Old 11-03-2010, 05:29 PM
emimix emimix is offline
Mein Auto: BMW 550i
K&N Air Filters
Hi,
I plan to replace my F10 air filter with K&N air filter.... does anyone know where can I locate the air filter on the F10?!
http://assets.clickmotive.com/ail/st..._050.jpg?w=530
THX
Old 11-03-2010, 05:47 PM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
Curious...what are you hoping to gain?
Old 11-03-2010, 09:33 PM
1HOT BMR's Avatar
1HOT BMR 1HOT BMR is offline
Mein Auto: 2015 X5d/ 2012 X5d
Originally Posted by emimix View Post
Hi,
THX
The only thing you will gain is more induction noise - if that is what you are after, I understand. Other than that, the switch will be all negative - no additional power and less filtration allowing more dirt into the engine.
Old 11-04-2010, 07:47 AM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: E92 335i
Exactamundo!
Old 11-04-2010, 07:56 AM
Quick11 Quick11 is offline
Mein Auto: 2011 535i
Been there....done that! Not worth the effort with respect to any slight gain and as stated previously ...poorer filtration
2011 535I Dark Graphite, Sport, P 1&2, Cold, 8spd, CA
Old 11-04-2010, 09:12 AM
Mein Auto: BMW 550i
From the hundreds of reviews and the people who use them, the K&N air filter design is superior to a paper element (OEM) because it allows for superior filtration without sacrificing air flow for a longer period of time ....many high performance cars use them
http://www.knfilters.com/filtercharger.htm
My brother uses 2 K&N air filters in his Infiniti FX50S, and he loves them....he says he will never go back to his OEM filters.
So.... anyone knows where can I locate the F10 air filter?
Old 11-04-2010, 09:21 AM
Emilner Emilner is offline
Mein Auto: 2013 SL63
I do not know if they have filters yet for the f10.
That being said, with the new strict CAFE requirements on mpgs it is hard to imagine there would be a way to just bolt on an airfilter in an existing box to gain hp and mileage. It was certainly true a decade ago, but since then the manufacturers have aggressively wrung those easy to find hps and mpgs out of the cars. That is why todays filters are so much bigger and often have 2 vs 1 filter.
You also run the risk of filter oil clogging the sensors which do void engine malfunctions when they are proven to cause the problem.
2015 S550 Anthracite blue, Silk, loaded and doin just fine...
2013 SL63 AMG black....
2014 GL350 The kids chariot.
2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... (gone)
2012 650 Cabriolet M sport (gone)
Old 11-04-2010, 10:59 AM
Diver624 Diver624 is offline
Diver624
Mein Auto: Porsche 911 Turbo
Why does you brother like them, has he measured any power/torque difference on a dyno? Do you really think an auto manufacturer would use an air filter that restricts power when they spend enormous amounts of time and money trying to get even small increases in power from these engines. If such a cheap, simple item really increases power I have no doubt the manufacturers would be using them. K&N is a marketing company. Additionally if you use one of the oiled K&N filters your asking for trouble with your MAF (mass air flow sensor).
ordered-2018 M550ix White, Mocha
2014 550ix Mineral White, Black
2015 X5 35i
Porsche 997 GT3
Porsche 993 Cab.
Porsche 996 Turbo (Ruf 550) gone but not forgotten
ordered-2017 Mustang GT350
Old 11-04-2010, 11:18 AM
johnbmw6's Avatar
johnbmw6 johnbmw6 is offline
Mein Auto: 2016 LCI M3/2015 M6 GC CP
TBH BMW cars are all running rich from the factory, this poor ecu set-up is due to cars being fed all sorts of poor fuel quality throughout the world, the ECU remaps enhance premium fuelled car set-ups, and give more BHP and better fuel economy as well as better running.
There is always "some Power" to be gained by this method regardless of Turbos or Naturally aspirated.
Live for now , tomorrow never comes.
