + 1Up, split armrest, stainless lines, track pads...super fun
Recent ex: Porsche 944 S2
Former Bimmers: Dinan E39 M5, E90 335i 6mt sport JB+, E36 M3
Old 11-10-2010, 02:03 PM
TED13B TED13B is offline
Mein Auto: 2000 328
The last M60 was sold about 15 years ago, and this comes out in an article now? Does it include the Pinto and Oldsmobile 350 diesels as well??
Old 11-10-2010, 02:37 PM
Bremen Ben's Avatar
Bremen Ben Bremen Ben is offline
Mein Auto: A nice car
This article is like those "top ten combat rifles" type of shows that compare the WW I Mauser K98k with the M16; entertaining at best but nothing else beyond that.
Old 11-13-2010, 09:59 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Cant forget about the breaking motor mounts with Chevy in the late 60s...lol
Old 11-14-2010, 03:02 AM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
Blame it on bad gasoline is the standard disclaimer among many manufacturers. My wife's V6 Highlander with 42K miles was running like crap under any load. No power, no codes. IT was always worse when the temp outside was 75+. Brought it to dealer and with no codes, they said.... must be bad gas, that will be $90 please for the diagnosis. Well it was not the gas, and another trip to the dealer with this issue did not get resolved since it was cool out and the issue never showed up when cool. In the end I carefully cleaned the MAF with CRC MAF cleaner and it has been perfect since.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 11-14-2010, 03:05 AM
gtxragtop's Avatar
Resale value of the 335/535 speaks to the fact that these are not reliable power plants.
Old 11-14-2010, 10:08 AM
EdCT's Avatar
EdCT EdCT is offline
zeddy
Mein Auto: '06 330cic ZHP / '07 M35x
The HPFP issue is well documented by now, so much so BMW has issued a recall.
Our cars aren't perfect guys, so shoot the messenger all you want, the problem is real.
FWIW, I've always avoided turbos, unfortunately, it appears BMW will be banking on turbos for years to come, having announced a new single turbo.
Sigh ...
2000 Mercedes Benz E320 (daily driver)
2007 Infiniti M35x (wife's)
2006 330 cic ZHP 6sp (current)
2005 Z4 3.0 sp nav x-leather (retired)
2000 323i PP (best car, ever - retired)
Old 11-14-2010, 10:53 AM
AzNMpower32's Avatar
Tar Heel Faithful
Sigh ...
Everyone is moving to turbos for their potential for lower emissions and fuel consumptions, combined with modern engineering that allows power delivery to be smoother and more usable. With ever stricter emissions and fuel consumption standards, big engines just really weren't the way to go.
One of the coolest examples I want to sample is the VW 1,4 TSI Twincharger engine, both a super and a turbocharger.
Old 11-14-2010, 10:56 AM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
Sigh ...
They've kinda been forced to... Between all the other manufacturers selling entry level cars with 300+ HP (hell, you can get a Camaro SS w/ 425hp for $30k) and the federal mandate to raise average fuel economy, forced induction is really the only logical choice.
With that said, I think the reliability issue is more due to the direct injection than it is to using turbos. I wonder how reliable the N53 engine in Europe is (N/A direct injection 6. 272hp... not bad for a 3-liter that only spins to 7k)
Old 11-29-2010, 05:54 AM
sambb sambb is offline
Mein Auto: 750iL
The HPFP issue is a big deal... the way BMW has handled it for years, from an owner's perspective, is atrocious. ABsolutely reprehensible. I was told several times that i was "driving my car wrong" and that I "ran over something". That was several fuel pump versions ago. I would NEVER recommend purchase of an N54 vehicle.
Old 11-29-2010, 06:44 AM
SWMc SWMc is offline
Mein Auto: LCI X3
The X3 has been rated as one of the most reliable.
BMW X3: Most reliable vehicle on Germany's roads
The BMW X3 has finished first in the ADAC quality ranking for the second time in succession.
In the ADAC breakdown statistics, the BMW X3 was the model which last year made least work for the ADAC roadside assistance mechanics, known in Germany as the "Gelbe Engel".
As in the previous year, the Sports Activity Vehicle was awarded the renowned ADAC "Gelber Engel" prize in the "Quality" category.
Germany's automobile club thus once again deems the BMW X3 to be the most reliable vehicle on Germany's roads.
The "Gelber Engel" award is based on an evaluation of some 2 million cases drawn from ADAC breakdown statistics as well as a customer satisfaction study by the club magazine "ADAC motorwelt". 43,000 readers participated this time.
500,000 units of BMW X3 have been supplied as of November 2008.
http://www.autospies.com/news/BMW-X3...s-roads-40910/
Old 11-29-2010, 07:08 AM
Mein Auto: LCI X3
A 6.2L pushrod V8 putting out 425hp does nothing for me. I honestly can't believe Chevrolet is still building pushrod engines.
BMW was building OHC inline 6 engines in 1918.
The pics are from the Smithsonian
ID:	256440   Click image for larger version
Old 11-29-2010, 11:22 PM
Shrike Shrike is offline
Mein Auto: 330i 6-speed, ZSP
Ford gets 412 hp (approx?) out of a 5.0 liter DOHC V8 that redlines at 7,000 rpms in the '11 Mustang GT, whose base price is around $30k. Yes, the car's crude compared to a BMW but 400 plus horsepower for 30k. And more than 0.9g on the skidpad.
2004 330i, 6-speed, ZSP, Silver/Black
2012 Mini Cooper automatic (wife's daily driver, snow machine with Blizzaks)
hpfp, n54, recall
