Old 11-06-2010, 06:44 PM
07X3platinum's Avatar
07X3platinum 07X3platinum is offline
Mein Auto: 2012 E550 Sedan
Are these symptoms of a Power Failure/Battery Problem?
2010 528i, Auto, No Comfort Access
I drove the car 40 miles and made a stop.
Drove another 10 miles and stopped.
Locked it with my key fob remote and heard the usual "chirp."
Within 5 minutes I tried to unlock the door using my key fob remote and nothing happened.
I tried all 3 buttons on my key fob and the car did not respond to any of them.
Luckily I knew about the hidden key inside the fob, so I used that to open the driver's door.
The car started right up, but the car's settings were all gone/reset.
The clock was still showing the correct time, but my radio presets were gone and my Daytime Running Light settings were reset along with the Triple-turn signal function.
I drove 30 miles home and locked the car with my key fob and heard the "chirp."
Just as a test, I pressed the unlock button on my key fob and it worked! I locked it again and head the chirp. I'll check tomorrow to see if my radio presets and car settings are back.
Is this a symptom of a Battery Problem/Power Failure? Or do you think it's just a weird glitch?
"Money is freedom."
Old 11-07-2010, 12:13 PM
Update
UPDATE:
Everything seems to be back to normal. The key fob worked this morning and I was able to unlock the door and when I started the car all of my settings and radio presets were back.
I guess the car didn't recognize my settings last night because I wasn't able to use the key fob to unlock the door.
I'm not sure why the key fob stopped working last night. Maybe it was because I was in downtown Chicago and there was radio interference. Or maybe it was just a random glitch.
"Money is freedom."
battery, presets, reset, unlock