Old 11-04-2010, 11:57 AM
Mein Auto: BMW 550i
OEM stuff are not optimal so you keep getting back for replacements
it already compared OEM with KN
http://www.knfilters.com/dynocharts/33-2970.pdf
the filter is not about power, but better ventilation and air flow ...it's also more $$ than the OEM, and you dont' need to change it for life
Old 11-04-2010, 12:12 PM
TJPark01's Avatar
Mein Auto: E92 335i
If you want better power and airflow, you'll get a heck of a lot more from the swapping out the computer, that controls everything. Swapping out paper filters for K&N may give you more power at full throttle, but I doubt it's noticeable with a OEM ECU.
Also the cost of the K&N over stock makes the "save money change it for life" argument, mute, since it would take you 10 years to be on the + side of that monetary equation. Assuming you keep the car that long.
Old 11-04-2010, 12:36 PM
Billd104's Avatar
Billd104 Billd104 is offline
Mein Auto: 2015 Mazda 6 GT
Perhaps one who is unable to locate the air filter should not be replacing same? Just a thought. My advice... Stay away from K & N filters, you're just asking for trouble.
2007 530xiT -- Titanium Silver / Black Dakota / Nav / PP / Step / Sirius / HD / CWP / CA /Rear shades / 2 Diono Monterey Booster Seats in Pink :>) / Hüper Optik tint -- Ordered 08/19/06 -- Delivered 10/17/06 -- 59 days order to delivery.
"Money is a strange business. People who haven't got it aim at it strongly. People who have it are full of troubles." -- Ayrton Senna
BMW CCA Member
Old 11-04-2010, 02:52 PM
Diver624
I was only referring to changing the air filter to a K&N filter which will not produce any gains and might cause problems if you use the oiled version.
An ECU re-map will, especially on a turbocharged car produce HP/Torque gains but will void your warranty.
2015 X5 35i
Porsche 997 GT3
Porsche 993 Cab.
Old 11-04-2010, 03:10 PM
So what you are saying is that faced with tens of millions in fines from CAFE and ever escalating costs to get another 1/2 mile to the gallon (the same reason you would get more hp is the reason you would get more MPG), BMW has cheaped out and put in a sub par filter to save a buck? Seriously quit with the snake oil...
Old 11-04-2010, 04:26 PM
1HOT BMR's Avatar
It might be one of those things that you must do regardless of anyone's advice. If you are young enough then it may be exactly that. For some of us older guys we've done it too - springs, exhausts, shocks, turbos, K&Ns and much more without much gain with the exception of noise and a harsher ride. You'd be wise taking the advice but you may not want to because you just need to do it - if that's the case, go ahead with that K&N swap, even if the extra power and better running of your engine is not true you will just "know" that it's running better and it will make you happy regardless.
Old 11-04-2010, 04:54 PM
Aronis Aronis is offline
Mein Auto: RS6
Oil from the filter (if over oiled and not properly dried) will damage the mass air flow sensor. Be careful.
2016 M2 Alpine White, 7 speed DCT
2015 Q7 s-line Daytona Grey
2003 RS6 Daytona Grey
Prior: 2013 A8L, 2008 A4 Cab, 2000 A6 4.2 sport, 1997 M3 luxury, 1994 325 is with M-tech suspension
Old 11-04-2010, 05:30 PM
johnbmw6's Avatar
IF of course your engine has one, the E92/90 M3 does not. I am not sure if the 550i has or not till mine arrives.
I did use the BMC filter on the M3 and it did give some BHP about 4BHP and increased the induction noise, it did sound nice with the remap. I will not go this route with the 550i M sport though must be getting old.
Old 11-05-2010, 09:24 PM
bklyn550 bklyn550 is offline
Mein Auto: 2011 550i sport
Dinan wont void warranty and adds 95hp. 100 ftlb torque its 3000
Sent from my Nexus One using BimmerApp
Old 11-07-2010, 08:59 AM
Diver624
Are you saying that BMW supports the Dinan modifications. If you can get that in writing then go for it.
2015 X5 35i
Porsche 997 GT3
Porsche 993 Cab.
Old 01-27-2013, 01:41 PM
Gre8tW8LL Gre8tW8LL is offline
Mein Auto: 97 Honda Accord
Emimix,
Did you end up buying the K&N air filter? if so, did you notice any gains or better air flow? I believe in K&N as i used to have it in my Accord back in the day. It definitely breathe better.
2012 535i Alpine White | Oyster Black Dakota Interior | Hamann CF Front Lip | LiteSpeed Catback Exhaust System | M5 Rear Diffuser | Painted Calipers, Reflectors & Black Gloss Grill | FormulaOne Pinnacle Series Tint | Born on 1/30/12
Gre8tW8LL
Old 01-27-2013, 02:14 PM
m6pwr m6pwr is offline
Mein Auto: '14 335i M Sport
I tried K&N once a long time ago. I did used oil analysis, too. The ppm silicon (dirt) in the used oil analysis nearly tripled after the K&N - - almost to the labs condemnation point around 20+ ppm IIRC. I never used one again. The K&N does reduce the inertia of the air column in the intake track (removing the filter altogether does, too) which gives you a feeling of a more sensitive throttle response, which in turn is mistaken for more power. But it's all smoke and mirrors, pure illusion.
By the way, BMW does recognize DINAN. Many BMW dealers are also DINAN dealers and DINAN warranties their mods/software. If the dealer updates your factory software/ecu when you have the car in for service (which they do all the time and which will wipe your DINAN), and if they're a DINAN dealer, they will reload whatever DINAN performance stage you have at no charge - - it's part of the DINAN warranty. Don't think other mod houses do this.
Old 01-27-2013, 11:54 PM
K-A's Avatar
K-A K-A is offline
Cray
Mein Auto: Porsche Macan S SportDsgn
I was thinking about it, but I know from Mercedes and now apparently BMW, K&N filters don't do much except add more risk and throw the "balance" off, per-se. Seems these motors are engineered to a degree where a K&N won't help at all (maybe hurt?). I wouldn't mind extra induction noise especially from a Turbo, though. At the same time, I love the quietness of this car where you hear some deep engine noise around town (subtle and "pleasant"), but only "truly" hear it when you get on it, nice balance IMO.
'15 Porsche Macan S SportDesign | White/Black (Alcantara/Leather), PDK, 20" RS Spyder's w/ Colored Crests & Summer Tires, Air Suspension w/ PASM, High-Gloss Black Trim, Premium Package, Comfort Lighting, HD Radio, Tints.
'15 Mazda 3 i Sport.
Recents: '13 BMW 535i M Sport: Black/Black, Prem/Tech/Sport Auto/etc. M-B's: '11/10/06 E350 "Sport", '02 S500 w/ Every Option.
Old 01-28-2013, 02:54 AM
schnell525 schnell525 is offline
Mein Auto: 12 550xi
back in my C5 A6 days putting in a K&N was a no-no due to problems with sensors, like MAF.
i can't see sticking one of those in and incredibly expensive machine like at 550. nake oil imo.
Auf Wiedersehen 12 550xi
Old 01-28-2013, 05:30 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
emimix, make sure you get some of that Slick 50 oil treatment and Tornado fuel saver when you put in the K&N filter
Old 01-28-2013, 08:06 AM
AggieKnight's Avatar
AggieKnight AggieKnight is offline
Can has cheezburger
Mein Auto: A lonely i3
LOL.
I had a K&N air filter in my heavily modified Tegra and it definitely "sounded" faster than OEM. Whether it had a larger impact on the car than the japanese characters I had painted on the door, I'm not sure.
WARNING: Author not responsible for the readers failure to recognize sarcasm.
Yield, I can has picture?
Current Car:
2014 BMW i3
Retired Bimmers:
2013 BMW 550
2009 BMW 335
Last edited by AggieKnight; 01-28-2013 at 08:07 AM. Reason: Clarification -> I did have a Tegra that was heavily modified and did put a K&N in it, but did not actually paint characters
